Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Using SWT via JNI Invocation on Mac OS X
Using SWT via JNI Invocation on Mac OS X [message #439693] |
Wed, 14 July 2004 14:26  |
Originally posted by: good.dolet.net
We are writing a plug-in for Finale 2004, an application that runs on both
Windows and Macintosh OS X. We want to write the user interface in Java to
keep as much as possible cross-platform. Since Finale is a Carbon
application on OS X, that means we can't use Swing but we should be able to
use SWT.
Finale plug-ins need to be written in C++ to provide Finale with specified
function entry points. So we do the bulk of the plug-in in Java by using the
JNI invocation interface, then using JNI to call back into the Finale
application. (Similar to SWT, our JNI interface back into Finale provides a
thin Java veneer over the native Finale API.)
Since this is a plug-in, not a main application, all we are doing for the
user interface is putting up dialog boxes. Here's the test Java code we're
using. Our real-life examples will be application modal dialogs, not message
boxes, but otherwise not much more complicated:
// Testing use of SWT dialogs within a plug-in
Display display = Display.getDefault();
Shell shell = new Shell(display);
MessageBox mbox = new MessageBox(shell, SWT.ICON_INFORMATION |
SWT.OK);
mbox.setText("Our Finale Plug-In");
mbox.setMessage("This is an SWT message box");
int mboxResult = mbox.open();
shell.dispose();
display.dispose();
On Windows this works fine. On Mac OS X 10.3, the windows appear, but the
main application menu gets zapped as if the shell were creating its own
menu. After the plug-in runs, any use of the GUI crashes Finale. This is
with SWT 3.0.
I suspect this may be related to the need for the java_swt program on OS X
that I have read about on this newsgroup. But as I understand it, this is a
wrapper application, so I don't understand how to invoke it via JNI
invocation's JNI_CreateJavaVM call in C++.
Another possibility is that creating a Shell implies creating a new
top-level window, but all we want are dialog boxes for an existing C++
application and top-level window. But since things work OK on Windows,
java_swt seems the more likely suspect. There are probably other
possibilities for trouble that I have overlooked. Googling for SWT plus JNI
Invocation did not reveal much, and what I did find was Windows-specific.
Any advice as to how to get SWT working on Mac OS X from JNI Invocation
would be most appreciated!
Michael Good
Recordare LLC
www.recordare.com
Re: Using SWT via JNI Invocation on Mac OS X [message #439746 is a reply to message #439693] |
Thu, 15 July 2004 12:24   |
Sounds like there are 2 problems:
1) The menu bar gets zapped as if the shell were creating its own menu
2) Any use of the GUI crashes Finale
I'm not sure what "zapped" means. Does it disappear?
Does Finale do any UI work? Does it run an event loop?
Can you make a simple JNI + SWT program that zaps the menu bar and crashes?
"Michael Good" <good@dolet.net> wrote in message
news:cd3tqk$t67$1@eclipse.org...
to
> use SWT.
the
a
message
> SWT.OK);
> shell.dispose();
> display.dispose();
> with SWT 3.0.
a
JNI
> Michael Good
> Recordare LLC
> www.recordare.com
Re: Using SWT via JNI Invocation on Mac OS X [message #439752 is a reply to message #439746] |
Thu, 15 July 2004 13:16   |
Hi Steve,
Thanks for the reply. Sorry for the unhelpful "zapped" description. When
Finale starts up, the menu bar looks like this:
Apple - Finale 2004b - File - Edit - View - Options - MIDI - Tools -
Window - Plug-ins - Help
Once our SWT dialog box appears, the menu bar looks like this:
Apple - Finale 2004b - Help (grayed out)
It stays like this after our plug-in completes and returns to Finale. When I
try to do any menu choices, either via the menu or keyboard shortcuts,
Finale crashes.
Finale does have its own UI and event loop. We want to supplement the UI
with some modal SWT dialog boxes.
A standalone JNI + SWT program should have it's own menu bar. But in our
case, we don't want ourSWT UI to affect Finale's menu bar at all - we're
just a plug-in. If you still think it would be helpful for diagnosis to try
out the standalone JNI program, please let me know.
Thanks for your help!
Michael Good
Recordare LLC
"Steve Northover" <steve_northover@ca.ibm.com> wrote in message
news:cd6b2b$qak$1@eclipse.org...
crashes?
both
to
> to
> > use SWT.
specified
> the
provides
> a
the
we're
> message
> > SWT.OK);
> > shell.dispose();
> > display.dispose();
the
> > with SWT 3.0.
X
is
> a
> JNI
Windows-specific.
> > Thanks,
> > Michael Good
> > Recordare LLC
> > www.recordare.com
Re: Using SWT via JNI Invocation on Mac OS X [message #439914 is a reply to message #439752] |
Mon, 19 July 2004 12:22   |
You can't have multiple event loops on the Macintosh. Strange things happen
when you do. Not sure how to proceed ...
news:cd6e2i$vr8$1@eclipse.org...
> Hi Steve,
I
> Finale crashes.
try
> Michael Good
> Recordare LLC
> crashes?
> both
Java
> to
able
> > to
> > > use SWT.
> specified
using
> > the
> provides
> > a
> the
> we're
> > message
> > > SWT.OK);
> > > shell.dispose();
> > > display.dispose();
> the
own
is
> > > with SWT 3.0.
OS
> X
> is
> > a
plus
> > JNI
> Windows-specific.
Invocation
> > > Thanks,
> > > Michael Good
> > > Recordare LLC
> > > www.recordare.com
Re: Using SWT via JNI Invocation on Mac OS X [message #440177 is a reply to message #439996] |
Fri, 23 July 2004 19:33  |
The application is not our code - just the plug-in - so we don't get the
chance to rewrite it in Java!
This one plug-in is just a dialog box UI, just in case it had to be done in
C++. But we would like to use the same framework for other larger UIs, and
not have to learn the separate C++ UI tools for Mac and Windows. (This is a
port from Visual Basic, so the Mac stuff is all new to me.) Instead we will
leave the more complex UIs to standalone applications that are all-Java.
Thanks again! We'll certainly be considering SWT for our future standalone
Java apps.
Michael Good
Recordare LLC
Current Time: Sat Jul 19 11:47:48 EDT 2025
Powered by FUDForum. Page generated in 0.06413 seconds
