Home » Eclipse Projects » Standard Widget Toolkit (SWT) » DND: can't set up DragSource as in article example
DND: can't set up DragSource as in article example [message #448608] |
Tue, 11 January 2005 17:52  |
Originally posted by: mmaercker.tripper-bullet.com
Hi all,
I am trying to implement drag and drop. To familiarize myself with the API I
copied the DragSource code from the DND in SWT article. I wound up with the,
as far as I can tell, smallest possible DND program (see below). When run,
the program shows the label including text. Whenever I try to drag the text,
though, the "no dragging allowed" cursor (circle with diagonal line) is
immediately and continuously shown. So, to me, it looks like the minimal
example does not work. What could I be doing wrong?
Any help greatly appreciated,
Martin Maercker
import org.eclipse.swt.SWT;
import org.eclipse.swt.dnd.*;
import org.eclipse.swt.widgets.*;
public class MainMethClass {
public static void main(String [] args)
Display display = new Display();
Shell shell = new Shell(display);
shell.setText("test");
shell.setLayout(new FillLayout());
// Enable a label as a Drag Source
final Label dragLabel = new Label(shell, SWT.BORDER);
dragLabel.setText("text to be transferred");
// Allow data to be copied or moved from the drag source
int operations = DND.DROP_MOVE | DND.DROP_COPY;
DragSource source = new DragSource(dragLabel, operations);
// Provide data in Text format
Transfer[] types = new Transfer[] {TextTransfer.getInstance()};
source.setTransfer(types);
source.addDragListener(new DragSourceListener() {
public void dragStart(DragSourceEvent event) {
// Only start the drag if there is actually text in the
// label - this text will be what is dropped on the target.
if (dragLabel.getText().length() == 0) {
event.doit = false;
public void dragSetData(DragSourceEvent event) {
// Provide the data of the requested type.
if
(TextTransfer.getInstance().isSupportedType(event.dataType)) {
event.data = dragLabel.getText();
public void dragFinished(DragSourceEvent event) {
// If a move operation has been performed, remove the data
// from the source
if (event.detail == DND.DROP_MOVE)
dragLabel.setText("");
shell.open();
shell.setBounds(100,100,400,400);
while(!shell.isDisposed())
if(!display.readAndDispatch())
display.sleep();
display.dispose();
Re: can't set up DragSource as in article example [message #448617 is a reply to message #448608] |
Wed, 12 January 2005 06:59   |
You have implemented a drag source but you do not have a drop target.
Something that supplies that data for a drag is not automatically a drop
target for the same data. See the next part of the article.
"Martin Maercker" <mmaercker@tripper-bullet.com> wrote in message
news:cs1l6t$roh$1@www.eclipse.org...
> Hi all,
> I
> the,
> text,
> Martin Maercker
> event.doit = false;
> if
> // from the source
> shell.open();
> display.sleep();
> display.dispose();
Re: DND problem solved (for the most part ;) [message #448618 is a reply to message #448608] |
Wed, 12 January 2005 07:19   |
My example did not include a properly configured drop target. I've got dnd
within one application working now.
I was expecting other windows, at least those in the Eclipse IDE, to offer
themselves as drop targets, at least for things like TextTransfer. How do I
get a cross-application drag and drop set up?
Martin Maercker
"Martin Maercker" <mmaercker@tripper-bullet.com> schrieb im Newsbeitrag
> Hi all,
I
the,
text,
> Martin Maercker
target.
> event.doit = false;
> if
> // from the source
> shell.open();
> display.sleep();
> display.dispose();
Re: can't set up DragSource as in article example [message #448620 is a reply to message #448617] |
Wed, 12 January 2005 07:30   |
Hi Veronika,
thanks for your input. I had originally expected other applications to be
the target. I've now got it running within my own application. I'm still
interested in cross-application possibilities, though.
The other mail in this thread (Re: DND problem solved) was sent before your
reply was downloaded.
Martin
I had assumed as much
"Veronika Irvine" <veronika_irvine@oti.com> schrieb im Newsbeitrag
news:cs33gf$rif$1@www.eclipse.org...
> > Hi all,
API
> > I
> > the,
run,
> > text,
> > Martin Maercker
target.
> > event.doit = false;
> > if
> > // from the source
> > shell.open();
> > display.sleep();
> > display.dispose();
Re: DND problem solved (for the most part ;) [message #448622 is a reply to message #448618] |
Wed, 12 January 2005 08:54   |
Just run your application twice and you will see that you can drag from one
application to another. You can also drag your text into another
application like Word. Eclipse editors are not set up as drop targets for
text.
news:cs34h5$vlg$1@www.eclipse.org...
> I
> Martin Maercker
>> Hi all,
>> API
> I
> the,
>> run,
> text,
>> Martin Maercker
> target.
>> event.doit = false;
>> if
>> // from the source
>> shell.open();
>> display.sleep();
>> display.dispose();
Re: DND problem solved (for the most part ;) [message #448625 is a reply to message #448622] |
Wed, 12 January 2005 09:54  |
Thanks for the hint! I hadn't thought to try Word, thinking the Eclipse text
editors must be "closer" somehow... but you are right, it works like a
charm.
Martin
news:cs3a6s$meq$2@www.eclipse.org...
one
> text.
dnd
offer
do
> > I
> > Thanks,
> > Martin Maercker
> >> Hi all,
> >> API
> > I
> > the,
> >> run,
> > text,
minimal
> >> Martin Maercker
> > target.
> >> event.doit = false;
> >> if
data
> >> // from the source
> >> shell.open();
> >> display.sleep();
> >> display.dispose();
Current Time: Sat Jul 19 20:08:21 EDT 2025
Powered by FUDForum. Page generated in 0.04987 seconds
