Home » Eclipse Projects » Standard Widget Toolkit (SWT) » How to get a control from a specific column of a TableTreeItem ?
How to get a control from a specific column of a TableTreeItem ? [message #446681] Tue, 30 November 2004 10:03 Go to next message
hello all !
I used a TableTreeEditor to add a control to a cloumn of a TableTreeItem.
editor.setEditor(control,item,Column);
Then How can I get recover the control giving the editor and the item
and the column directly,
but not through event listener?
That means the the composite which the Control displayed above is not
being edited.
so I can't use editor.getEditor() to get the control.
anyone can help me ?
Thank you for any help !
Re: How to get a control from a specific column of a TableTreeItem ? [message #446688 is a reply to message #446681] Tue, 30 November 2004 11:19 Go to previous messageGo to next message
For the currently active control, you can use TableTreeEditor.getEditor().
If you are using TableTreeEditor for multiple columns and multiple controls,
you will have to remember somewhere which Control is used to edit which
column. After you call TableTreeEditor.setEditor(null), TableTreeEditor has
no knowledge of the control you just removed.
"bbskill" <bbkills@tom.com> wrote in message
news:coi275$j3q$1@www.eclipse.org...
> hello all !
> being edited.
Re: How to get a control from a specific column of a TableTreeItem ? [message #446736 is a reply to message #446688] Wed, 01 December 2004 19:03 Go to previous messageGo to next message
But if the control is not currently active .
what I want to do is to dynamicaly update a
progressBar in a specific column of a specific TableTreeItem of a
TableTree.
any way to get the control ?
>>hello all !
>>being edited.
Re: How to get a control from a specific column of a TableTreeItem ? [message #446756 is a reply to message #446736] Thu, 02 December 2004 08:49 Go to previous message
You will need to track the non-active controls yourself.
news:colmjh$5vk$1@www.eclipse.org...
> TableTree.
>> controls, you will have to remember somewhere which Control is used to
>> edit which column. After you call TableTreeEditor.setEditor(null),
>> TableTreeEditor has no knowledge of the control you just removed.
>>>hello all !
>>>being edited.
Previous Topic:CoolBars
Next Topic:[TreeViewer] Force update
Current Time: Sun Jul 20 05:54:14 EDT 2025
Powered by FUDForum. Page generated in 0.24804 seconds
