MouseDoubleClick event [message #445263] |
Sun, 31 October 2004 09:07  |
I have a list control with a SelectionListener attached to it. The problem
is that when I double-click an item in the list first is called the
widgetSelected() method and then the widgetDefaultSelected() method. I need
to filter the widgetSelected method invocation, how can I do that ?
I know that is this system specific event generation, ex. Win32:
"Double-clicking the left mouse button actually generates a sequence of four
messages: WM_LBUTTONDOWN, WM_LBUTTONUP, WM_LBUTTONDBLCLK, and WM_LBUTTONUP.
But is there a method to avoid this ?
The only solution I found for this is to make a thread when Selection event
is generated and sleep this thread for doubleClickTime amount (a little bit
more) and if the DefaultSelection event still not arrived consider that was
a Selection event (only mouse down).
Is there another solution for this ?
Boby
Re: MouseDoubleClick event [message #445276 is a reply to message #445263] |
Mon, 01 November 2004 09:37   |
Waiting is the right thing to do, even if you were a native MFC application.
The issue is that in a mouse down, you have no way of knowing whether there
is another mouse down coming that will cause a double select, other than
waiting for it. Investigate Display.addTimer() instead of spawning a
thread. Be warned that widgetDefaultSelected() can come from the keyboard
as well as from the mouse, depending on the platform.
"Robert Bacs" <boby@zerosoft.ro> wrote in message
news:cm2rjc$afb$1@eclipse.org...
need
four
WM_LBUTTONUP.
event
bit
was
> Best regards,
> Boby
Re: MouseDoubleClick event [message #445289 is a reply to message #445276] |
Mon, 01 November 2004 11:54   |
Do you mean Display.timerExec() ?
I don't see any addTimer() method in Display class.
Yes, it's much better to execute in the user-interface thread than spawning
a new thread but I tried in an asyncExec() - didn't work and I missed the
timerExec() :).
Thanks and regards,
Boby
"Steve Northover" <steve_northover@ca.ibm.com> wrote in message
news:cm5hn8$int$1@eclipse.org...
application.
there
> > Hi,
problem
> need
> four
> WM_LBUTTONUP.
> event
> bit
> was
> > Best regards,
> > Boby
Re: MouseDoubleClick event [message #445327 is a reply to message #445289] |
Tue, 02 November 2004 10:24  |
Yup, I meant Display.timerExec().
news:cm5pnc$34s$1@eclipse.org...
spawning
> timerExec() :).
> Thanks and regards,
> Boby
> application.
> there
keyboard
> > > Hi,
> problem
> > need
of
> > four
> > WM_LBUTTONUP.
> > event
little
> > bit
that
> > was
> > > Best regards,
> > > Boby
FUDForum. Page generated in 0.04371 seconds
