How to modify Table columns dynamically [message #445765] |
Wed, 10 November 2004 14:00  |
I'd like to build a table/tableviewer that displays the result of SQL
query. Each time the result will return different set of table columns. I
used a table/tableviewer to display the result, it needs to dynamically
change the table columns for each resultset. However, I can not find a
method in Table or TableViewer to modify the TableColumn inside. Also the
columns[] is a private member in Table.class and is invisible even I
inherits from it.
Do I have to recreat a new tableviewer everytime a resultset is returned?
Thanks a lot,
John
Re: How to modify Table columns dynamically [message #445777 is a reply to message #445765] |
Wed, 10 November 2004 20:29  |
Originally posted by: nickthat.yahoo.com
John,
I think what you will need to do is call Table.getColumns to get your
array of columns. Then iterate through the array and call dispose on each
column. Then you will need to recreate the new set of columns.
Nick
John Wang wrote:
> inherits from it.
> Thanks a lot,
> John
FUDForum. Page generated in 0.03083 seconds
