Home » Eclipse Projects » Standard Widget Toolkit (SWT) » javaw.exe keeps running in Windows
javaw.exe keeps running in Windows [message #449332] Fri, 21 January 2005 16:34 Go to next message
In Task Manager, you see an instance of javaw.exe (Windows' jvm launcher)
appear when you start eclipse. We see another instance appear when we run
our JFace app (either under eclipse or standalone).
After exiting our app, its javaw.exe does not disappear from Task Manager.
They pile up, one for each run. Eventually, system problems begin to
occur. Plus, when you try to shut down windows, you get all of these
instances not responding to windows.
It sure sounds like a memory leak, or a failure to dispose a system
resource, such as a non standard color.
But, we've scoured our app and commented out all such Color creations. We
don't do anything with fonts, so we're out of ideas as to what would cause
this problem. We have verified that this problem does not occur with
simplistic apps.
Anyone have any ideas on...?
1. What our problem is
2. Strategies for troubleshooting
Re: javaw.exe keeps running in Windows [message #449361 is a reply to message #449332] Mon, 24 January 2005 12:10 Go to previous messageGo to next message
The java VM will not keep running if you fail to dispose an SWT resource.
Are you exiting from your event loop?
"Bill Ewing" <ewing@irori.com> wrote in message
news:csrshl$asq$1@www.eclipse.org...
> simplistic apps.
Re: javaw.exe keeps running in Windows [message #449462 is a reply to message #449361] Mon, 24 January 2005 17:26 Go to previous messageGo to next message
>> simplistic apps.
Thank you for taking the time to post, Steve. The information in your
response is valuable to us.
We are using JFace. Specifically, we have an ApplicationWindow class that
contains a main method. So, I believe handling the event loop is
automatically done by ApplicationWindow-- it's buried and not available
for us to see (until we figure out how to attach source and JavaDoc to
libs we use).
What would you suggest we look at next?
I was in the process of commenting out chunks of the program, piece by
piece until the zombie javaw.exe no longer hangs around in Task Manager.
But now, the knowledge that failure to dispose() would not cause this
problem makes us wonder just what sort of problem we are chasing.
Our main method looks like the following. It was auto-generated by the
GUI builder available from swt-designer.com.
public static void main(String args[]) {
try {
MainWindow window = new MainWindow();
window.setBlockOnOpen(true);
window.open();
} catch (Exception e) {
e.printStackTrace();
Re: javaw.exe keeps running in Windows [message #449463 is a reply to message #449462] Mon, 24 January 2005 19:32 Go to previous messageGo to next message
>>> simplistic apps.
> libs we use).
> try {
> window.open();
OK, it looks like we were not dispose'ing Display. Thank you Bahram, for
suggesting that earlier.
The reason that this stumped us is that all of the code is autogenerated
by a GUI designer tool that we assumed worked. We've contacted the
manufacturer (who sent us here).
Our new main method now looks like below.
try {
Display.getCurrent().dispose();
Re: javaw.exe keeps running in Windows [message #449505 is a reply to message #449463] Tue, 25 January 2005 10:08 Go to previous messageGo to next message
Ok, it was a combination of the GUI builder and JFace. I just want to
confirm with you that SWT doesn't do anything special to keep running.
news:ct442e$t3m$1@www.eclipse.org...
resource.
launcher)
run
Manager.
We
cause
> >>> simplistic apps.
that
> > libs we use).
> > try {
> > window.open();
> try {
Re: javaw.exe keeps running in Windows [message #449588 is a reply to message #449505] Wed, 26 January 2005 13:20 Go to previous message
Hi Steve. Yes, confirmed. Our problem was a combination of JFace and a
GUI designer which is now fixed. To summarize, main method was missing
"Display.getCurrent().dispose()" below:
try {
// (MainWindow is an ApplicationWindow)
> resource.
> launcher)
> run
> Manager.
> We
> cause
>> >>> simplistic apps.
> that
>> > libs we use).
>> > try {
>> > window.open();
>> try {
Previous Topic:More than on curser and selections
Next Topic:Outlook Address Book
Current Time: Sat Jul 19 21:05:20 EDT 2025
Powered by FUDForum. Page generated in 0.03323 seconds
