Home » Eclipse Projects » Rich Client Platform (RCP) » NullPointerException when creating a simple RCP project
NullPointerException when creating a simple RCP project [message #447839] Mon, 17 April 2006 20:00 Go to next message
Originally posted by: betty06gao.yahoo.com
I got NullPointerException when trying to creating a RCP project.
Basically, I followed the RCP tutorial in Eclipse,
1. select New->project and choose Plug-in project from Plugin-in
developement categary
2. Fill the project name, click next
3. select "yes" for creating a rich client application in the bottom
section. Click next.
4. select the "RCP Mail Template" from the RCP template, Click Finish.
Then I got this NullPointException
I am wondering whether I didn't set up the RCP correctly.
What I did is:
1. downloaded eclipse-SDK-3.1.2-win32.zip and extracted the files in
c:\eclipse
2. downloaded eclipse-RCP-SDK-3.1.2-win32.zip and extracted the files in
c:\eclipseSDK\eclipse
3. Run the IDE.
4. I am not quite sure how to configure this RCP-SDK. What I did is:
got to Windows>Preferences>Plugin-Development>Target platform, and
configure the location
to be c:\eclipseSDK\eclipse. Is this correct?
The Exception in the log file is:
at
org.eclipse.pde.ui.templates.AbstractTemplateSection.generat eFiles(AbstractTemplateSection.java(Compiled
Code))
at
Code))
at
org.eclipse.pde.ui.templates.AbstractTemplateSection.generat eFiles(AbstractTemplateSection.java:278)
at
org.eclipse.pde.ui.templates.AbstractTemplateSection.execute (AbstractTemplateSection.java:348)
at
org.eclipse.pde.ui.templates.BaseOptionTemplateSection.execu te(BaseOptionTemplateSection.java:269)
at
org.eclipse.pde.ui.templates.AbstractNewPluginTemplateWizard .performFinish(AbstractNewPluginTemplateWizard.java:94)
at
org.eclipse.pde.internal.ui.wizards.plugin.NewProjectCreatio nOperation.execute(NewProjectCreationOperation.java:261)
at
org.eclipse.ui.actions.WorkspaceModifyOperation$1.run(Worksp aceModifyOperation.java:98)
at org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1721)
at
org.eclipse.ui.actions.WorkspaceModifyOperation.run(Workspac eModifyOperation.java:110)
at
org.eclipse.jface.operation.ModalContext.runInCurrentThread( ModalContext.java:346)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:291)
at org.eclipse.jface.wizard.WizardDialog.run(WizardDialog.java: 830)
at
org.eclipse.pde.internal.ui.wizards.plugin.NewPluginProjectW izard.performFinish(NewPluginProjectWizard.java:102)
at
org.eclipse.jface.wizard.WizardDialog.finishPressed(WizardDi alog.java:680)
at
org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDi alog.java:349)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.jav a:556)
at
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:90)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java (Compiled
Code))
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java(Inlined Compiled
Code))
at
org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va(Compiled
Code))
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java (Compiled
Code))
at org.eclipse.jface.window.Window.runEventLoop(Window.java(Com piled
Code))
at org.eclipse.jface.window.Window.open(Window.java:787)
at org.eclipse.ui.actions.NewProjectAction.run(NewProjectAction .java:114)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:996 )
at
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:538)
at
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:488)
at
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:400)
Code))
Code))
at
Code))
Code))
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a(Compiled
Code))
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1663)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:367)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:103)
at
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:226)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:376)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:163)
at
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:79)
at
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:41)
at java.lang.reflect.Method.invoke(Method.java:386)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:334 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:278)
at org.eclipse.core.launcher.Main.run(Main.java:973)
at org.eclipse.core.launcher.Main.main(Main.java:948)
Thank you very much for your help!
Betty
Re: NullPointerException when creating a simple RCP project [message #447939 is a reply to message #447839] Tue, 18 April 2006 07:52 Go to previous messageGo to next message
Betty,
It seems that your platform is missing the rcp templates.
Try to use last eclipse RC (3.2RC1)
Re: NullPointerException when creating a simple RCP project [message #448124 is a reply to message #447939] Tue, 18 April 2006 13:06 Go to previous messageGo to next message
Hi Pierre,
Thank you very much for your quick response. I downloaded
eclipse-SDK-3.2RC1-win32.zip and unzipped it in c:\eclipse. When I tried
to run the eclipse.exe, I got the following error. Do I need to install
anything else in c:\eclipse?
Thanks a lot!
!SESSION 2006-04-18 10:01:44.952
eclipse.buildId=I20060413-1718
java.fullversion=J2RE 1.4.1 IBM Windows 32 build cn1411-20040301a (JIT
enabled: jitc)
Command-line arguments: -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.osgi 4 0 2006-04-18 10:01:46.143
!MESSAGE An error occurred while automatically activating bundle
org.eclipse.core.runtime.compatibility (25).
!STACK 0
org.osgi.framework.BundleException: Exception in
org.eclipse.core.internal.plugins.CompatibilityActivator.sta rt() of bundle
org.eclipse.core.runtime.compatibility.
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:1014)
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:970)
at
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:317)
at
org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:256)
at
org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter .preFindLocalClass(EclipseLazyStarter.java:86)
at
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass(ClasspathManager.java:402)
at
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.fin dLocalClass(DefaultClassLoader.java:188)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(BundleLoader.java:339)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:391)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:352)
at
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:83)
at java.lang.ClassLoader.loadClass(ClassLoader.java:494)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.loadCl ass(BundleLoader.java:276)
at
org.eclipse.osgi.framework.internal.core.BundleHost.loadClas s(BundleHost.java:227)
at
org.eclipse.osgi.framework.internal.core.AbstractBundle.load Class(AbstractBundle.java:1245)
at
org.eclipse.core.internal.runtime.CompatibilityHelper.getPlu ginDescriptor(CompatibilityHelper.java:63)
at org.eclipse.core.runtime.Plugin.initializeDescriptor(Plugin. java:681)
at org.eclipse.core.runtime.Plugin.start(Plugin.java:667)
at
org.eclipse.core.internal.runtime.PlatformActivator.start(Pl atformActivator.java:39)
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl$2 .run(BundleContextImpl.java:995)
at java.security.AccessController.doPrivileged1(Native Method)
at java.security.AccessController.doPrivileged(AccessController .java:350)
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:989)
at
at
at
org.eclipse.osgi.framework.internal.core.AbstractBundle.resu me(AbstractBundle.java:329)
at
org.eclipse.osgi.framework.internal.core.Framework.resumeBun dle(Framework.java:1037)
at
org.eclipse.osgi.framework.internal.core.StartLevelManager.r esumeBundles(StartLevelManager.java:573)
at
org.eclipse.osgi.framework.internal.core.StartLevelManager.i ncFWSL(StartLevelManager.java:495)
at
org.eclipse.osgi.framework.internal.core.StartLevelManager.d oSetStartLevel(StartLevelManager.java:275)
at
org.eclipse.osgi.framework.internal.core.StartLevelManager.d ispatchEvent(StartLevelManager.java:455)
at
org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEve nt(EventManager.java:189)
at
org.eclipse.osgi.framework.eventmgr.EventManager$EventThread .run(EventManager.java:291)
Caused by: java.lang.NoClassDefFoundError: org/eclipse/core/runtime/Plugin
at java.lang.Class.getDeclaredMethods0(Native Method)
at java.lang.Class.privateGetDeclaredMethods(Class.java:1754)
at java.lang.Class.privateGetPublicMethods(Class.java:1782)
at java.lang.Class.privateGetPublicMethods(Class.java:1792)
at java.lang.Class.getMethod1(Class.java:1877)
at java.lang.Class.getMethod(Class.java:1057)
at
org.eclipse.core.internal.runtime.CompatibilityHelper.setPlu gin(CompatibilityHelper.java:48)
at
org.eclipse.core.internal.plugins.CompatibilityActivator.sta rt(CompatibilityActivator.java:23)
at
at
... 32 more
Root exception:
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
!ENTRY org.eclipse.core.runtime.compatibility 4 0 2006-04-18 10:01:46.313
!MESSAGE FrameworkEvent.ERROR
!STACK 0
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
... 10 more
Root exception:
at
at
at
at
at
at
at
at
at
at
at
at
at
at
!ENTRY org.eclipse.osgi 4 0 2006-04-18 10:01:46.394
!STACK 0
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at org.eclipse.ui.plugin.AbstractUIPlugin.start(AbstractUIPlugi n.java:585)
at org.eclipse.ui.internal.WorkbenchPlugin.start(WorkbenchPlugi n.java:724)
at
at
at
at
at
at
at
at
at
at
org.eclipse.osgi.framework.internal.core.SingleSourcePackage .loadClass(SingleSourcePackage.java:37)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:388)
at
at
at java.lang.ClassLoader.defineClass0(Native Method)
at java.lang.ClassLoader.defineClass(ClassLoader.java:757)
at
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.def ineClass(DefaultClassLoader.java:160)
at
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.defineC lass(ClasspathManager.java:491)
at
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findCla ssImpl(ClasspathManager.java:461)
at
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClassImpl(ClasspathManager.java:420)
at
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass(ClasspathManager.java:403)
at
at
at
at
at
at
at
at
org.eclipse.osgi.framework.internal.core.AbstractBundle.load BundleActivator(AbstractBundle.java:134)
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:966)
at
at
at
at
at
at
at
at
at
at
at
at
at
org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .createExecutableExtension(RegistryStrategyOSGI.java:147)
at
org.eclipse.core.internal.registry.ExtensionRegistry.createE xecutableExtension(ExtensionRegistry.java:759)
at
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:243)
at
org.eclipse.core.internal.registry.ConfigurationElementHandl e.createExecutableExtension(ConfigurationElementHandle.java: 51)
at
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:74)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:92)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:68)
at
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:169)
at
at
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
at
at
at
at
... 82 more
Root exception:
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
!ENTRY org.eclipse.osgi 4 0 2006-04-18 10:01:46.434
!STACK 0
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at org.eclipse.ui.internal.UIPlugin.start(UIPlugin.java:91)
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at org.eclipse.ui.internal.WorkbenchPlugin.start(WorkbenchPlugi n.java:741)
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
... 101 more
Root exception:
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
!ENTRY org.eclipse.osgi 4 0 2006-04-18 10:01:46.584
!STACK 0
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
Re: NullPointerException when creating a simple RCP project [message #448126 is a reply to message #448124] Tue, 18 April 2006 13:57 Go to previous message
Betty Gao wrote:
> Hi Pierre,
> Thanks a lot!
Was c:\eclipse empty before you unzipped anything?
Always install eclipse into an empty directory. But this might not be
your problem.
Also, you should probably be on at least java 1.4.2
Later,
PW
Previous Topic:"Help content" error
Next Topic:Size of RCP and Customer Feedback
Current Time: Sat Jul 19 19:56:11 EDT 2025
Powered by FUDForum. Page generated in 0.04327 seconds
