Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Dynamic size composite
Dynamic size composite [message #451756] Tue, 08 March 2005 10:53 Go to next message
Originally posted by: rodrigo.im.ufba.br
In my application there is a Group whose contents change based on user's=
choice. When the contents change, the Group isn't resized to fit them (t=
he =
Group is inside a Composite with RowLayout). What can I do to resize the=
Group based on its contents?
Rodrigo
Re: Dynamic size composite [message #451767 is a reply to message #451756] Tue, 08 March 2005 12:32 Go to previous message
Call layout(true) on the parent Composite with the RowLayout. You need to
call layout(true) on the parent of the topmost parent that you expect to
change size due to this change.
If you are using 3.1, you can call group.getShell.layout(new
Control[]{group});
This will determine exactly which parents in the parent hierarchy need to be
resized.
"Rodrigo Rocha" <rodrigo@im.ufba.br> wrote in message
news:op.snbs3q1z23h1qe@kurumin...
choice. When the contents change, the Group isn't resized to fit them (the
Rodrigo
Previous Topic:Different radio button groupings in the same shell
Next Topic:Looking for input masking and data validation widgets for SWT
Current Time: Sat Jul 19 14:56:49 EDT 2025
Powered by FUDForum. Page generated in 0.04337 seconds
