Home » Eclipse Projects » Standard Widget Toolkit (SWT) » No Display.getCurrent() when opening Swing Component
No Display.getCurrent() when opening Swing Component [message #446929] Mon, 06 December 2004 10:14 Go to next message
I have a (SWT based) GEF/draw2d Application which opens a JFrame on
Button Click (pure Swing, not SWT_AWT !)
Beside from strange effects like deadlocks when using the Clipboard if
the JFrame is opened modal, I've got one somehow fundamental error:
The JFrame is opened, causing some visuals "from behind" to be marked as
invalid. The asynchronous (GEF-) repaint manager triggers something like
a repaint event with "Display.getCurrent().asyncExec(....)", which
results in a NullPointerException...
Is there no current display, if some Swing component has the focus ?
It sound plausible, as the current thread is no SWT ui-thread...
but how can I work around this issue?
Changing the call into "Display.getDefault()" is no solution, as the
code is part of the GEF.
Any ideas ?
Thanks in advance
Florian
Re: No Display.getCurrent() when opening Swing Component [message #446937 is a reply to message #446929] Mon, 06 December 2004 12:40 Go to previous message
Enter a bug report against GEF. Display.getCurrent() can return null.
"Florian Georg" <FGeorg@gmx.de> wrote in message
news:cp1t07$fka$1@www.eclipse.org...
> Hello,
> Any ideas ?
> Thanks in advance
> Florian
Previous Topic:Shell.computeTrim()
Next Topic:Redrawing newly created widget
Current Time: Sat Jul 19 12:15:55 EDT 2025
Powered by FUDForum. Page generated in 0.04361 seconds
