Home » Eclipse Projects » Standard Widget Toolkit (SWT) » How To Remove a Column from a Table
How To Remove a Column from a Table [message #445430] Fri, 05 November 2004 08:38 Go to next message
Originally posted by: alr.agelid.com
Hi there,
I'd like to remove a TableColumn from a Table but i didn't find any way to
do this properly.
In my case the Table is in a Editor Part of the Eclipse Workbench.
When i tried to "dispose" the column directly, column diseapear from the
TableViewer, but when closing the workbench i've got the following error :
Unhandled exception caught in event loop.
Reason:
at org.eclipse.swt.widgets.Table.releaseWidget(Table.java:1091)
at org.eclipse.swt.widgets.Widget.releaseResources(Widget.java: 715)
at org.eclipse.swt.widgets.Composite.releaseChildren(Composite. java:319)
at org.eclipse.swt.widgets.Composite.releaseWidget(Composite.ja va:367)
and so on....
i'm running under ibm jdk.1.4.1 and Eclipse 2.1
Re: How To Remove a Column from a Table [message #445434 is a reply to message #445430] Fri, 05 November 2004 09:28 Go to previous message
TableColumn.dispose() is the right answer. Looks like a flavour of
https://bugs.eclipse.org/bugs/show_bug.cgi?id=45708.
"alr" <alr@agelid.com> wrote in message news:cmfvnv$2nk$1@eclipse.org...
> Hi there,
> do this properly.
> Reason:
> and so on....
Previous Topic:ScrollBar problem
Next Topic:Accessing Object Instances in via OLE
Current Time: Sat Jul 19 15:15:53 EDT 2025
Powered by FUDForum. Page generated in 0.03234 seconds
