Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Is is possible to make a tree node non-collapsible
Is is possible to make a tree node non-collapsible [message #446807] Thu, 02 December 2004 11:04 Go to next message
I want to display a tree with a root node that can never be collapsed. As
such I want to remove the initial -/+ and slide everything over to the left.
Is that possible?
Re: Is is possible to make a tree node non-collapsible [message #446810 is a reply to message #446807] Thu, 02 December 2004 11:12 Go to previous messageGo to next message
Hi Jim,
I think you have to implement a TreeListener and than manually call
setExpand(true) if the TreeItem was collapsed. I do not know, how to hide
the [+/-].
Bye Stefan
"Jim Adams" <Jim.Adams@sas.com> schrieb im Newsbeitrag
news:conecu$pe4$1@www.eclipse.org...
left.
> Is that possible?
Re: Is is possible to make a tree node non-collapsible [message #446811 is a reply to message #446807] Thu, 02 December 2004 11:30 Go to previous messageGo to next message
Hi Jim,
take a look at jface.TreeViewer. There is a method called isExpandable which
you can override.
Bye Stefan
left.
> Is that possible?
Re: Is is possible to make a tree node non-collapsible [message #446813 is a reply to message #446811] Thu, 02 December 2004 12:29 Go to previous messageGo to next message
Yeah, but its the +/- that I really want to get rid of....
And, in any case, I would really need that to be isCollapsilbe which is
different from isExpandable...
"Stefan Pietsch" <pietsch@multichart.de> wrote in message
news:confup$tgv$1@www.eclipse.org...
> Hi Jim,
which
> you can override.
> Bye Stefan
As
> left.
> > Is that possible?
Re: Is is possible to make a tree node non-collapsible [message #446828 is a reply to message #446813] Fri, 03 December 2004 05:31 Go to previous messageGo to next message
One workaround is to create a regular old table with spaces at the
beginning of some rows.
>> Hi Jim,
> which
>> you can override.
>> Bye Stefan
> As
>> left.
>> > Is that possible?
Re: Is is possible to make a tree node non-collapsible [message #446863 is a reply to message #446828] Fri, 03 December 2004 14:17 Go to previous message
Not if I wanted to delete spaces.....
"Mark McLaren" <noone@nowhere.com> wrote in message
news:copf97$406$1@www.eclipse.org...
> >> Hi Jim,
> > which
> >> you can override.
> >> Bye Stefan
collapsed.
> > As
the
> >> left.
> >> > Is that possible?
Previous Topic:[MacOS X] Image size changes after redrawing on TableTree
Next Topic:Widget layout
Current Time: Sat Jul 19 15:24:12 EDT 2025
Powered by FUDForum. Page generated in 0.06420 seconds
