Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Bug in SWT, drawing on partially transparent image?
Bug in SWT, drawing on partially transparent image? [message #451655] Fri, 04 March 2005 04:31 Go to next message
Originally posted by: David.A.Price.nokia.com
I'm new to SWT, and playing around with Canvas and transparent images.
I've found a rather puzzling behaviour, which seems to me to be a bug. I
didn't find anything relevant in the bug database or from Google. I'm
using SWT 3.0.1 and Windows 2000 SP4.
When I create a blank Image using a depth 32 ImageData and a non-indexed
PaletteData, where part of the ImageData has had setAlpha called to make
it fully opaque, later drawLine operations on the image only affect the
opaque part of the image. I would expect that lines drawn on the
transparent part of the image would also appear.
I've confirmed that if I create the image using an indexed palette, lines
drawn on the transparent part appear as I'd expect.
Is this a known bug? Is it somewhere documented as expected behaviour? If
not, should I submit a bug report?
David
PS. I've attached sample code. It produces a black rectangle with a red
'V', on a yellow background. I'd expect the red 'V' to continue downwards
to form an 'X'.
----8<----------------------------------
import org.eclipse.swt.*;
import org.eclipse.swt.widgets.*;
import org.eclipse.swt.graphics.*;
public class TestImage3 {
final Display display = new Display();
PaletteData palette =
new PaletteData(0x00FF0000, 0x0000FF00, 0x000000FF);
ImageData data = new ImageData(40, 40, 32, palette);
for (int x = 0; x < data.width; ++x) {
for (int y = 0; y < data.height / 2; ++y) {
data.setAlpha(x, y, 255);
final Image image = new Image(display, data);
GC tempGc = new GC(image);
tempGc.setForeground(display.getSystemColor(SWT.COLOR_RED));
tempGc.drawLine(0, 0, image.getBounds().width,
image.getBounds().height);
tempGc.drawLine(0, image.getBounds().height,
image.getBounds().width, 0);
final Shell shell = new Shell(display);
shell.setText("Test Image 3.");
shell.addListener(SWT.Paint, new Listener() {
public void handleEvent(Event event) {
GC gc = event.gc;
Rectangle rect = shell.getClientArea();
Rectangle bounds = image.getBounds();
gc.drawImage(image,
rect.x + (rect.width - bounds.width) / 2,
rect.y + (rect.height - bounds.height) / 2);
shell.setBackground(display.getSystemColor(SWT.COLOR_YELLOW) );
shell.setSize(200, 100);
shell.open();
while (!shell.isDisposed()) {
if (!display.readAndDispatch()) {
display.sleep();
display.dispose();
Re: Bug in SWT, drawing on partially transparent image? [message #451658 is a reply to message #451655] Fri, 04 March 2005 08:37 Go to previous messageGo to next message
When you call the ImageData.setAlpha() API, it is assumed that you are going
to set the alpha value for each pixel. The alphaData array gets created and
initially all of its values are 0 until you set a different value. Drawing
on the image does not affect the alpha values for the pixels you are drawing
on. Perhaps you should be setting the transparency rather than the alpha
value to get the effect you want:
PaletteData palette = new PaletteData(0x00FF0000, 0x0000FF00,
0x000000FF);
// pick some colour to be transparent
// anything drawn with this colour will be transparent
data.transparentPixel =
palette.getPixel(display.getSystemColor(SWT.COLOR_BLUE).getR GB());
tempGc.setBackground(display.getSystemColor(SWT.COLOR_BLACK) );
tempGc.fillRectangle(0, 0, bounds.width, bounds.height/2);
tempGc.setBackground(display.getSystemColor(SWT.COLOR_BLUE)) ;
tempGc.fillRectangle(0, bounds.height/2, bounds.width,
bounds.height);
tempGc.drawLine(0, 0, bounds.width, bounds.height);
tempGc.drawLine(0, bounds.height, bounds.width, 0);
GC gc = event.gc;
gc.drawImage(image,
bounds.width) / 2,
shell.open();
display.sleep();
display.dispose();
"David Price" <David.A.Price@nokia.com> wrote in message
news:d099sq$3pc$1@www.eclipse.org...
> David
> to form an 'X'.
> public static void main(String[] args) {
> GC gc = event.gc;
> gc.drawImage(image,
> shell.open();
> display.sleep();
> display.dispose();
Re: Bug in SWT, drawing on partially transparent image? [message #451659 is a reply to message #451658] Fri, 04 March 2005 10:15 Go to previous message
Actually, my eventual purpose is to be able to create arbitrary
non-rectangular 'sprites' by drawing on initially transparent images. I
was just surprised that drawing on an image does not affect the alpha
values for the pixels you draw on - it seems natural that it would (after
all, drawing on a transparent piece of glass results in opaque lines).
Maybe this is just a reflection of an oddity of the underlying Windows API?
Your approach of defining a transparent colour should solve my problem -
with a 24-bit palette it's not hard to choose a colour that I won't need
for my sprite. I must say I'm surprised to learn that you can have a
transparent colour without an indexed palette - you learn a new thing
every day :-)
Thanks for your help,
David
Previous Topic:How I can change the size of a treeviewer to show all content?
Next Topic:OleAutmation help
Current Time: Sat Jul 19 15:42:34 EDT 2025
Powered by FUDForum. Page generated in 0.08349 seconds
