Home » Eclipse Projects » Standard Widget Toolkit (SWT) » getItems() only works for TreeItems that are expanded
getItems() only works for TreeItems that are expanded [message #449917] Mon, 31 January 2005 09:48 Go to next message
Can you explain the following? I don't see why TreeItems need to be
expanded in order for getItems() to return something useful.
// the following line only works if viewer.getTree().getItems()[0] is
expanded
TreeItem[] testing = viewer.getTree().getItems()[0].getItems();
viewer.setContentProvider(new ViewContentProvider(file));
// if I do viewer.expandAll(); here then below works fine, but not if I use
viewer.expandToLevel(Object, int)
Re: getItems() only works for TreeItems that are expanded [message #449929 is a reply to message #449917] Mon, 31 January 2005 11:51 Go to previous message
They don't. Perhaps this is a bug/feature in JFace? Try eclipse.platform.
Someone may be able to help you there.
"Devin Steffler" <devin_steffler@ca.ibm.com> wrote in message
news:ctlgfo$5si$1@www.eclipse.org...
> expanded
use
Previous Topic:Can I set the size of a FileDialog
Next Topic:disable tree expanded
Current Time: Sat Jul 19 09:51:01 EDT 2025
Powered by FUDForum. Page generated in 0.05542 seconds
