Home » Eclipse Projects » Standard Widget Toolkit (SWT) » DragAndDrop Source problem
DragAndDrop Source problem [message #448611] Tue, 11 January 2005 19:44 Go to next message
Hi there,
I am implementing DND on a set of Labels the drop tager
new DropTargetListener() {
public void dragEnter(DropTargetEvent arg0) {
Label item = (Label) ((DropTarget) arg0.getSource())
.getControl();
if (((TableBean) item.getData()).getTableName().equals(
((TableBean) selItem.getData()).getTableName()))
arg0.detail = DND.DROP_NONE;
else {
arg0.detail = DND.DROP_LINK;
prevDropTargetBg = ((Label) arg0.getSource())
.getBackground();
((Label) arg0.getSource()).setBackground(display
.getSystemColor(SWT.COLOR_DARK_MAGENTA));
public void dragLeave(DropTargetEvent arg0) {
((Label) arg0.widget).setBackground(prevDropTargetBg);
public void dragOperationChanged(DropTargetEvent arg0) {
// TODO Auto-generated method stub
public void dragOver(DropTargetEvent arg0) {
public void drop(DropTargetEvent arg0) {
if (selItem == null)
return;
String dt = (String) arg0.data;
Label item = (Label) arg0.widget;
item.setBackground(prevDropTargetBg);
int ttlTop = SWTUtils.getOffsetTop(item, tableCanvas);
int ttlLeft = SWTUtils.getOffsetLeft(item, tableCanvas);
if (item == null)
return;
qBean.addJoin(selTable, selItem, (TableBean) item
.getParent().getData(), item);
public void dropAccept(DropTargetEvent arg0) {
the line in dragEnter
.getControl();
returns the Label that the drag originated from, not the label that the
mouse is currently hovering over.
Is this the normal behavour of DnD, or is there something I am doing wrong.
I have triend this two ways, one where every label shares the same
DropTargetListener, and one where every label has it's own instance of a
DropTargetListener, both times using the code as specified above.
Both times the same result has occured.
What I am trying to get returned is the Control over which the mouse is
hovering. I will try with a MouseTrackListener, but I think, when in DnD
mode, the MouseTrackListener isn't fired.
Steve
Re: DragAndDrop Source problem [message #448619 is a reply to message #448611] Wed, 12 January 2005 07:25 Go to previous message
Calling
Label item = (Label) ((DropTarget) arg0.getSource()).getControl();
in dragEnter DOES return the widget that you are hovering over. I have
verified this by printing out the handles of the widgets in a simple
example. There is something else wrong with your example. Perhaps the
"selItem" value is being set incorrectly.
"Steve" <steve@crmsoftware.com.au> wrote in message
news:cs1ski$kff$1@www.eclipse.org...
> Hi there,
> .getControl();
> else {
> .getBackground();
> return;
> if (item == null)
> return;
> .getControl();
> wrong.
> Regards
> Steve
Previous Topic:ProgressBar SWT.INDETERMINATE
Next Topic:DnD - several transfer classes?
Current Time: Sun Jul 20 15:33:18 EDT 2025
Powered by FUDForum. Page generated in 0.03441 seconds
