Home » Eclipse Projects » Standard Widget Toolkit (SWT) » setLocation Problem when resizing shell
setLocation Problem when resizing shell [message #450610] |
Wed, 16 February 2005 04:36  |
Hi out there,
I have a little question for those of you who are deeper inside the code
of SWT.
I have a shell with a composite that is being placed via setLocation
when the shell resizes. Unfortunately the setLocation seems to be
uneffective and I reckon, after I set the Location there is someone else
who does the same. I think it might be the shell when it lays out it's
composites after the resize.
The composite is not part of a layout so I don't really want to have it
laid out automatically (the location is 0/0 after resize).
Is there a possibility not to set the Location of my composite on the
shell automatically or is there some other mistake I'm making?
Thanks a lot and have a nice day,
Peter
Re: setLocation Problem when resizing shell [message #450651 is a reply to message #450646] |
Wed, 16 February 2005 10:29   |
Steve Northover wrote:
> You're going to have to code a small stand alone snippet that shows then
> problem. I can't understand it from your description.
> "Peter Goetz" <kingofbrain@web.de> wrote in message
Hi Steve,
thank you very much for your answer. I have prepared a relatively small
piece of code that illustrates the error.
It is attached below.
The important thing happens in line 115 where I call setLocation on the
Composite.
If you execute the program and open or close the "fastview", everything
is fine. But if you resize the shell, the Composite gets the location 0/0.
I hope you can help me!
Thanks a lot in advance.
Peter
===== CODE =====
package de.kaobe.fastview;
import org.eclipse.swt.SWT;
import org.eclipse.swt.events.ControlAdapter;
import org.eclipse.swt.events.ControlEvent;
import org.eclipse.swt.events.SelectionAdapter;
import org.eclipse.swt.events.SelectionEvent;
import org.eclipse.swt.graphics.Rectangle;
import org.eclipse.swt.layout.FormAttachment;
import org.eclipse.swt.layout.FormData;
import org.eclipse.swt.layout.FormLayout;
import org.eclipse.swt.widgets.Button;
import org.eclipse.swt.widgets.Composite;
import org.eclipse.swt.widgets.Label;
import org.eclipse.swt.widgets.Shell;
import org.eclipse.swt.widgets.Text;
* @author pgoetz
public class ErrorSnippet
public static void main(String[] args)
ErrorSnippet snippet = new ErrorSnippet();
public ErrorSnippet()
Display display = new Display();
final Shell shell = new Shell(display, SWT.SHELL_TRIM);
FastView fastview = new FastView(shell, SWT.NONE, "address",
new TestComposite(shell, SWT.NONE));
FormData formData;
formData = new FormData(SWT.DEFAULT,
fastview.computeSize(SWT.DEFAULT, SWT.DEFAULT).y);
formData.top = new FormAttachment(75);
formData.left = new FormAttachment(25);
formData.right = new FormAttachment(75);
fastview.setLayoutData(formData);
shell.setLayout(new FormLayout());
shell.open();
while(!shell.isDisposed())
while(!display.readAndDispatch())
display.sleep();
display.dispose();
class FastView extends Composite
private Label title;
private Button button;
private Composite content;
private boolean isExtended = false;
public FastView(Composite parent, int style, String title,
Composite content)
super(parent, style);
this.content = content;
initWidgets(title);
layoutWidgets();
pack();
private void changeFastViewState()
if(isExtended)
button.setText("open");
else
button.setText("close");
isExtended = !isExtended;
content.setVisible(isExtended);
content.setFocus();
private void initWidgets(String titleText)
title = new Label(this, SWT.NONE);
button = new Button(this, SWT.FLAT);
content.setVisible(false);
setBackground(getDisplay().getSystemColor(SWT.COLOR_WHITE));
addControlListener(new ControlAdapter()
public void controlResized(ControlEvent e)
layoutContents();
private void layoutContents()
int x = getBounds().x;
int y = getBounds().y - content.getBounds().height;
int width = getBounds().width;
int height = content.getBounds().height;
Rectangle bounds = new Rectangle(x, y, width, height);
content.setBounds(bounds);
title.setText(titleText);
button.addSelectionListener(new SelectionAdapter()
public void widgetSelected(SelectionEvent e)
changeFastViewState();
private void layoutWidgets()
FormLayout layout = new FormLayout();
FormData formData;
setLayout(layout);
formData = new FormData();
formData.top = new FormAttachment(button, 0, SWT.CENTER);
formData.left = new FormAttachment(5);
formData.right = new FormAttachment(button);
title.setLayoutData(formData);
formData.top = new FormAttachment(0);
formData.left = new FormAttachment(50,
-button.computeSize(SWT.DEFAULT, SWT.DEFAULT).x / 2);
button.setLayoutData(formData);
class TestComposite extends Composite
private Label lblFirstName;
private Label lblLastName;
private Text txtFirstName;
private Text txtLastName;
public TestComposite(Composite parent, int style)
initWidgets();
layoutWidgets();
fillWidgets("Peter", "Goetz");
pack();
private void initWidgets()
lblFirstName = new Label(this, SWT.NONE);
lblLastName = new Label(this, SWT.NONE);
txtFirstName = new Text(this, SWT.BORDER);
txtLastName = new Text(this, SWT.BORDER);
lblFirstName.setText("firstname:");
lblLastName.setText("lastname:");
FormData formData;
int broadMargin = 5;
layout.marginWidth = layout.marginHeight = 10;
this.setLayout(layout);
// first row
formData = new FormData(100, SWT.DEFAULT);
formData.left = new FormAttachment(0);
formData.right = new FormAttachment(50);
lblFirstName.setLayoutData(formData);
formData.top = new FormAttachment(lblFirstName, 0, SWT.CENTER);
formData.left = new FormAttachment(lblFirstName);
formData.right = new FormAttachment(100);
lblLastName.setLayoutData(formData);
formData.top = new FormAttachment(lblFirstName);
formData.left = new FormAttachment(lblFirstName, 0, SWT.LEFT);
formData.right = new FormAttachment(lblFirstName, 0,
SWT.RIGHT);
txtFirstName.setLayoutData(formData);
formData.top = new FormAttachment(lblLastName);
formData.left = new FormAttachment(lblLastName, 0, SWT.LEFT);
formData.right = new FormAttachment(lblLastName, 0, SWT.RIGHT);
txtLastName.setLayoutData(formData);
private void fillWidgets(String firstname, String lastname)
txtFirstName.setText(firstname);
txtLastName.setText(lastname);
Re: setLocation Problem when resizing shell [message #450843 is a reply to message #450651] |
Fri, 18 February 2005 10:08   |
Ok, there's too much code for me to fix right now in the late throws of M5.
The problem is that you are using both setBounds() and layout to position
the control. The job of layout is to position the children of a composite
when the composite is resized. That is happening with one of your panels.
If you use resize to resize a child that is also being resized by a layout,
the next time that the composite is resized, the layout comes along and
repositions the child. The key point here is that layout does not take into
account the current position of a control, it just applies the algorithm.
So, either position the new panel using layout or position the children of
the shared parent composite with setBounds() and don't use a layout. Hope
this helps.
news:cuvout$4lh$1@www.eclipse.org...
> Hi Steve,
> Composite.
> Peter
> ===== CODE =====
> import org.eclipse.swt.widgets.Display;
> * @author pgoetz
> FormData formData;
> shell.open();
> display.sleep();
> display.dispose();
> Composite content)
> initWidgets(title);
> layoutWidgets();
> pack();
> if(isExtended)
> else
> content.setFocus();
> layoutContents();
height);
> FormData formData;
> setLayout(layout);
> initWidgets();
> layoutWidgets();
> pack();
> FormData formData;
> // first row
SWT.CENTER);
SWT.LEFT);
> SWT.RIGHT);
SWT.RIGHT);
Re: setLocation Problem when resizing shell [message #451006 is a reply to message #450843] |
Mon, 21 February 2005 03:28  |
> this helps.
Hi Steve,
thank you very much, that is the explanation I was looking for. So I can
fix the code myself by not layouting widgets via a Layout when I want to
position them myself.
I'm looking forward to eclipse 3.1, so I don't want to hold you up in
implementing... ;)
Thank you!!
Peter
Current Time: Sun Jul 20 14:08:36 EDT 2025
Powered by FUDForum. Page generated in 0.04952 seconds
