Home » Eclipse Projects » Standard Widget Toolkit (SWT) » To dispose or not to dispose
To dispose or not to dispose [message #447987] Wed, 22 December 2004 10:41 Go to next message
<br><font size=1 face="sans-serif">I have a scrolled composite and have done a setinput with a composite to scroll. When a certain selection event happens I create a new composite and set the input of the scrolled composite to that.</font>
<br>
<br><font size=1 face="sans-serif">Question is eclipse says that widgets created with a parent are disposed by the system when the parent is disposed. In my case the parent scrolled composite is not disposed and there could be a lot of selection events (circa 200) with say 20 widgets on each composite, does this mean there will be 4000 widgets hanging around until the scrolled composite is disposed.</font>
<br>
<br><font size=1 face="sans-serif">Will the scrolled composite dispose of the old input when a new setinput is done, is it safe for me to dispose of them or do I just leave them all hanging around until the scrolled composite is disposed when the view closes.</font>
<br>
<br>
Re: To dispose or not to dispose [message #448006 is a reply to message #447987] Thu, 23 December 2004 12:32 Go to previous messageGo to next message
Hi Phill,
In your scenario you could be looking at a lot of widgets hanging around,
because since they are all descendents of the ScrolledComposite, they will
not be auto-disposed until the ScrolledComposite is disposed. You may wish
to dispose() of a Composite once it loses its status as the
ScrolledComposite's current content, especially if you know that it will not
be needed again (ie.- you're not likely to use it again as an argument for
ScrolledComposite.setContent(...)). This should be safe to do.
Grant
_______________
<Phill_Perryman@Mitel.COM> wrote in message
news:cqc4jb$h4d$1@www.eclipse.org...
closes.
Re: To dispose or not to dispose [message #448022 is a reply to message #448006] Fri, 24 December 2004 06:31 Go to previous messageGo to next message
<br><font size=1 face="sans-serif">Thanks, I have added my own call to dispose after the set input. I have checked all the logs and could not find any errors about access to disposed widgets so it seems ok.</font>
<br>
<br><font size=1 face="sans-serif">Thanks for the help.</font>
Re: To dispose or not to dispose [message #448145 is a reply to message #448022] Mon, 03 January 2005 13:19 Go to previous message
You may want to try:
http://dev.eclipse.org/viewcvs/index.cgi/%7Echeckout%7E/plat form-swt-home/dev.html#tools
And use the SLEAK tool. This will tell you if you have any SWT resources
that aren't being disposed that should of been.
Rich Kulp
Previous Topic:my java code together ve code
Next Topic:should I dispose of a font when...
Current Time: Sun Jul 20 14:57:36 EDT 2025
Powered by FUDForum. Page generated in 0.03584 seconds
