Home » Eclipse Projects » Standard Widget Toolkit (SWT) » carbon event handling
carbon event handling [message #441622] Tue, 17 August 2004 13:00 Go to next message
Originally posted by: eclipse.physarum.net
--------------080409060703080105070404
Content-Type: text/plain; charset=us-ascii; format=flowed
Hi, I'm wondering if somebody can help:
The code below installs a carbon event handler for mouse-down events,
using native methods from org.eclipse.swt.internal.carbon.*. The strange
thing is that it doesn't seem to receive mouse-down events from
left-clicks (primary button?), but it works for right-clicks.
The reason I'm using carbon events instead of SWT's is that I'm planning
to interface with a mac tablet (wacom) driver, which generates Carbon
tablet events. So I'll be adding constants like:
public static final int kEventClassTablet = ('t'<<24) + ('b'<<16) +
('l'<<8) + 't';
, and use them with OS.InstallEventHandler, etc.
/* snip */
Object target = new Object() {
int mouseProc(int nextHandler, int theEvent, int userData) {
switch (OS.GetEventKind(theEvent)) {
case OS.kEventMouseDown:
System.out.println("Mouse Down");
return OS.eventNotHandledErr;
final Callback mouseCallback = new Callback(target, "mouseProc", 3);
int mouseProc = mouseCallback.getAddress();
if (mouseProc == 0) {
mouseCallback.dispose();
return;
int[] mask = new int[] { OS.kEventClassMouse, OS.kEventMouseDown };
OS.InstallEventHandler(OS.GetApplicationEventTarget(), mouseProc,
mask.length/2, mask, 0, null);
/* snip */
(Full code attached).
stan
Content-Type: text/plain; x-mac-type="0"; x-mac-creator="0";
name="MouseEvents.java"
Content-Disposition: inline;
filename="MouseEvents.java"
import org.eclipse.swt.*;
import org.eclipse.swt.graphics.*;
import org.eclipse.swt.widgets.*;
import org.eclipse.swt.internal.carbon.*;
import org.eclipse.swt.internal.Callback;
public class MouseEvents
public static void main (String[] args)
Display display = new Display();
Shell shell = new Shell(display);
shell.setSize(500, 500);
return;
mouseProc, mask.length/2, mask, 0, null);
shell.open();
while (!shell.isDisposed()) {
if (!display.readAndDispatch())
display.sleep();
display.dispose();
--------------080409060703080105070404--
Re: carbon event handling [message #441626 is a reply to message #441622] Tue, 17 August 2004 16:47 Go to previous messageGo to next message
Try adding the mouse down handler to the window too. I am not sure why,
but I believe this is necessary. See Shell.hookEvents() for an example.
int windowTarget = OS.GetWindowEventTarget (shellHandle);
OS.InstallEventHandler (windowTarget, windowProc, mask1.length / 2, mask1,
shellHandle, null);
int [] mask2 = new int [] {
OS.kEventClassMouse, OS.kEventMouseDown,
OS.kEventClassMouse, OS.kEventMouseDragged,
// OS.kEventClassMouse, OS.kEventMouseEntered,
// OS.kEventClassMouse, OS.kEventMouseExited,
OS.kEventClassMouse, OS.kEventMouseMoved,
OS.kEventClassMouse, OS.kEventMouseUp,
OS.kEventClassMouse, OS.kEventMouseWheelMoved,
OS.InstallEventHandler (windowTarget, mouseProc, mask2.length / 2, mask2,
shellHandle, null);
Silenio
> ('l'<<8) + 't';
> /* snip */
> return;
> /* snip */
> stan
Re: carbon event handling [message #441628 is a reply to message #441626] Tue, 17 August 2004 18:55 Go to previous messageGo to next message
IIRC events propagate from specific to general, so if there's already a
window event handler eating the events you won't see them in the
application handler.
See
http://developer.apple.com/documentation/Carbon/Conceptual/C arbon_Event_Manager/Concept/chapter_17_section_2.html
-- brion vibber (brion @ pobox.com)
Re: carbon event handling [message #441630 is a reply to message #441628] Tue, 17 August 2004 23:38 Go to previous messageGo to next message
Although the second thing that I was about to ask was that:
OS.GetWindowEventTarget(shell.handle)
doesn't seen work (i.e. returns 0), although in Shell.java
(createHandle()), OS.GetWindowEventTarget() clearly gets used on a shell
handle (the result of creating a new window, a local var called
shellHandle). And yes, the value of shell.handle itself seems valid.
stan
> See
Re: carbon event handling [message #441633 is a reply to message #441630] Wed, 18 August 2004 02:42 Go to previous messageGo to next message
Sorry, I forgot to mention that OS.GetControlEventTarget(shell.handle)
seems to work, but when passed to OS.InstallEventHandler, no events seem
to get noticed.
Interestingly, so does doing that to a button, e.g.:
Button button = new Button(shell, SWT.PUSH); button.setText("Push me!");
OS.InstallEventHandler(OS.GetControlEventTarget(button.handl e), ....);
etc.
So, it seems only GetApplicationEventTarget() works...
Any idea?
stan
> stan
Re: carbon event handling [message #441634 is a reply to message #441633] Wed, 18 August 2004 03:08 Go to previous messageGo to next message
You need to pass "shellHandle" (which is a window handle) and not
"shell.handle" (which is a control handle). The problem is that
Shell.shellHandle is not public, but you can get the window handle given a
control handle with the following code:
int control = shell.handle;
int shellHandle = OS.GetControlOwner (control);
Silenio
> > Thanks,
> to get noticed.
> etc.
> Any idea?
> stan
> > Thanks,
> > stan
Re: carbon event handling [message #441636 is a reply to message #441634] Wed, 18 August 2004 03:30 Go to previous message
Thanks!! That fixed everything! =)
stan
> Silenio
>>>Thanks,
>>to get noticed.
>>etc.
>>Any idea?
>>Thanks,
>>stan
>>>Thanks,
>>>stan
Previous Topic:Flash Animation
Next Topic:Embedding MSWord with OLE
Current Time: Sat Jul 19 18:38:10 EDT 2025
Powered by FUDForum. Page generated in 0.06766 seconds
