Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Help needed on FormAttachment
Help needed on FormAttachment [message #445377] |
Thu, 04 November 2004 11:26  |
Originally posted by: hortiz.xxx.com
Here is a sample code to illustrate my problem : I use a FormLayout for my
main composite (the "red" one) and I create a new Composite (the "green"
one) in it, using a FormData.
My problem is that I want the green composite to be as wide as its parent
composite.
I've tried to set some FormAttachment but I didn't manage to find the
solution.
Could you please help me,
H.ORTIZ
import org.eclipse.swt.SWT;
import org.eclipse.swt.graphics.Color;
import org.eclipse.swt.graphics.RGB;
import org.eclipse.swt.layout.FormData;
import org.eclipse.swt.layout.FormLayout;
import org.eclipse.swt.widgets.Composite;
import org.eclipse.swt.widgets.Shell;
public class FormAttachmentTest {
private static Display display;
private static Shell shell;
display = new Display ();
shell = new Shell (display);
shell.setBackground(new Color(display, new RGB(255,0,0)));
FormLayout formLayout = new FormLayout();
shell.setLayout(formLayout);
Composite composite = new Composite(shell, SWT.BORDER);
composite.setBackground(new Color(display, new RGB(0,255,0)));
FormData data = new FormData();
composite.setLayoutData(data);
shell.pack();
shell.setSize(800,600);
shell.open();
while (!shell.isDisposed ()) {
if (!display.readAndDispatch ())
display.sleep ();
display.dispose ();
Re: Help needed on FormAttachment [message #445387 is a reply to message #445377] |
Thu, 04 November 2004 13:20   |
You need to set the form attachments. In this case, why would you use a form
at all? Why not use a FillLayout?
import org.eclipse.swt.layout.FormAttachment;
display = new Display();
shell = new Shell(display);
shell.setBackground(new Color(display, new RGB(255, 0, 0)));
composite.setBackground(new Color(display, new RGB(0, 255, 0)));
data.left = new FormAttachment (0);
data.right = new FormAttachment (100);
data.top = new FormAttachment (0);
data.bottom = new FormAttachment (100);
shell.pack();
shell.setSize(800, 600);
shell.open();
while (!shell.isDisposed()) {
if (!display.readAndDispatch())
display.sleep();
display.dispose();
"HORTIZ" <hortiz@xxx.com> wrote in message news:cmdl6r$qgk$1@eclipse.org...
> composite.
> solution.
> Thanks
> H.ORTIZ
> import org.eclipse.swt.widgets.Display;
> public static void main(String[] args) {
> shell.pack();
> shell.open();
> display.sleep ();
> display.dispose ();
Re: Help needed on FormAttachment [message #445406 is a reply to message #445387] |
Fri, 05 November 2004 03:14   |
Hi Steve,
If I use a FormLayout it is because my composite is hidden / shown at
runtime so I have adapted the sample code provided by Caroline MacLeod at
https://bugs.eclipse.org/bugs/show_bug.cgi?id=49426
> shell.pack();
> shell.open();
> display.sleep();
> display.dispose();
>> Hi,
>> composite.
>> solution.
>> Thanks
>> H.ORTIZ
>> shell.pack();
>> shell.open();
>> display.sleep ();
>> display.dispose ();
Re: Help needed on FormAttachment [message #445408 is a reply to message #445388] |
Fri, 05 November 2004 03:18  |
Thanks a lot Stefan, it works fine now
Stefan Zeiger wrote:
>> my main composite (the "red" one) and I create a new Composite (the
>> "green" one) in it, using a FormData.
>> parent composite.
> Here's the correct FormData:
> data.left = new FormAttachment(0);
> data.right = new FormAttachment(100);
Current Time: Sat Jul 19 05:03:00 EDT 2025
Powered by FUDForum. Page generated in 0.04503 seconds
