Home » Eclipse Projects » Rich Client Platform (RCP) » View Title
View Title [message #427788] Wed, 04 May 2005 05:28 Go to next message
Anyone knows how change a view title in runtime?
Thanks.
Re: View Title [message #427799 is a reply to message #427788] Wed, 04 May 2005 13:09 Go to previous messageGo to next message
setPartName() method in org.eclipse.ui.part.ViewPart
....Ron Capelli
Re: View Title [message #427801 is a reply to message #427788] Wed, 04 May 2005 22:15 Go to previous messageGo to next message
Most of your recent questions are covered in
http://www.eclipsecon.org/2005/presentations/EclipseCon2005_ Tutorial26Final.pdf
HTH,
PaScaL
> Thanks.
Re: View Title [message #427807 is a reply to message #427788] Thu, 05 May 2005 08:39 Go to previous messageGo to next message
Originally posted by: jsilva.inf.utfsm.cl
> Thanks.
Hi Oscar,
I have this method in my WorkbenchWindowAdvisor. Is called every time a
user update the name in the preference page. To achive this i register a
property change listener who call this method, and then i change it.
Probably you only need the (*) part of this code.
public void updateTitleBar() {
IWorkbenchWindowConfigurer configurer = getWindowConfigurer();
StringBuffer title = new StringBuffer();
IPreferenceStore store = ProyectoJPlugin.getDefault()
.getPreferenceStore();
title.append(store.getString(PreferenceConstants.P_PLATFORM_ NAME)); //(*)
configurer.setTitle(title.toString());
best regards,
toño.
Re: View Title [message #444013 is a reply to message #427799] Wed, 08 February 2006 05:57 Go to previous messageGo to next message
Originally posted by: alexixlebaulois.yahoo.fr
Do you have an example ? I have tried to put this method in my view :
<b>
public void setPartName(String name) {
this.setPartName(name);
</b>
then I opened my view in runtime and called my method :
<b>
ViewPart view = (ViewPart)PlatformUI.getWorkbench().getActiveWorkbenchWindow ().getActivePage().showView(viewID);
view.setPartName(name);
</b>
Nothing happened, so an example would be useful
Re: View Title [message #444022 is a reply to message #444013] Wed, 08 February 2006 08:37 Go to previous messageGo to next message
> <b>
> </b>
This is a recursive call (BAD).
You probably want
super.setPartName(name)
> <b>
> </b>
This code doesn't compile (unless you're in view code), since
ViewPart#setPartName(*) is protected. You would normally check that
it's an instance of your class and then cast it to your view class.
Later,
PW
Re: View Title [message #444170 is a reply to message #444022] Fri, 10 February 2006 05:41 Go to previous message
thank you for your useful advices. It works well now :)
Previous Topic:Launcher is not exported on Linux
Next Topic:Feature List
Current Time: Sat Jul 19 16:33:05 EDT 2025
Powered by FUDForum. Page generated in 0.05554 seconds
