Home » Eclipse Projects » Standard Widget Toolkit (SWT) » ActiveX and return class
ActiveX and return class [message #444571] Fri, 15 October 2004 00:39 Go to next message
I'm wondering how I would go about getting the object provided by a
listener to a OleControl object.
public void handleEvent (OleEvent event)
if (event.type == DOUBLE_CLK)
Variant args = event.arguments[0];
if (args == null) return;
/*What do i do?*/
How do I get the _OnAlertSelectedEvent e which is provided by this event?
And how would I get it's fields.
Re: ActiveX and return class [message #444578 is a reply to message #444571] Fri, 15 October 2004 09:32 Go to previous messageGo to next message
What does the type library info for the DOUBLE_CLK event for this particular
control look like?
"Vitali" <vlovich@spymac.com> wrote in message
news:opsfv9vfd6p9udmp@superspeedy.spuc...
> /*What do i do?*/
Re: ActiveX and return class [message #444590 is a reply to message #444578] Fri, 15 October 2004 12:05 Go to previous messageGo to next message
I'm not sure what you mean by that. I don't have the source to the
activex control and the documentation is pretty sparse.
I figured out what the int for the event type by just adding event
listeners for events 0 - 1000, and 50 is the one that occurs when a user
double clicks.
In CPP or C# the event handler is a callback which is passed LPDISPATCH
(in the example called Alert).
HRESULT hr = Alert->QueryInterface( IID_IAlertData,(void**)&myalert);
IID_IAlertData is something imported from an ocx file and myalert is a
pointer to the proper class type (probably also imported from the ocx file.
On Fri, 15 Oct 2004 09:32:00 -0400, Veronika Irvine
> particular
> control look like?
>> /*What do i do?*/
>> event?
Using Opera's revolutionary e-mail client: http://www.opera.com/m2/
Re: ActiveX and return class [message #444597 is a reply to message #444590] Fri, 15 October 2004 14:50 Go to previous message
You could try:
Variant arg1 = event.arguments[0];
if (arg1 == null) return;
if (arg1.getType() == OLE.VT_DISPATCH) {
OleAutomation auto = arg1.getAutomation();
... use the automation object to do whatever it is you
want to do, you need to find out what methods are available on it
auto.dispose();
arg1.dispose();
news:opsfw5m1lkp9udmp@superspeedy.spuc...
> double clicks.
> file.
>> particular
>> control look like?
>>> /*What do i do?*/
>>> event?
Previous Topic:Reordering Table Columns in Carbon
Next Topic:Need a cross-platform example
Current Time: Sat Jul 19 13:19:25 EDT 2025
Powered by FUDForum. Page generated in 0.20130 seconds
