Home » Eclipse Projects » Standard Widget Toolkit (SWT) » javaw.exe keeps running in Windows
javaw.exe keeps running in Windows [message #449327] Fri, 21 January 2005 14:46 Go to next message
After we run our app (under eclipse or standalone), an instance of
javaw.exe (Windows' virtual machince launcher) remains in the Task Manager.
After coding and debugging for an hour, there's lots of them. Eventually,
system problems occur.
This problem is very noticeable when we cannot delete or rename an
application-related file because it is "in use." Using Task Manager to
kill off the javaw.exe remedies this problem. However, one of the
javaw.exe's was used to launch eclipse, so killing it immediately takes
down eclipse (with no file saves).
Our current hypothesis is that we are failing to dispose() of resources
(probably a nonstandard Color object obtained from a GC).
Does this sound like the right theory and does anybody have a similar
experience they'd like to share?
Re: javaw.exe keeps running in Windows [message #449330 is a reply to message #449327] Fri, 21 January 2005 15:53 Go to previous messageGo to next message
I think it happens when you do not dispose display object.
Bahram
"Bill Ewing" <ewing@irori.com> wrote in message
news:csrm5u$sp1$1@www.eclipse.org...
Manager.
Re: javaw.exe keeps running in Windows [message #449333 is a reply to message #449330] Fri, 21 January 2005 16:54 Go to previous message
Bahram wrote:
> Bahram
> Manager.
Hi Bahram. Excellent idea, thank you for taking the time to share it.
We went through our code and checked every use of Display, but still have
the problem.
((On this subject, would everyone agree that in general, once your app is
up and running, it is a good idea to use the static method
"Display.getCurrent()" when you need a reference to the display?))
Previous Topic:Browser widget on Linux and native crashes
Next Topic:What's making my dropdown menu popup
Current Time: Sat Jul 19 16:31:55 EDT 2025
Powered by FUDForum. Page generated in 0.04743 seconds
