Home » Eclipse Projects » Standard Widget Toolkit (SWT) » GUI hanging.
GUI hanging. [message #447271] |
Sun, 12 December 2004 11:01  |
--____LPHMXLZMXOMRLFKSEJCW____
Content-Type: text/plain; charset=iso-8859-1
Content-Transfer-Encoding: quoted-printable
I am new to java programing and even newer to SWT programming. I have =
found a problem where the GUI interface will "Hang". The background =
processes are all working but the GUI stops updating. (Running in a =
Windows XP environment)
I do not know if this is bug or a problem with my code. Below is a sample =
program that demonstrates the problem.
The program outputs a number to a text box and at the same time printing =
it to the system console. It is in a simple for loop. When the program is =
running press in quick succession the mouse about 10 to 20 times, The GUI =
will hang, however the System console is still being updated.
Is this a bug, or is their another way to do this.
I would be most gratefull for any assistance.
Matt
Sample program
public class Temp {
Temp t =3D new Temp();
t.start();
public void start(){
Display display =3D new Display();
Shell shell =3D new Shell(display);
Text text =3D new Text(shell,SWT.MULTI);
text.setSize(200,200);
text.setEditable(false);
shell.open();
=20
int y=3D1000000;
for (int x=3D0;x<y;x++){
text.append("\nCounter.. "+x);
System.out.print("\nCounter.. "+x);
=20
shell.open();
while (!shell.isDisposed()){
if (!display.readAndDispatch())display.sleep();
display.dispose();
Content-Type: multipart/related; boundary="____WHPEPQYSAQXEHDGESJXG____"
--____WHPEPQYSAQXEHDGESJXG____
Content-Type: text/html; charset=windows-1252
<HTML><HEAD>
<META http-equiv=3DContent-Type content=3D"text/html; charset=3Diso-8859-1"=
<META content=3D"MSHTML 6.00.2800.1400" name=3DGENERATOR></HEAD>
<BODY style=3D"MARGIN: 4px 4px 1px; FONT: 10pt Tahoma">
<DIV>Hi</DIV>
<DIV> </DIV>
<DIV>I am new to java programing and even newer to SWT programming. I have =
Windows XP environment)</DIV>
<DIV> </DIV>
<DIV>I do not know if this is bug or a problem with my code. Below is a =
sample program that demonstrates the problem.</DIV>
<DIV> </DIV>
<DIV>The program outputs a number to a text box and at the same time =
printing it to the system console. It is in a simple for loop. When the =
program is running press in quick succession the mouse about 10 to 20 =
times, The GUI will hang, however the System console is still being =
updated.</DIV>
<DIV> </DIV>
<DIV>Is this a bug, or is their another way to do this.</DIV>
<DIV> </DIV>
<DIV>I would be most gratefull for any assistance.</DIV>
<DIV> </DIV>
<DIV>Thanks</DIV>
<DIV> </DIV>
<DIV>Matt</DIV>
<DIV> </DIV>
<DIV>Sample program</DIV>
<DIV> </DIV>
<DIV>public class Temp {</DIV>
<DIV> </DIV>
<DIV> public static void main(String[] args) {<BR> Temp t =
=3D new Temp();<BR> t.start();<BR> } <BR> public void =
start(){<BR> Display display =3D new Display();<BR> S=
hell shell =3D new Shell(display);<BR> Text text =3D new =
Text(shell,SWT.MULTI);<BR> text.setSize(200,200); <BR>  =
;text.setEditable(false);<BR> shell.open(); <BR> <BR>&=
nbsp; int y=3D1000000;<BR> for (int x=3D0;x<y;x++){<BR>&=
nbsp; text.append("\nCounter.. "+x);<BR> =
System.out.print("\nCounter.. "+x);<BR> }<BR> <=
BR> shell.open();<BR> while (!shell.isDisposed()){<BR=
> if (!display.readAndDispatch())display.sleep();<BR> =
; }<BR> display.dispose();<BR > }<BR>}<BR></DIV></BODY>=
</HTML>
--____WHPEPQYSAQXEHDGESJXG____--
--____LPHMXLZMXOMRLFKSEJCW____--
Re: GUI hanging. [message #447272 is a reply to message #447271] |
Sun, 12 December 2004 12:39   |
Hi Matt,
Your "for" loop is a long-running process.
When you start clicking around while the loop is running, the mouse events
are queued directly in the SWT event queue, which must be processed by the
UI-Thread BEFORE any other GUI operations can be processed (e.g.
Text.append(String str) ).
So, the mouse events block the event queue, because the the event processing
code
(generally: display.readAndDispatch() never gets a chance to process and
execute (or in SWT terms, read and dispatch!) the queued events. (because
the programm just "STAYS" in your for loop, the whole time).
Here is a possible solution to the problem which I use often myself: I put
the update loop in a seperate Thread, so that the UI-Thread can process the
events without getting blocked. Note that display.syncExec() is used to pass
the UI-changing instructions back to the UI-Thread...
For more info, take a look at the API docs for:
org.eclipse.swt.widgets.Display
Display.syncExec(Runnable runnable)
Display.asyncExec(Runnable runnable)
you might also want to take a look at the articles found on these pages,
which both contain excellent tutorials for starters...:
http://www.eclipse.org/articles
http://www.cs.umanitoba.ca/~eclipse/
/* ***************** here is code********* */
import org.eclipse.swt.widgets.*;
import org.eclipse.swt.*;
public class Temp implements Runnable
// display and text are made global so that the references are available
within the run() method
Display display;
Text text;
// running is made global because otherwise it has to be declared final
to be accessible
// from the inner class
boolean running;
public void run()
int y=1000000;
// if running is false, the shell is disposed and the thread should
stop running
// the variable running is used to prevent an Text.append(String
str), after the text is
// disposed (otherwise .append() would throw a
WidgetDisposedException)
for (int x=0;x<y && running;x++)
final int x2 = x;
// All calls to the GUI must be made within the UI-thread
display.syncExec(new Runnable()
public void run()
if (!text.isDisposed())
// shell and text are still there: update
text.append("\nCounter.. "+x2);
System.out.print("\nCounter.. "+x2);
else
// shell and text are disposed: stop running...
running = false;
Temp t = new Temp();
t.start();
public void start()
running = true;
display = new Display();
Shell shell = new Shell(display);
text = new Text(shell,SWT.MULTI);
shell.open();
// shell is created, start the update thread...
Thread thread = new Thread(this);
thread.start();
// you dont need to open the shell twice...
// shell.open();
display.dispose();
regards,
Mani
"Matt McKenzie" <mmckenzie@novell.com> wrote in message
news:cphqhm$nt5$1@www.eclipse.org...
I am new to java programing and even newer to SWT programming. I have found
a problem where the GUI interface will "Hang". The background processes are
all working but the GUI stops updating. (Running in a Windows XP
environment)
The program outputs a number to a text box and at the same time printing it
Matt
Sample program
public class Temp {
t.start();
Display display = new Display();
Text text = new Text(shell,SWT.MULTI);
shell.open();
int y=1000000;
for (int x=0;x<y;x++){
shell.open();
display.dispose();
Re: GUI hanging. [message #447284 is a reply to message #447272] |
Mon, 13 December 2004 04:15  |
Hi Mani
Thanks for the tips.
I will give to try.
Matt
>>> Mani Ghamari<mani.ghamari@linkast.com> 12/12/2004 17:39:32 >>>
Hi Matt,
When you start clicking around while the loop is running, the mouse =
events=20
are queued directly in the SWT event queue, which must be processed by =
the=20
UI-Thread BEFORE any other GUI operations can be processed (e.g.=20
So, the mouse events block the event queue, because the the event =
processing=20
code
(generally: display.readAndDispatch() never gets a chance to process =
and=20
execute (or in SWT terms, read and dispatch!) the queued events. =
(because=20
Here is a possible solution to the problem which I use often myself: I =
put=20
the update loop in a seperate Thread, so that the UI-Thread can process =
the=20
events without getting blocked. Note that display.syncExec() is used to =
pass=20
you might also want to take a look at the articles found on these =
pages,=20
// display and text are made global so that the references are =
available=20
Display display;
Text text;
// running is made global because otherwise it has to be declared =
final=20
to be accessible
boolean running;
public void run()
int y=3D1000000;
// if running is false, the shell is disposed and the thread =
should=20
stop running
// the variable running is used to prevent an Text.append(String=20=
// disposed (otherwise .append() would throw a=20
for (int x=3D0;x<y && running;x++)
final int x2 =3D x;
public void run()
else
running =3D false;
t.start();
public void start()
running =3D true;
shell.open();
Thread thread =3D new Thread(this);
thread.start();
// shell.open();
display.dispose();
regards,
Mani
"Matt McKenzie" <mmckenzie@novell.com> wrote in message=20
found=20
a problem where the GUI interface will "Hang". The background processes =
are=20
all working but the GUI stops updating. (Running in a Windows XP=20
environment)
sample=20
it=20
to the system console. It is in a simple for loop. When the program is=20
running press in quick succession the mouse about 10 to 20 times, The =
GUI=20
Matt
Sample program
public class Temp {
t.start();
shell.open();
int y=3D1000000;
shell.open();
display.dispose();
<HTML><HEAD>
<META content=3D"MSHTML 6.00.2900.2180" name=3DGENERATOR></HEAD>
<DIV>Hi Mani</DIV>
<DIV> </DIV>
<DIV>Thanks for the tips.</DIV>
<DIV> </DIV>
<DIV>I will give to try.</DIV>
<DIV> </DIV>
<DIV>Thanks</DIV>
<DIV> </DIV>
<DIV>Matt</DIV>
<DIV><BR>>>> Mani Ghamari<mani.ghamari@linkast.com> =
12/12/2004 17:39:32 >>><BR></DIV>
<DIV style=3D"COLOR: #000000">Hi Matt,<BR><BR>Your "for" loop is a =
long-running process.<BR><BR>When you start clicking around while the loop =
is running, the mouse events <BR>are queued directly in the SWT event =
queue, which must be processed by the <BR>UI-Thread BEFORE any other GUI =
operations can be processed (e.g. <BR>Text.append(String str) ).<BR><BR>So,=
the mouse events block the event queue, because the the event processing =
<BR>code<BR>(generally: display.readAndDispatch() never gets a =
chance to process and <BR>execute (or in SWT terms, read and dispatch!) =
the queued events. (because <BR>the programm just "STAYS" in your for =
loop, the whole time).<BR><BR>Here is a possible solution to the problem =
which I use often myself: I put <BR>the update loop in a seperate Thread, =
so that the UI-Thread can process the <BR>events without getting blocked. =
Note that display.syncExec() is used to pass <BR>the UI-changing instructio=
ns back to the UI-Thread...<BR><BR>For more info, take a look at the API =
docs for:<BR>org.eclipse.swt.widgets.Display<BR>&<BR >Display.syncExec(R=
unnable runnable)<BR>Display.asyncExec(Runnable runnable)<BR><BR>you might =
also want to take a look at the articles found on these pages, <BR>which =
both contain excellent tutorials for starters...:<BR><A href=3D"http://www.=
eclipse.org/articles">http://www.eclipse.org/articles</A><BR><A href=3D"htt=
p://www.cs.umanitoba.ca/~eclipse/">http://www.cs.umanitoba.ca/~eclipse/</A>=
<BR><BR>/* ***************** here is code********* */<BR><BR>import =
org.eclipse.swt.widgets.*;<BR>import org.eclipse.swt.*;<BR><BR>public =
class Temp implements Runnable<BR>{<BR> // display and =
text are made global so that the references are available <BR>within the =
run() method<BR> Display display;<BR> =
Text text;<BR><BR> // running is made global because =
otherwise it has to be declared final <BR>to be accessible<BR> &=
nbsp; // from the inner class<BR> boolean running;<BR><BR=
> public void run()<BR> {<BR> &nbs=
p; int y=3D1000000;<BR><BR> =
// if running is false, the shell is disposed and =
the thread should <BR>stop running<BR> &=
nbsp; // the variable running is used to prevent an Text.append(String =
<BR>str), after the text is<BR> =
// disposed (otherwise .append() would throw a <BR>WidgetDisposedException)=
<BR><BR> for (int x=3D0;x<y =
&& running;x++)<BR> =
{<BR> =
final int x2 =3D x;<BR><BR> =
// All calls to the GUI must be made within the =
UI-thread<BR> &n=
bsp; display.syncExec(new Runnable()<BR>  =
; {<BR> &n=
bsp; &n bsp; public void run()<BR>&=
nbsp; & nbsp; & nbs=
p; {<BR> &=
nbsp; & nbsp; if (!text.isDis=
posed())<BR> &nb=
sp; &nb sp; {<BR> =
&nb=
sp; &nb sp; // shell and text are still =
there: update<BR> &nbs=
p; &nbs p; &nbs p;&=
nbsp; text.append("\nCounter.. "+x2);<BR> &nbs=
nbsp; System.out.print("\nCounter.. "+x2);<BR> =
;   ;   ;&n=
bsp; }<BR>  =
;   ;   ;&n=
bsp; else<BR> &n=
bsp; &n bsp; {<BR>  =
;   ;   ;&n=
bsp; &n bsp; // shell and text are =
disposed: stop running...<BR> &nbs=
nbsp; running =3D false;<BR>  =
;   ;   ;&n=
bsp; }<BR>  =
; }<BR> &n=
bsp; });<BR> =
}<BR> }<BR><BR> public static void =
main(String[] args)<BR> {<BR> &nbs=
p; Temp t =3D new Temp();<BR> &nbs=
p; t.start();<BR> }<BR><BR> =
public void start()<BR> {<BR><BR> =
running =3D true;<BR>  =
; display =3D new Display();<BR> &=
nbsp; Shell shell =3D new Shell(display);<BR> =
text =3D new Text(shell,SWT.MULTI);<BR>  =
; text.setSize(200,200);<BR>  =
; text.setEditable(false);<BR> &nb=
sp; shell.open();<BR><BR> =
// shell is created, start the update thread...<BR> =
Thread thread =3D new Thread(this);<BR>  =
; thread.start();<BR><BR> &n=
bsp; // you dont need to open the shell twice...<BR>// &nb=
sp; shell.open();<BR> =
while (!shell.isDisposed())<BR> &=
nbsp; {<BR> &nbs=
p; if (!display.readAndDispatch())display.sleep();<BR> &nb=
sp; }<BR> =
display.dispose();<BR> }<BR>}<BR><BR><BR>regards,<BR><BR>=
Mani<BR><BR>"Matt McKenzie" <mmckenzie@novell.com> wrote in message =
<BR>news:cphqhm$nt5$1@<A href=3D"http://www.eclipse.org...">www.eclipse.org=
....</A><BR>Hi<BR><BR>I am new to java programing and even newer to SWT =
programming. I have found <BR>a problem where the GUI interface will =
"Hang". The background processes are <BR>all working but the GUI stops =
updating. (Running in a Windows XP <BR>environment)<BR><BR>I do not know =
if this is bug or a problem with my code. Below is a sample <BR>program =
that demonstrates the problem.<BR><BR>The program outputs a number to a =
text box and at the same time printing it <BR>to the system console. It is =
in a simple for loop. When the program is <BR>running press in quick =
succession the mouse about 10 to 20 times, The GUI <BR>will hang, however =
the System console is still being updated.<BR><BR>Is this a bug, or is =
their another way to do this.<BR><BR>I would be most gratefull for any =
assistance.<BR><BR>Thanks<BR><BR>Matt<BR><BR>Sample program<BR><BR>public =
class Temp {<BR><BR>public static void main(String[] args) {<BR> =
Temp t =3D new Temp();<BR> t.start();<BR>}<BR>public void start(){<BR=
> Display display =3D new Display();<BR> Shell shell =3D new =
Shell(display);<BR> Text text =3D new Text(shell,SWT.MULTI);<BR> =
; text.setSize(200,200);<BR> text.setEditable(false);<BR> =
shell.open();<BR><BR> int y=3D1000000;<BR> for (int x=3D0;x<=
y;x++){<BR> text.append("\nCounter.. "+x);<BR>  =
; System.out.print("\nCounter.. "+x);<BR> }<BR><BR> =
shell.open();<BR> while (!shell.isDisposed()){<BR> if =
(!display.readAndDispatch())display.sleep();<BR> }<BR> =
display.dispose();<BR>}<BR>} <BR><BR><BR><BR><BR></DIV></BODY></HTML>
Current Time: Sat Jul 19 17:44:33 EDT 2025
Powered by FUDForum. Page generated in 0.05257 seconds
