Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Can I get mouse position inside widget
Can I get mouse position inside widget [message #446123] Wed, 17 November 2004 09:56 Go to next message
I am writing a DropTargetListener for a Tree control and wish to find out
where the mouse is relative to each TreeItem widget. THis is to that I can
distinguihs between sibling-type inserts and child-type inserts, which are
otherwise indistinguishable - as far as I can work out.
I can get the display position from the event, along with the widget
itself, but there does not appear to be any way of obtaining the location
of the widget in any form that relates to the mouse position.
The event coordinates are relative to the display, which is fine, but all
of the widget details are relative to the widget itself - e.g. its
location is always set to (0,0).
Does anyone have any ideas as to how I can get the location of the widget
relative to the display (or any other common reference point)?
Note that since the widget is not a Control, I cannot use methods like
toDisplay or toControl to re-map the mouse coordinates.
Any info most appreciated.
Andy D
Re: Can I get mouse position inside widget [message #446129 is a reply to message #446123] Wed, 17 November 2004 11:05 Go to previous messageGo to next message
See Display.map():
* Maps a point from one coordinate system to another.
* When the control is null, coordinates are mapped to
* the display.
* <p>
* NOTE: On right-to-left platforms where the coordinate
* systems are mirrored, special care needs to be taken
* when mapping coordinates from one control to another
* to ensure the result is correctly mirrored.
* Mapping a point that is the origin of a rectangle and
* then adding the width and height is not equivalent to
* mapping the rectangle. When one control is mirrored
* and the other is not, adding the width and height to a
* point that was mapped causes the rectangle to extend
* in the wrong direction. Mapping the entire rectangle
* instead of just one point causes both the origin and
* the corner of the rectangle to be mapped.
* </p>
* @param from the source <code>Control</code> or <code>null</code>
* @param to the destination <code>Control</code> or <code>null</code>
* @param x coordinates to be mapped
* @param y coordinates to be mapped
* @return point with mapped coordinates
* @exception IllegalArgumentException <ul>
* <li>ERROR_INVALID_ARGUMENT - if the Control from or the Control to have
been disposed</li>
* </ul>
* @exception SWTException <ul>
* <li>ERROR_THREAD_INVALID_ACCESS - if not called from the thread that
created the receiver</li>
* <li>ERROR_DEVICE_DISPOSED - if the receiver has been disposed</li>
* </ul>
* @since 2.1.2
public Point map (Control from, Control to, int x, int y) {
See also:
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.swt.sni ppets/src/org/eclipse/swt/snippets/Snippet91.java?rev=HEAD&a mp;content-type=text/vnd.viewcvs-markup
"Andy Doddington" <andy@doddington.net> wrote in message
news:cnfore$l3j$1@www.eclipse.org...
> Regards,
> Andy D
Re: Can I get mouse position inside widget [message #446135 is a reply to message #446129] Wed, 17 November 2004 12:11 Go to previous message
Many thanks Veronica - that has solved my problem!
Andy D
Veronika Irvine wrote:
> See Display.map():
> * the display.
> * <p>
> * </p>
> been disposed</li>
> * </ul>
> * </ul>
> * @since 2.1.2
> See also:
>> Regards,
>> Andy D
Previous Topic:DirectoryFieldEditorQuestion
Next Topic:Z-Order of child widgets of a canvas
Current Time: Sun Jul 20 09:13:13 EDT 2025
Powered by FUDForum. Page generated in 0.04570 seconds
