Home » Eclipse Projects » Standard Widget Toolkit (SWT) » about swt 's thread .
about swt 's thread . [message #451611] Thu, 03 March 2005 06:33 Go to next message
if a long run Thread update a widget many times,then which
code is better?
first:
updateRunnable = new Runnable() {
public void run() {
//update a widget;
new Thread() {
public void run() {
for(int i = 0 ; i< manytimes; i++) {
//compute the data ,costs some time
display.syncExec(updateRunnable);
//compute some data,costs some time
}.start();
second:
display.asyncExec(new Runnable() {
public void run() {
//update a widget;
Thank you for your help !
Re: about swt 's thread . [message #451616 is a reply to message #451611] Thu, 03 March 2005 07:22 Go to previous messageGo to next message
The first way is better.
The second way still runs in the UI thread and if the data computation takes
a minute or so, you will end up blocking the UI thread and the application
will be unresponsive (hung) until it completes. Display.asyncExec runs when
the event loop is idle but it may not be idle for very long.
"bbskill" <bbkills@tom.com> wrote in message
news:d06sqn$d69$1@www.eclipse.org...
> code is better?
> first: updateRunnable = new Runnable() {
> public void run() {
> //update a widget; }
> new Thread() {
> public void run() {
> }.start();
> second:
> public void run() {
> //update a widget; //compute some data,costs some time
Re: about swt 's thread . [message #451620 is a reply to message #451616] Thu, 03 March 2005 07:32 Go to previous messageGo to next message
Thanke you for your advise.
>>code is better?
>>public void run() {
>>new Thread() {
>>public void run() {
>>}.start();
>>second:
>>public void run() {
Re: about swt 's thread . [message #451636 is a reply to message #451616] Thu, 03 March 2005 14:02 Go to previous messageGo to next message
Originally posted by: bob.objfac.com
Essentially you're saying the two ways are equivalent and the first way
is simpler. True, but if computing the data took a minute or more,
wouldn't he be better off running the compute in a separate thread in
the background, then using asyncExec to update the widget? A minute is
an awfully long time to hang the UI thread.
Bob
>>code is better?
>>public void run() {
>>new Thread() {
>>public void run() {
>>}.start();
>>second:
>>public void run() {
Re: about swt 's thread . [message #451639 is a reply to message #451636] Thu, 03 March 2005 14:29 Go to previous messageGo to next message
Maybe my words were not very clear. The two ways are not the same at all.
The second one hangs up the UI thread if it runs for any significant length
of time. The second way starts the work when the event loop is idle but
will block new events until it completes and therefore is bad. The first
way executes only the minimum amount of work in the UI thread (updating the
UI) and therefore does not or hang the GUI - that is why it is better.
"Bob Foster" <bob@objfac.com> wrote in message
news:42275F3D.2090705@objfac.com...
> Essentially you're saying the two ways are equivalent and the first way is
> simpler. True, but if computing the data took a minute or more, wouldn't
> he be better off running the compute in a separate thread in the
> background, then using asyncExec to update the widget? A minute is an
> Bob
>> takes a minute or so, you will end up blocking the UI thread and the
>> application will be unresponsive (hung) until it completes.
>> Display.asyncExec runs when the event loop is idle but it may not be idle
>> for very long.
>>>code is better?
>>>public void run() {
>>>new Thread() {
>>>public void run() {
>>>}.start();
>>>second:
>>>public void run() {
Re: about swt 's thread . [message #451649 is a reply to message #451639] Fri, 04 March 2005 01:09 Go to previous message
My humble apologies. I misread the first example. It's exactly what I
suggested. Feeling pretty foolish, but thanks for your kind reply.
Bob
>>Bob
>>>for very long.
>>>>code is better?
>>>>public void run() {
>>>>new Thread() {
>>>>public void run() {
>>>>}.start();
>>>>second:
>>>>public void run() {
Previous Topic:Is there a way to actively "read" keyboard modifier state?
Next Topic:TableViewer behaviour with SWT.VIRTUAL in 3.1-M5a?
Current Time: Sun Jul 20 06:22:42 EDT 2025
Powered by FUDForum. Page generated in 0.05191 seconds
