Home » Eclipse Projects » Standard Widget Toolkit (SWT) » table that allows only one row
table that allows only one row [message #446834] |
Fri, 03 December 2004 10:28  |
Originally posted by: mikael_focik.hotmail.com
Is it possible to create a table that only allows to add and to display
one row? I would like to have some kind of text field that can show three
values (like a table with three resizable columns), but I only want to
display one row. Is there another control I could use?
TIA, Mikael
Re: table that allows only one row [message #446991 is a reply to message #446834] |
Tue, 07 December 2004 09:02   |
Hi Mikael,
Why don't you just use a table?
Since you will have to add the table items to the table programmatically,
which is of course done using the constructor:
TableItem(Table parent, int style)
It is always up to you how many rows a table will have.
For example, when the user clicks on the add button (or whatever mechanism
that triggers the updating of table), just check the table for the number of
rows ( using Table.getItemCount() )
if the count is zero, just create the new TableItem. If the count is one,
clear up the table (using Table.removeAll()) and then add the row you want.
As far as I know, there is no control specially designed for that purpose
(It won't make sense, since the same thing is perfectly and easily
implementable using a Table!).
You might consider writing your own widget using a couple of Labels,
Composites and Sashes, yet the same result can be achieved much faster using
the table.
regards,
Mani
"Mikael Focik" <mikael_focik@hotmail.com> wrote in message
news:coq0m6$fq1$1@www.eclipse.org...
> TIA, Mikael
Re: table that allows only one row [message #447008 is a reply to message #446991] |
Tue, 07 December 2004 13:23   |
Actually, a SashForm with a bunch of Text widgets as children will do this
quite easily:
SashForm form = new SashForm(shell, SWT.HORIZONTAL | SWT.SMOOTH);
for (int i = 0; i < 3; i++) {
Text text= new Text(form, SWT.NONE);
text.setText("column "+i);
"Mani Ghamari" <mani.ghamari@linkast.com> wrote in message
news:cp4d5m$kh1$1@www.eclipse.org...
> Hi Mikael,
> of rows ( using Table.getItemCount() )
> want.
> using the table.
> regards,
> Mani
>> TIA, Mikael
Re: table that allows only one row [message #447009 is a reply to message #447008] |
Tue, 07 December 2004 14:36  |
Yes, About the compsoite, I assumed that there would be a header visible for
each column (so that you have to combine the header AND the Text/Label in a
composite)...
thanks anyways,
Mani
"Veronika Irvine" <veronika_irvine@oti.com> wrote in message
news:cp4sgj$13l$1@www.eclipse.org...
> quite easily:
>> Hi Mikael,
>> mechanism that triggers the updating of table), just check the table for
>> the number of rows ( using Table.getItemCount() )
>> want.
>> using the table.
>> regards,
>> Mani
>>> three values (like a table with three resizable columns), but I only
>>> want to display one row. Is there another control I could use?
>>> TIA, Mikael
Current Time: Sat Jul 19 09:31:13 EDT 2025
Powered by FUDForum. Page generated in 0.03736 seconds
