Home » Eclipse Projects » Standard Widget Toolkit (SWT) » java.lang.UnsatisfiedLinkError: no swt-win32-3063 in java.library.path
java.lang.UnsatisfiedLinkError: no swt-win32-3063 in java.library.path [message #448660] Wed, 12 January 2005 16:49 Go to next message
Originally posted by: sambraun.nospamgmx.net
Hello guys
I've a strange problem.
Today I've wanted to compile a swt sample.
First eclipse said that the imports org.eclipse.swt.widgets.Display,
org.eclipse.swt.widgets.Shell couldn't be found.
So I went Window->Preferences->Installed JREs->Selected the only entry and
added an external jar called swt.jar from my
C:\Programme\eclipse\plugins\org.eclipse.swt.win32_3.0.1\ws\ win32 directory.
Then I've tried it again but this error message occured:
at java.lang.ClassLoader.loadLibrary(ClassLoader.java:1517)
at java.lang.Runtime.loadLibrary0(Runtime.java:788)
at java.lang.System.loadLibrary(System.java:834)
at org.eclipse.swt.internal.Library.loadLibrary(Library.java:10 0)
at org.eclipse.swt.internal.win32.OS.<clinit>(OS.java:18)
at org.eclipse.swt.graphics.Device.init(Device.java:564)
at org.eclipse.swt.widgets.Display.init(Display.java:1780)
at org.eclipse.swt.graphics.Device.<init>(Device.java:100)
at org.eclipse.swt.widgets.Display.<init>(Display.java:355)
at org.eclipse.swt.widgets.Display.<init>(Display.java:351)
at core.AppDialog.<init>(AppDialog.java:30)
at core.Main.main(Main.java:17)
Exception in thread "main"
So I searched the net and found that I have to add the VM-Argument under
run...:
-Djava.library.path=C:\Programme\eclipse\plugins\org.eclipse .swt.win32_3.0.1\os\win32\x86
so I did this but the errors still occured. The path is correct because I
did a copy paste from the explorer.
Then I tried to copy this dll's in the C:\Windows\system32 but also then the
error still occurs.
Any ideas?
Thanks in advance
Sam
Re: java.lang.UnsatisfiedLinkError: no swt-win32-3063 in java.library.path [message #448663 is a reply to message #448660] Wed, 12 January 2005 18:16 Go to previous messageGo to next message
Originally posted by: nickthat.yahoo.com
The way I normally work is to have the PATH environment variable set to
pick up the SWT dll. e.g. in my case
PATH=C:\eclipse\plugins\org.eclipse.swt.win32_3.0.0\os\win32 \x86 ....etc
Make sure you restart Eclipse after you change the PATH.
Samuel Braun wrote:
> Hello guys
> C:Programmeeclipsepluginsorg.eclipse.swt.win32_3.0.1wswin32 directory.
> run...:
-Djava.library.path=C:Programmeeclipsepluginsorg.eclipse.swt .win32_3.0.1oswin32x86
> Then I tried to copy this dll's in the C:Windowssystem32 but also then the
> error still occurs.
> Any ideas?
> Thanks in advance
> Sam
Re: java.lang.UnsatisfiedLinkError: no swt-win32-3063 in java.library.path [message #448686 is a reply to message #448663] Thu, 13 January 2005 01:19 Go to previous messageGo to next message
Hello Nick
Thanks for your answer
Doesn't work on my system. It's really strange...
Greetings
Samuel
"Nick Thatcher" <nickthat@yahoo.com> schrieb im Newsbeitrag
news:cs4b50$o4f$1@www.eclipse.org...
> Samuel Braun wrote:
>> Hello guys
>> and added an external jar called swt.jar from my
>> run...:
>> the error still occurs.
>> Any ideas?
>> Thanks in advance
>> Sam
Solved: java.lang.UnsatisfiedLinkError: no swt-win32-3063 in java.library.path [message #448698 is a reply to message #448686] Thu, 13 January 2005 09:32 Go to previous message
Hi guys
I found the solution myself :-)
The way I added the swt.jar was wrong, if I added it over
Project->Properties->Java Build Path->Libraries->Add Variable->Eclipse
Home->Extend, then I can give the VM-Argument mentioned in my previous
posts.
Greetings Sam
"Samuel Braun" <sambraun@nospamgmx.net> schrieb im Newsbeitrag
news:cs53to$6r9$1@www.eclipse.org...
> Hello Nick
> Greetings
> Samuel
>> Samuel Braun wrote:
>>> Hello guys
>>> run...:
>>> I did a copy paste from the explorer.
>>> Any ideas?
>>> Thanks in advance
>>> Sam
Previous Topic:SWT Table margin
Next Topic:table accepting all control as cell item
Current Time: Sat Jul 19 09:15:38 EDT 2025
Powered by FUDForum. Page generated in 0.04678 seconds
