Home » Eclipse Projects » Standard Widget Toolkit (SWT) » SWT With Applet
SWT With Applet [message #440179] Sat, 24 July 2004 07:21 Go to next message
Hi There,
Does anybody know how to use SWT in applet. Does such a thing is EVER
possible in SWT. There seems to be nothing on the web for it, and neither
on the eclipse site.
Thanks in advance.
Re: SWT With Applet [message #440180 is a reply to message #440179] Sat, 24 July 2004 16:41 Go to previous messageGo to next message
Originally posted by: news.vadalus.com
I have done it and it works fine. You need to sign the applet though.
Basically just hook your eclipse code into the Applet or JApplet init
events and make sure you know how to reference the swt-win32-xxxx.dll
properly--that was the only tricky part.
L
Manohar wrote:
> Hi There,
> Thanks in advance.
Re: SWT With Applet [message #440186 is a reply to message #440180] Mon, 26 July 2004 01:22 Go to previous messageGo to next message
> L
> Manohar wrote:
> > Hi There,
> > Thanks in advance.
hi,
thanks for your information. But what exactly mean by "hooking eclipse
code into the Applet init event and how to reference the .dll file". iam
using GEL editor. do i need to use "Eclipse IDE" only or any IDE. Please
give a detailed information on this if possible send some sample code.
very urgent.
Thanking you.
Re: SWT With Applet [message #440370 is a reply to message #440180] Wed, 28 July 2004 14:41 Go to previous messageGo to next message
Could you please go into details with a basic snippet code for
MyJApplet.java and the page.html to show us how you deal with the dll
loading...
Tnak in advance,
Stephane
> L
> Manohar wrote:
> > Hi There,
> > Thanks in advance.
Re: SWT With Applet [message #440404 is a reply to message #440370] Thu, 29 July 2004 12:50 Go to previous message
OK,
You have the normal life cycle of the applet, start, stop, init,
destroy. I just have start() and stop() doing nothing... I have my
eclipse application referenced inside an applet class.
On init() I:
1. Check to make sure I have not been inited before, throw up an error
if I have
2. Check my security settings, if I am not a signed applet I should exit
3. Parse my applet parameters and pass them to the contained eclipse app
4. Get where my read/writeable temp dir is (defined in "java.io.tmpdir")
5. Check to see whether swt-win32-xxxx.dll exists in this dir.
6. If not download it from my webserver (it's part of the same webapp as
my applet)
7. Call System.load() on the location of the library
8. Finally then fire of a new thread which becomes the Eclipse Event
Dispatcher thread and init your eclipse app in there as you would normally.
9. return from the init() method.
Make sense..?
> loading...
> Tnak in advance,
> Stephane
>>L
>>Manohar wrote:
>>>Hi There,
>>>Thanks in advance.
Previous Topic:Can Eclipse Forms be used OUTSIDE of the workbench environment ?
Next Topic:[Mac 10.3.4] java_swt EXC_BAD_ACCESS Exception
Current Time: Sun Jul 20 02:54:01 EDT 2025
Powered by FUDForum. Page generated in 0.08733 seconds
