java.lang.IllegalArgumentException: Argument not valid [message #448992] |
Mon, 17 January 2005 10:01  |
Originally posted by: jimchiu2000.yahoo.com
I got the follow error when I use tableViewer
/* This is mainUI code */
public void createContent(){.....................
adultIncluded.setTicketNature("Adult ");
adultIncluded.setItem("Cable Car Round");
adultIncluded.setUnit("2");
adultIncluded.setPrice("100");
adultIncluded.setSubTotal("0");
System.out.println(adultIncluded.getTicketNature()+","+adultIncluded.getItem()+
","+adultIncluded.getUnit()+","+adultIncluded.getUnitPrice()+ ","+adultIncluded.getSubTotal());
System.out.println("adultIncluded:"+adultIncluded);
tableViewer.add(adultIncluded);
Initally, the mainUI.java can run this tableviewer properly. however, when
I press the button of mainUI.java to open this window second time and then
press the button again... and then a error occurs.
ie.
final Button confirmButton = new Button(this, SWT.NONE);
confirmButton.addSelectionListener(new SelectionAdapter() {
public void widgetSelected(SelectionEvent e) {
close();
new MainUI();
at org.eclipse.swt.SWT.error(SWT.java:2677)
at org.eclipse.swt.SWT.error(SWT.java:2616)
at org.eclipse.swt.SWT.error(SWT.java:2587)
at org.eclipse.swt.widgets.Widget.error(Widget.java:381)
at org.eclipse.swt.widgets.TableItem.setImage(TableItem.java:90 9)
at
org.eclipse.jface.viewers.TableViewer.doUpdateItem(TableView er.java:221)
at
org.eclipse.jface.viewers.StructuredViewer$UpdateItemSafeRun nable.run(StructuredViewer.java:128)
at
org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java:616)
at org.eclipse.core.runtime.Platform.run(Platform.java:747)
at
org.eclipse.jface.viewers.StructuredViewer.updateItem(Struct uredViewer.java:1374)
at org.eclipse.jface.viewers.TableViewer.add(TableViewer.java:1 16)
at org.eclipse.jface.viewers.TableViewer.add(TableViewer.java:1 34)
at MainUI.createContents(MainUI.java:762)
at MainUI.<init>(MainUI.java:128)
at MainUI.<init>(MainUI.java:98)
at MainUI$17.widgetSelected(MainUI.java:746)
at
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:89)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :82)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:796)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:2772)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2431)
at MainUI.<init>(MainUI.java:101)
at
at MainUI.main(MainUI.java:87)
Re: java.lang.IllegalArgumentException: Argument not valid [message #449553 is a reply to message #448992] |
Wed, 26 January 2005 08:18  |
From your stack trace it looks like your provider is answering a disposed
Image as the image for a TableItem.
Grant
"Jim Chiu" <jimchiu2000@yahoo.com> wrote in message
news:csgk05$ain$1@www.eclipse.org...
ed.getSubTotal());
> ie.
> close();
> new MainUI();
> at
> at
> at
:616)
> at
1374)
> at
> at
FUDForum. Page generated in 0.03625 seconds
