Home » Eclipse Projects » Standard Widget Toolkit (SWT) » displaying HTML in dialog
displaying HTML in dialog [message #447078] Wed, 08 December 2004 10:12 Go to next message
Originally posted by: ps7.bolton.ac.uk
I want to open a kind of confirmation (ok button) dialog which will
display/render a HTML string message. Heres how I did it in swing -
with a JLabel...
JLabel box = new JLabel();
box.setVerticalAlignment(SwingConstants.TOP);
// pd.getLogResults() returns a HTML string ie <html><body>etc....
box.setText(pd.getLogResults());
JScrollPane sp = new JScrollPane(box);
sp.setPreferredSize(new Dimension(350, 400));
JOptionPane.showMessageDialog(MyApplication.getInstance(), sp,
"Completed", JOptionPane.PLAIN_MESSAGE);
How can I do this in swt? I tried using swt Label but it didnt seem to
work.
Thanks for your time
Paul
Re: displaying HTML in dialog [message #447107 is a reply to message #447078] Wed, 08 December 2004 12:18 Go to previous messageGo to next message
Paul Sharples wrote:
> with a JLabel...
> work.
> Paul
Paul,
The SWT Browser Widget is the only SWT component capable of displaying
html out of the box. Have you looked into using it?
- Jeff
Re: displaying HTML in dialog [message #447129 is a reply to message #447107] Wed, 08 December 2004 18:20 Go to previous messageGo to next message
hi,
you can displaya limited set of html using the eclipse 3.0 forms api:
StringBuffer buf = new StringBuffer();
buf.append("<form>");
buf.append("<p>");
buf.append("Here is some plain text for the text to render; ");
buf.append("this text is at <a href=\"http://www.eclipse.org\"
nowrap=\"true\">http://www.eclipse.org</a> web site.");
buf.append("</p>");
buf.append("<p>");
buf.append("<span color=\"header\" font=\"header\">This text is in header
font and color.</span>");
buf.append("</p>");
buf.append("<p>This line will contain some <b>bold</b> and some <span
font=\"text\">source</span> text. ");
buf.append("We can also add <img href=\"image\"/> an image. ");
buf.append("</p>");
buf.append("<li>A default (bulleted) list item.</li>");
buf.append("<li>Another bullet list item.</li>");
buf.append("<li style=\"text\" value=\"1.\">A list item with text.</li>");
buf.append("<li style=\"text\" value=\"2.\">Another list item with
text</li>");
buf.append("<li style=\"image\" value=\"image\">List item with an image
bullet</li>");
buf.append("<li style=\"text\" bindent=\"20\" indent=\"40\"
value=\"3.\">A list item with text.</li>");
value=\"4.\">A list item with text.</li>");
buf.append("</form>");
FormText rtext = toolkit.createFormText(form.getBody(), true);
td = new TableWrapData(TableWrapData.FILL);
td.colspan = 2;
rtext.setLayoutData(td);
rtext.setImage("image",
ExamplesPlugin.getDefault().getImageRegistry().get(ExamplesP lugin.IMG_SAMPLE));
rtext.setColor("header", toolkit.getColors().getColor(FormColors.TITLE));
rtext.setFont("header", JFaceResources.getHeaderFont());
rtext.setText(buf.toString(), true, false);
rtext.addHyperlinkListener(new HyperlinkAdapter() {
public void linkActivated(HyperlinkEvent e) {
System.out.println("Link active: "+e.getHref());
see
http://dev.eclipse.org/viewcvs/index.cgi/~checkout~/pde-ui-h ome/working/EclipseForms/EclipseForms.html
for usage.
regards,
lars
>> Hi,
>> with a JLabel...
>> work.
>> Paul
> Paul,
> - Jeff
Re: displaying HTML in dialog [message #447135 is a reply to message #447129] Wed, 08 December 2004 19:53 Go to previous messageGo to next message
Thanks to both of you.
Yes I'd read a little about the forms API and have used the Browser
widget a little before - so it will have to be one of those I guess. I'd
just wondered if there was something comparable to the swing version -
but I guess not.
Thanks again.
Paul
lars gersmann wrote:
> hi,
> buf.append("<p>");
> buf.append("</p>");
> buf.append("<p>");
> header font and color.</span>");
> buf.append("</p>");
> <span font=\"text\">source</span> text. ");
> buf.append("</p>");
> text.</li>");
> text</li>");
> image bullet</li>");
> td.colspan = 2;
> see
> for usage.
> regards,
> lars
>>> Hi,
>>> with a JLabel...
>>> to work.
>>> Paul
>> Paul,
>> - Jeff
Re: displaying HTML in dialog [message #447143 is a reply to message #447078] Wed, 08 December 2004 23:37 Go to previous message
Originally posted by: no.ddress.here
In article <cp75ku$kmo$1@www.eclipse.org>, ps7@bolton.ac.uk says...
> with a JLabel...
> work.
> Paul
Paul,
You can always embed Swing in SWT. Check out SWT example snippet 125.
As an example, this snippet embeds a JEditorPane in a Composite in an
SWT form.
toolkit = new FormToolkit(parent.getDisplay());
form = toolkit.createForm(parent);
GridLayout layout = new GridLayout();
form.getBody().setLayout(layout);
Composite composite1 = toolkit.createComposite(form.getBody(),
SWT.EMBEDDED);
GridLayout composite1Layout = new GridLayout();
composite1Layout.makeColumnsEqualWidth = true;
GridData composite1LData = new GridData();
composite1LData.grabExcessHorizontalSpace = true;
composite1LData.grabExcessVerticalSpace = true;
composite1LData.horizontalAlignment = GridData.FILL;
composite1LData.verticalAlignment = GridData.FILL;
composite1.setLayoutData(composite1LData);
composite1.setLayout(composite1Layout);
Frame locationFrame = SWT_AWT.new_Frame(composite1);
Panel jPanel1 = new java.awt.Panel();
locationFrame.add(jPanel1);
BorderLayout panelLayout = new BorderLayout();
jPanel1.setLayout(panelLayout);
jScrollPane1 = new JScrollPane();
jPanel1.add(jScrollPane1, BorderLayout.CENTER);
jScrollPane1.setVerticalScrollBarPolicy
(JScrollPane.VERTICAL_SCROLLBAR_ALWAYS);
jEditorPane1 = new JEditorPane();
jScrollPane1.setViewportView(jEditorPane1);
jEditorPane1.setContentType("text/html");
jEditorPane1.setText("jEditorPane1");
jEditorPane1.setEditable(false);
Gerald
Previous Topic:Unable to select JTable rows??
Next Topic:Swing Table to SWT Table
Current Time: Sun Jul 20 08:23:24 EDT 2025
Powered by FUDForum. Page generated in 0.03192 seconds
