Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Browser widget: Popup Blocking with VisibilityWindowListener or OpenWindowListener?
Browser widget: Popup Blocking with VisibilityWindowListener or OpenWindowListener? [message #449360] Mon, 24 January 2005 12:09 Go to next message
Hi (Chris),
referring to Snippet 173:
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.swt.sni ppets/src/org/eclipse/swt/snippets/Snippet173.java#dirlist
the popup is blocked inside the VisibilityWindowListener#show() Method.
But is'nt it possible to block the popup in an earlier event:
OpenWindowListener#open() also tells about the kind of webpage
(adressbar, menubar, ...)?
Any reasons why one should block the popup inside the
VisibilityWindowListener and not earlier in the
OpenWindowListener?
Ben
Re: Browser widget: Popup Blocking with VisibilityWindowListener or OpenWindowListener? [message #449546 is a reply to message #449360] Wed, 26 January 2005 04:40 Go to previous messageGo to next message
Hm no comment yet. I am then going to open a bug report to update
Snippet 173. I think
handling the popup inside the OpenWindowListener has the big advantage
that is not
required to dispose any widget.
Ben
> Hi (Chris),
> OpenWindowListener?
> Regards,
> Ben
Re: Browser widget: Popup Blocking with VisibilityWindowListener or OpenWindowListener? [message #449593 is a reply to message #449546] Wed, 26 January 2005 15:58 Go to previous messageGo to next message
Hi Ben,
There's a reason, details below.
No. The fields addressbar, menubar... are only set from the
VisiblityWindowListener.show notification.
Why? Some native browsers request a new window first, and - only after that
new browser instance is set - inform that new browser instance on the styles
it should use before getting visible. That's why you don't get that info in
the OpenWindowListener.open notification - it's not always known at that
stage.
Chris
Re: Browser widget: Popup Blocking with VisibilityWindowListener or OpenWindowListener? [message #449595 is a reply to message #449593] Wed, 26 January 2005 16:33 Go to previous messageGo to next message
Christophe Cornu wrote:
>Hi Ben,
>stage.
Hm, but its working here on Windows. Is the late notification of styles
a problem
on Linux / Mac?
The whole popup problem would be no problem at all, if somehow one could
distinguish
between a new browser window being opened by a "target=_blank" link or
JavaScript.
Would it somehow be possible to store this information inside the
OpenWindowListener?
Ben
>Chris
Re: Browser widget: Popup Blocking with VisibilityWindowListener or OpenWindowListener? [message #449597 is a reply to message #449595] Wed, 26 January 2005 17:21 Go to previous messageGo to next message
> Hm, but its working here on Windows. Is the late notification of styles a
> problem
> on Linux / Mac?
Maybe we are not talking exactly about the same thing. The snippet below
will always display "false" for the values of addressBar and menuBar. Even
on Windows. Particularly on Windows since Internet Explorer fires that
information to the new native instance only after it has been created - and
not when initially firing the window open request (what Microsoft calls the
NewWindow2 event or even the most recent NewWindow3). The javadoc for the
OpenWindowListener.open mentions that only WindowEvent.browser and
WindowEvent.widget are set.
import org.eclipse.swt.*;
import org.eclipse.swt.widgets.*;
import org.eclipse.swt.layout.*;
import org.eclipse.swt.browser.*;
public class PRBrowser {
Display display = new Display();
Shell shell = new Shell(display);
shell.setText("PRBrowser");
shell.setLayout(new FillLayout());
Browser browser = new Browser(shell, SWT.NONE);
browser.addOpenWindowListener(new OpenWindowListener() {
public void open(WindowEvent event) {
System.out.println("These fields are never set from
OpenWindowListener.open (only in VisibilityWindow.show:");
System.out.println("addressBar "+event.addressBar);
System.out.println("menuBar "+event.menuBar);
browser.setUrl("http://www.eclipse.org");
shell.open();
while (!shell.isDisposed()) {
try {
if (!display.readAndDispatch())
display.sleep();
} catch (Exception e) {}
> OpenWindowListener?
If/when there is a way to get that information on the different platforms,
this could be considered. If anyone knows a way that you think we may have
overlooked, please open a bug report or talk about it on the SWT developer's
mailing list.
Chris
Re: Browser widget: Popup Blocking with VisibilityWindowListener or OpenWindowListener? [message #449652 is a reply to message #449597] Thu, 27 January 2005 09:32 Go to previous messageGo to next message
Ah ok I am now understanding the problem. Those fields are always false
in the OpenWindowListener, regardless
if the Window is a popup or not.
Anyways, being able to block any javascript-window will allow to get rid
of all popups. Some time ago, I opened
a bug report on the issue: "Distinguish between popup and target = blank
link"
https://bugs.eclipse.org/bugs/show_bug.cgi?id=63233
This would be a killer feature that would allow to avoid the most
annoying problem of IE: popups
Ben
>>problem
>>on Linux / Mac?
> public static void main(String[] args) {
> shell.open();
> try {
> display.sleep();
>>OpenWindowListener?
>mailing list.
>Chris
Re: Browser widget: Popup Blocking with VisibilityWindowListener or OpenWindowListener? [message #449653 is a reply to message #449652] Thu, 27 January 2005 09:36 Go to previous message
Here are two other bug reports that would also help in the fight vs popups:
49696 [browser] Mouse event listeners does not work in SWT Browser Widget
https://bugs.eclipse.org/bugs/show_bug.cgi?id=49696
55351 [browser] link listener
https://bugs.eclipse.org/bugs/show_bug.cgi?id=55351
Ben
Previous Topic:Redrawing pixels to the screen in SWT-simple graphics prob
Next Topic:SWT-WebBrowser Control: PostData problem
Current Time: Sat Jul 19 22:41:58 EDT 2025
Powered by FUDForum. Page generated in 0.04136 seconds
