Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Error creating OleControlSite
Error creating OleControlSite [message #451435] Tue, 01 March 2005 22:54 Go to next message
Originally posted by: michael_bishop.rta.nsw.gov.au
Wondering if someone might be able to help me out with an OleClientSite
creation error:
I have a 3rd party .exe which registers itself as an OLEServer when it is
first run.
A simple Visual Basic program using this COM object runs correctly.
However the same code in Java, using SWT's OleClientSite, gives an
ERROR_CANNOT_CREATE_OBJECT error when it tries to instanciate the
OleClientSite object.
Would anyone know what is going wrong when I use OleClientSite ?
The Visual Basic code and equivalent Java code is attached.
Thankyou
Michael Bishop
**======================== VB Code
Private Sub Form_Load()
Dim TMCVSClient As Object
Set TMCVSClient = CreateObject("TMCVSClient.TMCVSClientInterface")
Dim Result As Integer
Result = TMCVSClient.SelectCamera("1")
Set TMCVSClient = Nothing
End Sub
**========================= JAVA Code
Shell shell = new Shell(display);
OleFrame frame = new OleFrame(shell, SWT.NONE);
OleControlSite controlSite = new OleControlSite(frame,
SWT.NONE,
"TMCVSClient.TMCVSClientInterface");
Re: Error creating OleControlSite [message #451456 is a reply to message #451435] Wed, 02 March 2005 11:26 Go to previous messageGo to next message
OleControlSite is for ActiveX controls only. It does not support generic
COM objects. My guess is that you are getting the error "-2147483644 No
such interface supported" which probably means that the COM object you are
trying to embed does not support the minimal set of interfaces required by
an ActiveX control.
"Michael Bishop" <michael_bishop@rta.nsw.gov.au> wrote in message
news:d03de7$or4$1@www.eclipse.org...
> creation error:
> first run. A simple Visual Basic program using this COM object runs
> correctly. However the same code in Java, using SWT's OleClientSite, gives
> an ERROR_CANNOT_CREATE_OBJECT error when it tries to instanciate the
> Thankyou
> Michael Bishop
> End Sub
> OleControlSite controlSite = new OleControlSite(frame, SWT.NONE,
Re: Error creating OleControlSite [message #451560 is a reply to message #451456] Wed, 02 March 2005 18:25 Go to previous messageGo to next message
Thanks Veronika for the reply,
I have also tried using OleClientSite in place of OleControlSite and I get
the same error :
org.eclipse.swt.SWTException: Failed to create Ole Client. result =
-2147221164
at org.eclipse.swt.ole.win32.OLE.error(OLE.java:302)
at org.eclipse.swt.ole.win32.OleClientSite.<init>(OleClientSite.java:238)
Maybe what I am doing is incorrect because I just want to call methods of
the Ole Automation object - I don't need to display it in the GUI.
Do you know if Eclipse has support for using an ActiveX Control that
doesn't need to be embedded in a Frame ?
Cheers
Michael Bishop
Re: Error creating OleControlSite [message #451618 is a reply to message #451560] Thu, 03 March 2005 07:33 Go to previous message
SWT does not have support for non-UI COm objects:
See:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=68194
news:d05i0h$mve$1@www.eclipse.org...
> the same error :
> = -2147221164
> Cheers
> Michael Bishop
Previous Topic:OleAutomation with Excel
Next Topic:Regarding Spinner widget in latest SWT swt-3.1M4-win32
Current Time: Sun Jul 20 16:02:41 EDT 2025
Powered by FUDForum. Page generated in 0.05465 seconds
