Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Help: implementing IDocHostUIHandler and GetExternal method
Help: implementing IDocHostUIHandler and GetExternal method [message #450393] Fri, 11 February 2005 09:41 Go to next message
Originally posted by: NoSpam.NoSpam.Com
Below is a code snippet in which I tried to implement IDocHostUIHandler.
Through implementing this interface it should be possible to call external
code from within JavaScript that run in the WebBrowser ActiveX component (by
calling window.external.doSomething). IDocHostUIHandlerImpl has a method
GetExternal. This method should return an IDispatch interface. I created a
sample IDispatch implementation but when I return my app crashes...... Any
ideas what could be wrong? Any help is welcome.
class IDocHostUIHandlerImpl {
private COMObject iDocHostUIHandler;
private int refCount = 0;
public IDocHostUIHandlerImpl() {
createCOMInterfaces();
public int getAddress() {
int address = iDocHostUIHandler.getAddress();
return address;
private void createCOMInterfaces() {
iDocHostUIHandler = new COMObject(new int[]{2, 0, 0, 4, 1, 5, 0, 0, 1, 1, 1,
3, 3, 2, 2, 1, 3, 2}){
public int method0(int[] args) {return QueryInterface(args[0], args[1]);}
public int method1(int[] args) {return AddRef();}
public int method2(int[] args) {return Release();}
// method3 (not implemented) - ShowContextMenu
// method4 (not implemented) - GetHostInfo
// method5 (not implemented) - ShowUI
// method6 (not implemented) - HideUI
// method7 (not implemented) - UpdateUI
// method8 (not implemented) - EnableModeless
// method9 (not implemented) - OnDocWindowActivate
// method10 (not implemented) - OnFrameWindowActivate
// method11 (not implemented) - ResizeBorder
// method12 (not implemented) - TranslateAccelerator
// method13 (not implemented) - GetOptionKeyPath
// method14 (not implemented) - GetDropTarget
public int method15(int[] args) { return GetExternal(args[0]); }
// method16 (not implemented) - TranslateUrl
// method17 (not implemented) - FilterDataObject
private int GetExternal(int ppDispatch) {
Logger.log(LoggerSelectors.WEB, (short) 2, "GetExternal!");
EventDispatch ed = new EventDispatch(0);
COM.MoveMemory(ppDispatch, new int[] {ed.getAddress()}, 4);
return COM.S_OK;
Re: implementing IDocHostUIHandler and GetExternal method [message #450425 is a reply to message #450393] Fri, 11 February 2005 13:40 Go to previous message
I think I solved my problem, changing the implementation for GetExternal
return COM.S_OK;
to:
IDispatch iDispatch = new IDispatch(ed.getbAddress());
iDispatch.AddRef();
COM.MoveMemory(ppDispatch, new int[] {iDispatch.getAddress()}, 4);
return COM.S_OK;
Don't understand entirely why this works, any ideas?
Gr,
Frank
"FrankVanMoorsel" <NoSpam@NoSpam.Com> wrote in message
news:cuig6q$8dn$1@www.eclipse.org...
> (by calling window.external.doSomething). IDocHostUIHandlerImpl has a
> method GetExternal. This method should return an IDispatch interface. I
> created a sample IDispatch implementation but when I return my app
> crashes...... Any ideas what could be wrong? Any help is welcome.
> return address;
> 1, 3, 3, 2, 2, 1, 3, 2}){
> return COM.S_OK;
Previous Topic:CheckBoxTreeViewer - help needed!
Next Topic:When i redraw a canvas, it clears the old stuff
Current Time: Sat Jul 19 05:51:51 EDT 2025
Powered by FUDForum. Page generated in 0.02985 seconds
