Home » Eclipse Projects » Standard Widget Toolkit (SWT) » SWT-Browser Questions: How can I get the html src content from swt.browser.
SWT-Browser Questions: How can I get the html src content from swt.browser. [message #442655] |
Thu, 09 September 2004 19:44  |
I need to figure out a way to get the source html content from which
swt.browser is viewing.
I can get the location from the LocationEvent.location but you know since
user could already use the browser login into the site and the site could
maintain a login info using cookie and provide a user specific page, so just
using the url can not exactly get the same page the user is navigating.
BTW, I've though it over, and think the IE has a view source pop-up menu and
could get the src the IE is viewing, and I guess it is read a IE caching
local file, if there is a way to let use know which is the caching file of
current browsering it will fix this problem.
Lots of thanks here!
Yi
Long way to go to get Document object from swt.browser! [message #442658 is a reply to message #442655] |
Fri, 10 September 2004 02:50   |
------=_NextPart_000_0026_01C49745.83E24C00
Content-Type: text/plain;
charset="gb2312"
Content-Transfer-Encoding: quoted-printable
I've investaged on this issue. It's much more complecated than i =
imagine.
It is possible to rewrite swt.browser and its internal implementation to =
provide a OLE invocation on IWebBrowser interface.
interface IWebBrowser : IDispatch {
[id(0x000000cb), propget, helpstring("Returns the active =
Document automation object, if any.")]
HRESULT Document([out, retval] IDispatch** ppDisp);
And then will get a pointer point to IHTMLDocument2 Interface:
This interface retrieves information about the document, and examines =
and modifies the HTML elements and text within the document.
Interface Information
Stock Implementation mshtml.dll=20
Custom Implementation No=20
Inherits from IDispatch=20
Header and IDL files Mshtml.h, Mshtml.idl=20
Minimum availability Internet Explorer 4.0=20
Minimum operating systems Windows 95, Windows NT 4.0, Windows CE =
2.12=20
This is anothor OLE object should be written a java wrapper to use it.
And than at this time your could use the following interface to access =
what you want, but it's better to wrap it with a java class.
ProgId=3Dhtmlfile
uuid(332C4425-26CB-11D0-B483-00C04FD90119),
dual
dispinterface IHTMLDocument2 {
properties:
methods:
[id(0x000003e9), propget, hidden]
IDispatch* Script();
[id(0x000003eb), propget]
IHTMLElementCollection* all();
[id(0x000003ec), propget]
IHTMLElement* body();
[id(0x000003ed), propget]
IHTMLElement* activeElement();
[id(0x000003f3), propget]
IHTMLElementCollection* images();
[id(0x000003f0), propget]
IHTMLElementCollection* applets();
[id(0x000003f1), propget]
IHTMLElementCollection* links();
[id(0x000003f2), propget]
IHTMLElementCollection* forms();
[id(0x000003ef), propget]
IHTMLElementCollection* anchors();
[id(0x000003f4), propput]
void title([in] BSTR rhs);
[id(0x000003f4), propget]
BSTR title();
[id(0x000003f5), propget]
IHTMLElementCollection* scripts();
[id(0x000003f6), propput, hidden]
void designMode([in] BSTR rhs);
[id(0x000003f6), propget, hidden]
BSTR designMode();
[id(0x000003f9), propget]
IHTMLSelectionObject* selection();
[id(0x000003fa), propget, bindable]
BSTR readyState();
[id(0x000003fb), propget]
IHTMLFramesCollection2* frames();
[id(0x000003f7), propget]
IHTMLElementCollection* embeds();
[id(0x000003fd), propget]
IHTMLElementCollection* plugins();
[id(0x000003fe), propput]
void alinkColor([in] VARIANT rhs);
[id(0x000003fe), propget]
VARIANT alinkColor();
[id(0xfffffe0b), propput]
void bgColor([in] VARIANT rhs);
[id(0xfffffe0b), propget]
VARIANT bgColor();
[id(0x8001138a), propput]
void fgColor([in] VARIANT rhs);
[id(0x8001138a), propget]
VARIANT fgColor();
[id(0x00000400), propput]
void linkColor([in] VARIANT rhs);
[id(0x00000400), propget]
VARIANT linkColor();
[id(0x000003ff), propput]
void vlinkColor([in] VARIANT rhs);
[id(0x000003ff), propget]
VARIANT vlinkColor();
[id(0x00000403), propget]
BSTR referrer();
[id(0x00000402), propget]
IHTMLLocation* location();
[id(0x00000404), propget]
BSTR lastModified();
[id(0x00000401), propput]
void url([in] BSTR rhs);
[id(0x00000401), propget]
BSTR url();
[id(0x00000405), propput]
void domain([in] BSTR rhs);
[id(0x00000405), propget]
BSTR domain();
[id(0x00000406), propput]
void cookie([in] BSTR rhs);
[id(0x00000406), propget]
BSTR cookie();
[id(0x00000407), propput, bindable, hidden]
void expando([in] VARIANT_BOOL rhs);
[id(0x00000407), propget, bindable, hidden]
VARIANT_BOOL expando();
[id(0x00000408), propput, hidden]
void charset([in] BSTR rhs);
[id(0x00000408), propget, hidden]
BSTR charset();
[id(0x00000409), propput]
void defaultCharset([in] BSTR rhs);
[id(0x00000409), propget]
BSTR defaultCharset();
[id(0x00000411), propget]
BSTR mimeType();
[id(0x00000412), propget]
BSTR fileSize();
[id(0x00000413), propget]
BSTR fileCreatedDate();
[id(0x00000414), propget]
BSTR fileModifiedDate();
[id(0x00000415), propget]
BSTR fileUpdatedDate();
[id(0x00000416), propget]
BSTR security();
[id(0x00000417), propget]
BSTR protocol();
[id(0x00000418), propget]
BSTR nameProp();
[id(0x0000041e), vararg]
void write([in] SAFEARRAY(VARIANT) psarray);
[id(0x0000041f), vararg]
void writeln([in] SAFEARRAY(VARIANT) psarray);
[id(0x00000420)]
IDispatch* open(
[in, optional, defaultvalue("text/html")] BSTR =
url,=20
[in, optional] VARIANT name,=20
[in, optional] VARIANT features,=20
[in, optional] VARIANT replace);
[id(0x00000421)]
void close();
[id(0x00000422)]
void clear();
[id(0x00000423)]
VARIANT_BOOL queryCommandSupported([in] BSTR cmdID);
[id(0x00000424)]
VARIANT_BOOL queryCommandEnabled([in] BSTR cmdID);
[id(0x00000425)]
VARIANT_BOOL queryCommandState([in] BSTR cmdID);
[id(0x00000426)]
VARIANT_BOOL queryCommandIndeterm([in] BSTR cmdID);
[id(0x00000427)]
BSTR queryCommandText([in] BSTR cmdID);
[id(0x00000428)]
VARIANT queryCommandValue([in] BSTR cmdID);
[id(0x00000429)]
VARIANT_BOOL execCommand(
[in] BSTR cmdID,=20
[in, optional, defaultvalue(0)] VARIANT_BOOL =
showUI,=20
[in, optional] VARIANT value);
[id(0x0000042a)]
VARIANT_BOOL execCommandShowHelp([in] BSTR cmdID);
[id(0x0000042b)]
IHTMLElement* createElement([in] BSTR eTag);
[id(0x8001177d), propput, bindable, displaybind]
void onhelp([in] VARIANT rhs);
[id(0x8001177d), propget, bindable, displaybind]
VARIANT onhelp();
[id(0x80011778), propput, bindable, displaybind]
void onclick([in] VARIANT rhs);
[id(0x80011778), propget, bindable, displaybind]
VARIANT onclick();
[id(0x80011779), propput, bindable, displaybind]
void ondblclick([in] VARIANT rhs);
[id(0x80011779), propget, bindable, displaybind]
VARIANT ondblclick();
[id(0x80011776), propput, bindable, displaybind]
void onkeyup([in] VARIANT rhs);
[id(0x80011776), propget, bindable, displaybind]
VARIANT onkeyup();
[id(0x80011775), propput, bindable, displaybind]
void onkeydown([in] VARIANT rhs);
[id(0x80011775), propget, bindable, displaybind]
VARIANT onkeydown();
[id(0x80011777), propput, bindable, displaybind]
void onkeypress([in] VARIANT rhs);
[id(0x80011777), propget, bindable, displaybind]
VARIANT onkeypress();
[id(0x80011773), propput, bindable, displaybind]
void onmouseup([in] VARIANT rhs);
[id(0x80011773), propget, bindable, displaybind]
VARIANT onmouseup();
[id(0x80011772), propput, bindable, displaybind]
void onmousedown([in] VARIANT rhs);
[id(0x80011772), propget, bindable, displaybind]
VARIANT onmousedown();
[id(0x80011774), propput, bindable, displaybind]
void onmousemove([in] VARIANT rhs);
[id(0x80011774), propget, bindable, displaybind]
VARIANT onmousemove();
[id(0x80011771), propput, bindable, displaybind]
void onmouseout([in] VARIANT rhs);
[id(0x80011771), propget, bindable, displaybind]
VARIANT onmouseout();
[id(0x80011770), propput, bindable, displaybind]
void onmouseover([in] VARIANT rhs);
[id(0x80011770), propget, bindable, displaybind]
VARIANT onmouseover();
[id(0x80011789), propput, bindable, displaybind]
void onreadystatechange([in] VARIANT rhs);
[id(0x80011789), propget, bindable, displaybind]
VARIANT onreadystatechange();
[id(0x80011786), propput, bindable, displaybind]
void onafterupdate([in] VARIANT rhs);
[id(0x80011786), propget, bindable, displaybind]
VARIANT onafterupdate();
[id(0x80011782), propput, bindable, displaybind]
void onrowexit([in] VARIANT rhs);
[id(0x80011782), propget, bindable, displaybind]
VARIANT onrowexit();
[id(0x80011783), propput, bindable, displaybind]
void onrowenter([in] VARIANT rhs);
[id(0x80011783), propget, bindable, displaybind]
VARIANT onrowenter();
[id(0x80011793), propput, bindable, displaybind]
void ondragstart([in] VARIANT rhs);
[id(0x80011793), propget, bindable, displaybind]
VARIANT ondragstart();
[id(0x80011795), propput, bindable, displaybind]
void onselectstart([in] VARIANT rhs);
[id(0x80011795), propget, bindable, displaybind]
VARIANT onselectstart();
[id(0x0000042c)]
IHTMLElement* elementFromPoint(
[in] long x,=20
[in] long y);
[id(0x0000040a), propget]
IHTMLWindow2* parentWindow();
[id(0x0000042d), propget]
IHTMLStyleSheetsCollection* styleSheets();
[id(0x80011785), propput, bindable, displaybind]
void onbeforeupdate([in] VARIANT rhs);
[id(0x80011785), propget, bindable, displaybind]
VARIANT onbeforeupdate();
[id(0x80011796), propput, bindable, displaybind]
void onerrorupdate([in] VARIANT rhs);
[id(0x80011796), propget, bindable, displaybind]
VARIANT onerrorupdate();
[id(0x0000042e)]
BSTR toString();
[id(0x0000042f)]
IHTMLStyleSheet* createStyleSheet(
[in, optional, defaultvalue("")] BSTR bstrHref,=20
[in, optional, defaultvalue(-1)] long lIndex);
Content-Type: text/html;
charset="gb2312"
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD>
<META http-equiv=3DContent-Type content=3D"text/html; charset=3Dgb2312">
<META content=3D"MSHTML 6.00.3790.186" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY>
<DIV><FONT size=3D2>I've investaged on this issue. It's much more =
complecated than=20
i imagine.</FONT></DIV>
<DIV><FONT size=3D2></FONT> </DIV>
<DIV><FONT size=3D2>It is possible to rewrite swt.browser and its =
internal=20
implementation to provide a OLE invocation on IWebBrowser=20
interface.</FONT></DIV>
<DIV><FONT size=3D2>interface IWebBrowser : IDispatch {</FONT></DIV>
<DIV><FONT size=3D2>...</FONT></DIV>
<DIV><FONT size=3D2> =
[id(0x000000cb),=20
propget, helpstring("Returns the active Document automation object, if=20
any.")]<BR> HRESULT =
Document([out,=20
retval] IDispatch** ppDisp);</FONT></DIV>
<DIV><FONT size=3D2>}</FONT></DIV>
<DIV><FONT size=3D2>And then will get a pointer point to IHTMLDocument2=20
Interface:</FONT></DIV>
<DIV>
<H1><FONT size=3D2>IHTMLDocument2 Interface</FONT></H1><FONT =
size=3D2></HR></FONT>
<P><FONT size=3D2>This interface retrieves information about the =
document, and=20
examines and modifies the HTML elements and text within the =
document.</FONT></P>
<P>Interface Information</P>
<BLOCKQUOTE>
<TABLE class=3DclsStd>
<TBODY>
<TR>
<TH>Stock Implementation</TH>
<TD><SPAN class=3DclsFmtDLL>mshtml.dll</SPAN></TD></TR>
<TR>
<TH>Custom Implementation</TH>
<TD>No</TD></TR>
<TR>
<TH>Inherits from</TH>
<TD><?XML:NAMESPACE PREFIX =3D MSHelp NS =3D=20
"http://msdn.microsoft.com/mshelp" /><MSHelp:link tabIndex=3D0=20
xmlns:MSHelp=3D"http://msdn.microsoft.com/mshelp"=20
keywords=3D"_com_iunknown_queryinterface"><U><FONT=20
color=3D#0000ff>IDispatch</FONT></U></MSHelp:link></TD> </TR>
<TR>
<TH>Header and IDL files</TH>
<TD><SPAN class=3DclsFmtInc>Mshtml.h</SPAN>, <SPAN=20
class=3DclsFmtIDL>Mshtml.idl</SPAN></TD></TR>
<TR>
<TH>Minimum availability</TH>
<TD>Internet Explorer 4.0</TD></TR>
<TR>
<TH>Minimum operating systems</TH>
<TD>Windows 95, Windows NT 4.0, Windows=20
CE 2.12</TD></TR></TBODY></TABLE></BLOCKQUOTE> </DIV>
<DIV>This is anothor OLE object should be written a java wrapper to use=20
it.</DIV>
<DIV><FONT size=3D2>And than at this time your could use the following =
interface=20
to access what you want, but it's better to wrap it with a java=20
class.</FONT></DIV>
<DIV><FONT size=3D2>ProgId=3Dhtmlfile</FONT></DIV>
<DIV><FONT size=3D2>[<BR> =20
uuid(332C4425-26CB-11D0-B483-00C04FD90119),<BR> =
dual<BR>]<BR>dispinterface=20
IHTMLDocument2 {<BR> properties:<BR> =
methods:<BR> [id(0x000003e9), =
propget,=20
hidden]<BR> IDispatch*=20
Script();<BR> [id(0x000003eb), =
propget]<BR> =
IHTMLElementCollection*=20
all();<BR> [id(0x000003ec),=20
propget]<BR> IHTMLElement*=20
body();<BR> [id(0x000003ed),=20
activeElement();<BR> =
[id(0x000003f3),=20
propget]<BR> =
images();<BR> [id(0x000003f0), =
propget]<BR> =
applets();<BR> =
[id(0x000003f1),=20
propget]<BR> =
links();<BR> [id(0x000003f2),=20
propget]<BR> =
forms();<BR> [id(0x000003ef),=20
propget]<BR> =
anchors();<BR> =
[id(0x000003f4),=20
propput]<BR> void title([in] =
BSTR=20
rhs);<BR> [id(0x000003f4),=20
propget]<BR> BSTR=20
title();<BR> [id(0x000003f5),=20
propget]<BR> =
scripts();<BR> =
[id(0x000003f6),=20
propput, hidden]<BR> void=20
designMode([in] BSTR rhs);<BR> =
[id(0x000003f6), propget, =
hidden]<BR> =20
BSTR designMode();<BR> =20
[id(0x000003f9), propget]<BR> =20
IHTMLSelectionObject* =
selection();<BR> =20
[id(0x000003fa), propget,=20
bindable]<BR> BSTR=20
readyState();<BR> =
[id(0x000003fb),=20
propget]<BR> =
IHTMLFramesCollection2*=20
frames();<BR> [id(0x000003f7), =
propget]<BR> =
embeds();<BR> [id(0x000003fd), =
propget]<BR> =
plugins();<BR> =
[id(0x000003fe),=20
propput]<BR> void =
alinkColor([in]=20
VARIANT rhs);<BR> =
[id(0x000003fe),=20
propget]<BR> VARIANT=20
alinkColor();<BR> =
[id(0xfffffe0b),=20
propput]<BR> void bgColor([in] =
VARIANT=20
rhs);<BR> [id(0xfffffe0b),=20
bgColor();<BR> =
[id(0x8001138a),=20
propput]<BR> void fgColor([in] =
VARIANT=20
rhs);<BR> [id(0x8001138a),=20
fgColor();<BR> =
[id(0x00000400),=20
propput]<BR> void =
linkColor([in]=20
VARIANT rhs);<BR> =
[id(0x00000400),=20
linkColor();<BR> =
[id(0x000003ff),=20
propput]<BR> void =
vlinkColor([in]=20
VARIANT rhs);<BR> =
[id(0x000003ff),=20
vlinkColor();<BR> =
[id(0x00000403),=20
referrer();<BR> =
[id(0x00000402),=20
propget]<BR> IHTMLLocation*=20
location();<BR> =
[id(0x00000404),=20
lastModified();<BR> =
[id(0x00000401),=20
propput]<BR> void url([in] =
BSTR=20
rhs);<BR> [id(0x00000401),=20
url();<BR> [id(0x00000405),=20
propput]<BR> void domain([in] =
BSTR=20
rhs);<BR> [id(0x00000405),=20
domain();<BR> [id(0x00000406), =
propput]<BR> void cookie([in] =
BSTR=20
rhs);<BR> [id(0x00000406),=20
cookie();<BR> [id(0x00000407), =
propput, bindable, hidden]<BR> =
void=20
expando([in] VARIANT_BOOL =
rhs);<BR> =20
[id(0x00000407), propget, bindable,=20
hidden]<BR> VARIANT_BOOL=20
expando();<BR> =
[id(0x00000408),=20
propput, hidden]<BR> void =
charset([in]=20
BSTR rhs);<BR> =
[id(0x00000408),=20
propget, hidden]<BR> BSTR=20
charset();<BR> =
[id(0x00000409),=20
propput]<BR> void =
defaultCharset([in]=20
BSTR rhs);<BR> =
[id(0x00000409),=20
defaultCharset();<BR> =
[id(0x00000411),=20
mimeType();<BR> =
[id(0x00000412),=20
fileSize();<BR> =
[id(0x00000413),=20
fileCreatedDate();<BR> =20
[id(0x00000414), propget]<BR> =
BSTR=20
fileModifiedDate();<BR> =20
[id(0x00000415), propget]<BR> =
BSTR=20
fileUpdatedDate();<BR> =20
[id(0x00000416), propget]<BR> =
BSTR=20
security();<BR> =
[id(0x00000417),=20
protocol();<BR> =
[id(0x00000418),=20
nameProp();<BR> =
[id(0x0000041e),=20
vararg]<BR> void write([in]=20
SAFEARRAY(VARIANT) =
psarray);<BR> =20
[id(0x0000041f), vararg]<BR> =
void=20
writeln([in] SAFEARRAY(VARIANT)=20
psarray);<BR> =20
[id(0x00000420)]<BR> =
IDispatch*=20
open(<BR> &nbs=
p; &nbs p; &nbs p=
;=20
[in, optional, defaultvalue("text/html")] BSTR url,=20
<BR> &nb=
sp; &nb sp; =20
<BR> &nb=
sp; &nb sp; =20
<BR> &nb=
sp; &nb sp; =20
[in, optional] VARIANT =
replace);<BR> =20
[id(0x00000421)]<BR> void=20
close();<BR> =20
[id(0x00000422)]<BR> void=20
clear();<BR> =20
[id(0x00000423)]<BR> =
VARIANT_BOOL=20
queryCommandSupported([in] BSTR=20
cmdID);<BR> =20
[id(0x00000424)]<BR> =
VARIANT_BOOL=20
queryCommandEnabled([in] BSTR=20
cmdID);<BR> =20
[id(0x00000425)]<BR> =
VARIANT_BOOL=20
queryCommandState([in] BSTR=20
cmdID);<BR> =20
[id(0x00000426)]<BR> =
VARIANT_BOOL=20
queryCommandIndeterm([in] BSTR=20
cmdID);<BR> =20
[id(0x00000427)]<BR> BSTR=20
queryCommandText([in] BSTR =
cmdID);<BR> =20
[id(0x00000428)]<BR> VARIANT=20
queryCommandValue([in] BSTR=20
cmdID);<BR> =20
[id(0x00000429)]<BR> =
VARIANT_BOOL=20
execCommand(<BR> &nb=
sp; &nb sp; &nb s=
p; =20
[in] BSTR cmdID,=20
<BR> &nb=
sp; &nb sp; =20
[in, optional, defaultvalue(0)] VARIANT_BOOL showUI,=20
<BR> &nb=
sp; &nb sp; =20
value);<BR> =20
[id(0x0000042a)]<BR> =
VARIANT_BOOL=20
execCommandShowHelp([in] BSTR=20
cmdID);<BR> =20
[id(0x0000042b)]<BR> =
IHTMLElement*=20
createElement([in] BSTR =
eTag);<BR> =20
[id(0x8001177d), propput, bindable,=20
displaybind]<BR> void =
onhelp([in]=20
VARIANT rhs);<BR> =
[id(0x8001177d),=20
propget, bindable, =
displaybind]<BR> =20
VARIANT onhelp();<BR> =
[id(0x80011778),=20
propput, bindable, =
void onclick([in] VARIANT =
rhs);<BR> =20
[id(0x80011778), propget, bindable,=20
displaybind]<BR> VARIANT=20
onclick();<BR> =
[id(0x80011779),=20
void ondblclick([in] VARIANT =
rhs);<BR> =20
[id(0x80011779), propget, bindable,=20
ondblclick();<BR> =
[id(0x80011776),=20
void onkeyup([in] VARIANT =
rhs);<BR> =20
[id(0x80011776), propget, bindable,=20
onkeyup();<BR> =
[id(0x80011775),=20
void onkeydown([in] VARIANT =
rhs);<BR> =20
[id(0x80011775), propget, bindable,=20
onkeydown();<BR> =
[id(0x80011777),=20
void onkeypress([in] VARIANT =
rhs);<BR> =20
[id(0x80011777), propget, bindable,=20
onkeypress();<BR> =
[id(0x80011773),=20
void onmouseup([in] VARIANT =
rhs);<BR> =20
[id(0x80011773), propget, bindable,=20
onmouseup();<BR> =
[id(0x80011772),=20
void onmousedown([in] VARIANT=20
rhs);<BR> [id(0x80011772), =
propget,=20
bindable, displaybind]<BR> =
VARIANT=20
onmousedown();<BR> =
[id(0x80011774),=20
void onmousemove([in] VARIANT=20
rhs);<BR> [id(0x80011774), =
propget,=20
VARIANT=20
onmousemove();<BR> =
[id(0x80011771),=20
void onmouseout([in] VARIANT =
rhs);<BR> =20
[id(0x80011771), propget, bindable,=20
onmouseout();<BR> =
[id(0x80011770),=20
void onmouseover([in] VARIANT=20
rhs);<BR> [id(0x80011770), =
propget,=20
VARIANT=20
onmouseover();<BR> =
[id(0x80011789),=20
void onreadystatechange([in] VARIANT=20
rhs);<BR> [id(0x80011789), =
propget,=20
VARIANT=20
onreadystatechange();<BR> =20
[id(0x80011786), propput, bindable,=20
displaybind]<BR> void=20
onafterupdate([in] VARIANT =
rhs);<BR> =20
[id(0x80011786), propget, bindable,=20
onafterupdate();<BR> =
[id(0x80011782),=20
void onrowexit([in] VARIANT =
rhs);<BR> =20
[id(0x80011782), propget, bindable,=20
onrowexit();<BR> =
[id(0x80011783),=20
void onrowenter([in] VARIANT =
rhs);<BR> =20
[id(0x80011783), propget, bindable,=20
onrowenter();<BR> =
[id(0x80011793),=20
void ondragstart([in] VARIANT=20
rhs);<BR> [id(0x80011793), =
propget,=20
VARIANT=20
ondragstart();<BR> =
[id(0x80011795),=20
void onselectstart([in] VARIANT=20
rhs);<BR> [id(0x80011795), =
propget,=20
VARIANT=20
onselectstart();<BR> =20
[id(0x0000042c)]<BR> =
IHTMLElement*=20
elementFromPoint(<BR> &nbs=
p; &nbs p; &nbs p=
; =20
[in] long x,=20
<BR> &nb=
sp; &nb sp; =20
[in] long y);<BR> =
[id(0x0000040a),=20
propget]<BR> IHTMLWindow2*=20
parentWindow();<BR> =
[id(0x0000042d),=20
propget]<BR> =20
IHTMLStyleSheetsCollection*=20
styleSheets();<BR> =
[id(0x80011785),=20
void onbeforeupdate([in] VARIANT=20
rhs);<BR> [id(0x80011785), =
propget,=20
VARIANT=20
onbeforeupdate();<BR> =
[id(0x80011796),=20
void onerrorupdate([in] VARIANT=20
rhs);<BR> [id(0x80011796), =
propget,=20
VARIANT=20
onerrorupdate();<BR> =20
[id(0x0000042e)]<BR> BSTR=20
toString();<BR> =20
[id(0x0000042f)]<BR> =
IHTMLStyleSheet*=20
createStyleSheet(<BR> &nbs=
p; &nbs p; &nbs p=
; =20
<BR> &nb=
sp; &nb sp; =20
[in, optional, defaultvalue(-1)] long=20
lIndex);<BR>};<BR></FONT></DIV></BODY></HTML>
------=_NextPart_000_0026_01C49745.83E24C00--
Current Time: Sat Jul 19 18:01:49 EDT 2025
Powered by FUDForum. Page generated in 0.03755 seconds
