Home » Eclipse Projects » Rich Client Platform (RCP) » Creating standalone help RCP
Creating standalone help RCP [message #444033] Wed, 08 February 2006 13:49 Go to next message
Originally posted by: hardage-vergeer_lani.emc.com
I've created w working help plugin for display within the Eclipse
workbench. I've worked through the RCP tutorials. This is probably still a
very basic question, but I'm stumped on how to package my help as an RCP.
To be explicit, I want nothing but the help. This seems to be a
potentially wide application of RCP -- as a help delivery system -- but I
can't find any guidelines on how to do it. Any suggestions?
Re: Creating standalone help RCP [message #444103 is a reply to message #444033] Thu, 09 February 2006 12:36 Go to previous messageGo to next message
Was the question too broad or too easy? Should I post it on the newbie
group?
Re: Creating standalone help RCP [message #444118 is a reply to message #444103] Thu, 09 February 2006 23:42 Go to previous messageGo to next message
> group?
This link describes using stand alone help in applications
http://help.eclipse.org/help31/index.jsp?topic=/org.eclipse. platform.doc.isv/reference/misc/help_standalone.html
Re: Creating standalone help RCP [message #444119 is a reply to message #444033] Thu, 09 February 2006 23:50 Go to previous messageGo to next message
Originally posted by: phillip.baird.clear.net.nz
I'm not an RCP expert yet but this is how I'd attempt to do this...
Create a RCP application that does not open any
workbench windows and then automatically invoke the help system.
Not sure how you start the workbench without opening a workbench window.
Possibly in your WorkbenchAdvisor override openWindows() to do nothing
other than return true.
Again in your WorkbenchAdvisor override postStartup() and call
PlatformUI.getWorkbench().getHelpSystem().displayHelp() to invoke the
help. See HelpContentsAction.run() for how the standard help action
does this. You cannot use the action because it requires a window.
/PhillipB
Re: Creating standalone help RCP [message #444202 is a reply to message #444118] Fri, 10 February 2006 12:28 Go to previous messageGo to next message
Thanks, but I'm not creating an infocenter, it is just a help RCP. It's
for developers who are not using Eclipse and not connecting to an
infocenter installation. That article is helpful in describing the
dependencies but not the launching.
Re: Creating standalone help RCP [message #444204 is a reply to message #444119] Fri, 10 February 2006 12:29 Go to previous messageGo to next message
Thanks, this approach sounds promising. I'll give it a try.
Re: Creating standalone help RCP [message #444209 is a reply to message #444204] Fri, 10 February 2006 14:03 Go to previous messageGo to next message
That worked! Thank you very much.
Re: Creating standalone help RCP [message #444495 is a reply to message #444209] Thu, 16 February 2006 10:22 Go to previous messageGo to next message
I thought this looked interesting and gave it a try too. There is one
problem. After the help system is closed the main application stays
running. Did you find a way to close the application once the help system
is closed? Or were you able to find a way to keep the help system running
after closing the application programaticly. When I closed the workbench
after starting the help system it closed the help window too.
Ian
Re: Creating standalone help RCP [message #444543 is a reply to message #444119] Fri, 17 February 2006 05:28 Go to previous message
Originally posted by: rohitash.kainth.tcs.com
I have tried this, but my help window is not appearing. I also tried that with adding the action HELP_CONTENT in a gui plugin, but still it didn't work. Any thoughts?
Previous Topic:RCP Export ignores code exclusions
Next Topic:rcp application, how to I get rid of the search menu
Current Time: Sat Jul 19 20:32:53 EDT 2025
Powered by FUDForum. Page generated in 0.39423 seconds
