Home » Eclipse Projects » Standard Widget Toolkit (SWT) » What is that drop-down Coolbar button widget?
What is that drop-down Coolbar button widget? [message #447637] Wed, 15 December 2004 11:35 Go to next message
Hi, can anyone tell me what the widget is that allows menu sub-buttons to be
added to a parent coolbar button - looks like a combo box, and is used for
the New Project button in the IDE.
Thanks!
Phil
Re: What is that drop-down Coolbar button widget? [message #447639 is a reply to message #447637] Wed, 15 December 2004 13:07 Go to previous messageGo to next message
It's a ToolItem with style SWT.DROP_DOWN.
Stefan Zeiger http://www.szeiger.de http://www.novocode.com
My SWT controls: http://www.novocode.com/swt
Re: What is that drop-down Coolbar button widget? [message #447642 is a reply to message #447639] Wed, 15 December 2004 15:05 Go to previous messageGo to next message
Thanks for pointing me in the right direction. I'm trying to build a
Toolbar in a Coolbar:
public void fillCoolBar(ICoolBarManager coolBar) {
ToolBarManager toolBar = new ToolBarManager(SWT.FLAT | SWT.RIGHT);
coolBar.add(new ToolBarContributionItem(toolBar, "file"));
Action actionNew = new Action("New", SWT.DROP_DOWN) {
toolBar.add(actionNew);
This adds a drop-down ToolItem to the toolbar, but how do I now add actions
to this ToolItem?
Many thanks,
Phil
"Stefan Zeiger" <szeiger@novocode.com> wrote in message
news:cppuge$dml$1@www.eclipse.org...
>> be added to a parent coolbar button - looks like a combo box, and is used
>> for the New Project button in the IDE.
Re: What is that drop-down Coolbar button widget? [message #447644 is a reply to message #447642] Wed, 15 December 2004 16:13 Go to previous messageGo to next message
See:
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.swt.sni ppets/src/org/eclipse/swt/snippets/Snippet140.java?rev=HEAD& amp;content-type=text/vnd.viewcvs-markup
regards,
Mani
"Phillip Beauvoir" <p.beauvoir@bolton.ac.uk> wrote in message
news:cpq5dh$4q7$1@www.eclipse.org...
> actions to this ToolItem?
> Many thanks,
> Phil
>>> to be added to a parent coolbar button - looks like a combo box, and is
>>> used for the New Project button in the IDE.
Re: What is that drop-down Coolbar button widget? [message #447646 is a reply to message #447644] Wed, 15 December 2004 16:23 Go to previous messageGo to next message
Thnaks for the link but it doesn't help.
I'm trying to set up a Coolbar and toolbars when creating a View. All I
have is a ICoolBarManager.
Phil
Re: What is that drop-down Coolbar button widget? - The answer... [message #447653 is a reply to message #447637] Wed, 15 December 2004 19:43 Go to previous messageGo to next message
For anyone who's interested I found out how to do it with the following
class (replace your own actions). I don't know if this is the best way to
do it, but it works:
public class NewDropDownAction extends Action implements IMenuCreator {
private Menu _menu;
public NewDropDownAction() {
super("New", SWT.DROP_DOWN);
setToolTipText("New");
setMenuCreator(this);
public void dispose() {
if(_menu != null) {
_menu.dispose();
_menu = null;
public Menu getMenu(Control parent) {
if(_menu != null) {
_menu.dispose();
_menu = new Menu(parent);
ActionContributionItem item = new
ActionContributionItem(yourAction);
item.fill(_menu, -1);
item = new ActionContributionItem(anotherAction);
return _menu;
public Menu getMenu(Menu parent) {
return null;
news:cppp50$sa2$1@www.eclipse.org...
> Thanks!
> Phil
Re: What is that drop-down Coolbar button widget? - The answer... [message #447656 is a reply to message #447653] Thu, 16 December 2004 02:43 Go to previous messageGo to next message
Hi Phillip,
thanks for your example. I came to the same solution.
But your method getMenu(Menu) returns null. Have you an idea how I can fill
this method, without construvting the same menu like getMenu(Control) twice?
Bye Stefan
"Phillip Beauvoir" <p.beauvoir@bolton.ac.uk> schrieb im Newsbeitrag
news:cpqlpd$n2p$1@www.eclipse.org...
> private Menu _menu;
> if(_menu != null) {
> _menu.dispose();
> _menu = null;
> if(_menu != null) {
> _menu.dispose();
> return _menu;
> return null;
to
used
> > Thanks!
> > Phil
Re: What is that drop-down Coolbar button widget? - The answer... [message #447703 is a reply to message #447656] Thu, 16 December 2004 05:27 Go to previous messageGo to next message
I based mine on
org.eclipse.team.internal.ui.synchronize.actions.Synchronize PageDropDownAction
where they do the same, return null. I put a breakpoint there and found
that getMenu(Menu) is never called.
Now all I need to do is figure out how to get the menu to drop down when I
click the actual button (as well as the little arrow.)
Phil
"Stefan Pietsch" <pietsch@multichart.de> wrote in message
news:cprebq$tci$1@www.eclipse.org...
> Hi Phillip,
> fill
> twice?
> Bye Stefan
>> to
>> private Menu _menu;
>> if(_menu != null) {
>> _menu.dispose();
>> _menu = null;
>> if(_menu != null) {
>> _menu.dispose();
>> return _menu;
>> return null;
> to
> used
>> > Thanks!
>> > Phil
Re: What is that drop-down Coolbar button widget? - The answer... [message #447704 is a reply to message #447703] Thu, 16 December 2004 07:47 Go to previous messageGo to next message
Hi Phil,
you need getMenu(Menu) if you insert the same action a menubar and a
toolbar! With my toolbar everything works fine, but the menu does not.
Bye Stefan
news:cpro7g$uvh$1@www.eclipse.org...
> I based mine on
on
> Phil
> > Hi Phillip,
> > fill
> > twice?
> > Bye Stefan
> >> to
> >> private Menu _menu;
> >> if(_menu != null) {
> >> _menu.dispose();
> >> _menu = null;
> >> if(_menu != null) {
> >> _menu.dispose();
> >> return _menu;
> >> return null;
sub-buttons
> > to
> > used
> >> > Thanks!
> >> > Phil
Re: What is that drop-down Coolbar button widget? - The answer... [message #447706 is a reply to message #447704] Thu, 16 December 2004 08:24 Go to previous messageGo to next message
Can you just copy the code from getMenu(Control parent)?
Phil
news:cps04h$pmb$1@www.eclipse.org...
> Hi Phil,
> Bye Stefan
>> I based mine on
> on
>> I
>> Phil
>> > Hi Phillip,
>> > fill
>> > twice?
>> > Bye Stefan
>> >> following
>> >> way
>> >> to
>> >> private Menu _menu;
>> >> if(_menu != null) {
>> >> _menu.dispose();
>> >> _menu = null;
>> >> if(_menu != null) {
>> >> _menu.dispose();
>> >> return _menu;
>> >> return null;
> sub-buttons
>> > to
>> > used
>> >> > Thanks!
>> >> > Phil
Re: What is that drop-down Coolbar button widget? - The answer... [message #447709 is a reply to message #447706] Thu, 16 December 2004 09:14 Go to previous message
Hi Phil,
I think I can
Previous Topic:WizardSelectionPage example?
Next Topic:SWT & GEF
Current Time: Sat Jul 19 18:54:00 EDT 2025
Powered by FUDForum. Page generated in 0.32759 seconds
