Home » Eclipse Projects » Standard Widget Toolkit (SWT) » RCP Tutorial - NoClassDefFound
RCP Tutorial - NoClassDefFound [message #439185] |
Tue, 06 July 2004 13:08  |
I'm moving through the 3-part Rich Client Tutorial article by Ed
Burnette...
http://dev.eclipse.org/viewcvs/index.cgi/%7echeckout%7e/org. eclipse.ui.tutorials.rcp.part1/html/tutorial1.html
....and am having trouble running on Linux (Fedora Core 1, Java 1.4.2_04,
Eclipse 3.0). Part 1 of the tutorial essentially creates is a "Hello,
World" for RCP, and runs fine for me on Windows 2000 with the same Eclipse
and Java versions like this..
java -cp startup.jar org.eclipse.core.launcher.Main -application
org.eclipse.ui.tutorials.rcp.part1.RcpApplication
...after exporting the plugin and copying all libraries to the
appropriate directories. However, doing the same thing on Linux (except
for using org.eclipse.swt.gtk_3.0.0 instead of org.eclipse.swt.win32_3.0.0
of course) results in the error below. I've tried explicitly adding
swt.jar and swt-pi.jar to the classpath with the same outcome. (I tried
this because of the "Root exception: java.lang.NoClassDefFoundError:
org/eclipse/swt/widgets/Control" line in the log.)
I'm relatively new to RCP & SWT and greatly appreciate your help. TIA,
Preston
----BEGIN ERROR----
[plee@plee dist]$ cat configuration/1089132956751.log
!SESSION Jul 06, 2004 09:55:57.920 ---------------------------------------------
eclipse.buildId=unknown
java.version=1.4.2_04
BootLoader constants: OS=unknown, ARCH=x86, WS=unknown, NL=en_US
Command-line arguments: -application org.eclipse.ui.tutorials.rcp.part1.RcpApplication
!ENTRY org.eclipse.osgi Jul 06, 2004 09:55:57.922
!MESSAGE An error occured while automatically activating bundle org.eclipse.ui.workbench (12).
!STACK 0
org.osgi.framework.BundleException: Exception in org.eclipse.ui.internal.WorkbenchPlugin.start() of bundle org.eclipse.ui.workbench.
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:975)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:937)
at org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:421)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:293)
at org.eclipse.core.runtime.adaptor.EclipseClassLoader.findLoca lClass(EclipseClassLoader.java:110)
at org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(BundleLoader.java:371)
at org.eclipse.osgi.framework.internal.core.BundleLoader.requir eClass(BundleLoader.java:336)
at org.eclipse.osgi.framework.internal.core.BundleLoader.findRe quiredClass(BundleLoader.java:914)
at org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:399)
at org.eclipse.osgi.framework.adaptor.core.AbstractClassLoader. loadClass(AbstractClassLoader.java:93)
at java.lang.ClassLoader.loadClass(ClassLoader.java:235)
at java.lang.ClassLoader.loadClassInternal(ClassLoader.java:302 )
at java.lang.Class.getDeclaredConstructors0(Native Method)
at java.lang.Class.privateGetDeclaredConstructors(Class.java:16 10)
at java.lang.Class.getConstructor0(Class.java:1922)
at java.lang.Class.newInstance0(Class.java:278)
at java.lang.Class.newInstance(Class.java:261)
at org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:141)
at org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:124)
at org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:113)
at org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:330)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:272)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:128)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:324)
at org.eclipse.core.launcher.Main.basicRun(Main.java:185)
at org.eclipse.core.launcher.Main.run(Main.java:638)
at org.eclipse.core.launcher.Main.main(Main.java:622)
Caused by: java.lang.NoClassDefFoundError: org/eclipse/swt/widgets/Control
at org.eclipse.ui.plugin.AbstractUIPlugin.refreshPluginActions( AbstractUIPlugin.java:795)
at org.eclipse.ui.plugin.AbstractUIPlugin.start(AbstractUIPlugi n.java:897)
at org.eclipse.ui.internal.WorkbenchPlugin.start(WorkbenchPlugi n.java:619)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl$1 .run(BundleContextImpl.java:958)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:954)
... 29 more
Root exception:
!ENTRY org.eclipse.osgi Jul 06, 2004 09:55:57.925
!MESSAGE Application error
!STACK 1
java.lang.NoClassDefFoundError: org/eclipse/ui/application/WorkbenchAdvisor
----END ERROR----
Re: RCP Tutorial - NoClassDefFound [message #439201 is a reply to message #439185] |
Wed, 07 July 2004 02:39   |
Somehow I'm glad to see that I'm not alone with this problem (Eclipse 3.0
SuSE 9.1 + Gtk).
Though the ClassDefNotFoundError says org/eclipse/swt/widgets/Synchronizer
in my case.
Any solutions?
Stefan
"Preston Lee" <plee@unicon.net> wrote in message
news:pan.2004.07.06.17.08.28.481493@unicon.net...
> Burnette...
> Preston
> ----BEGIN ERROR----
> !STACK 0
> at
> at
xtImpl.java:937)
> at
ava:421)
> at
..java:293)
> at
assLoader.java:110)
> at
oader.java:371)
> at
der.java:336)
> at
leLoader.java:914)
> at
..java:399)
> at
> at
> at
> at
> at
java:330)
> at
> at
> at
> at
..java:25)
> at
..java:795)
> at
> at
> at
xtImpl.java:958)
> at java.security.AccessController.doPrivileged(Native Method)
> at
> ... 29 more
> Root exception:
> at
..java:795)
> at
> at
> at
xtImpl.java:958)
> at
> at
xtImpl.java:937)
> at
ava:421)
> at
..java:293)
> at
assLoader.java:110)
> at
oader.java:371)
> at
der.java:336)
> at
leLoader.java:914)
> at
..java:399)
> at
> at
> at
> at
> at
java:330)
> at
> at
> at
> at
..java:25)
> !STACK 1
> at
> at
> at
> at
java:330)
> at
> at
> at
> at
..java:25)
> ----END ERROR----
Re: RCP Tutorial - NoClassDefFound [message #439238 is a reply to message #439201] |
Wed, 07 July 2004 22:35   |
Well, I know some people have it working on Linux under GTK but it seems to
be a little tricky. You need to have that extra swt-pi jar file, which you
apparently already have, and one person reported they had to add some java
command line options (-os linux -ws gtk -arch x86 -nl en_US, see
http://sourceforge.net/mailarchive/message.php?msg_id=863861 4). Another said
that 1.4.2 was required, which you already have. I'll copy this to the
eclipsepowered list to see if anybody there has any other advice.
Also see the instructions for launching the RCP Browser example at
http://dev.eclipse.org/viewcvs/index.cgi/~checkout~/platform -ui-home/rcp/index.html .
That might work better than running java directly. Let us know what worked
for you.
Ed Burnette, co-author, Eclipse in Action
www.eclipsepowered.org
"Stefan Krause" <Stefan.Krause@gmx.atnospam> wrote in message
news:ccg5qb$qdj$1@eclipse.org...
> SuSE 9.1 + Gtk).
> in my case.
> Any solutions?
> Stefan
> > Burnette...
Eclipse
> > Preston
> > ----BEGIN ERROR----
> > !STACK 0
> > at
> > at
> xtImpl.java:937)
> > at
> ava:421)
> > at
> .java:293)
> > at
> assLoader.java:110)
> > at
> oader.java:371)
> > at
> der.java:336)
> > at
> leLoader.java:914)
> > at
> .java:399)
> > at
> > at
> > at
> > at
> > at
> > at
> java:330)
> > at
> > at
> > at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
> > at
> > at
> .java:25)
> > at
> .java:795)
> > at
> > at
> > at
> xtImpl.java:958)
> > at
> > ... 29 more
> > Root exception:
> > at
> .java:795)
> > at
> > at
> > at
> xtImpl.java:958)
> > at
> > at
> xtImpl.java:937)
> > at
> ava:421)
> > at
> .java:293)
> > at
> assLoader.java:110)
> > at
> oader.java:371)
> > at
> der.java:336)
> > at
> leLoader.java:914)
> > at
> .java:399)
> > at
> > at
> > at
> > at
> > at
> > at
> java:330)
> > at
> > at
> > at
> > at
> .java:25)
> > !STACK 1
> > at
> > at
> > at
> > at
> > at
> java:330)
> > at
> > at
> > at
> > at
> .java:25)
> > ----END ERROR----
Re: RCP Tutorial - NoClassDefFound [message #439307 is a reply to message #439201] |
Fri, 09 July 2004 02:08   |
> SuSE 9.1 + Gtk).
> in my case.
> Any solutions?
> Stefan
>>Burnette...
>>Preston
>>----BEGIN ERROR----
>>!STACK 0
>> at
>> at
> xtImpl.java:937)
>> at
> ava:421)
>> at
> .java:293)
>> at
> assLoader.java:110)
>> at
> oader.java:371)
>> at
> der.java:336)
>> at
> leLoader.java:914)
>> at
> .java:399)
>> at
>> at
>> at
>> at
>> at
> java:330)
>> at
>> at
>> at
>> at
> .java:25)
>> at
> .java:795)
>> at
>> at
>> at
> xtImpl.java:958)
>> at
>> ... 29 more
>>Root exception:
>> at
> .java:795)
>> at
>> at
>> at
> xtImpl.java:958)
>> at
>> at
> xtImpl.java:937)
>> at
> ava:421)
>> at
> .java:293)
>> at
> assLoader.java:110)
>> at
> oader.java:371)
>> at
> der.java:336)
>> at
> leLoader.java:914)
>> at
> .java:399)
>> at
>> at
>> at
>> at
>> at
> java:330)
>> at
>> at
>> at
>> at
> .java:25)
>>!STACK 1
>> at
>> at
>> at
>> at
> java:330)
>> at
>> at
>> at
>> at
> .java:25)
>>----END ERROR----
I assume some people try to play with Eclipse and Rich Client Platform,
especially through reading "Rich Client Tutorial Part 1".
The example source codes "Part 1,2, 3" all work when you build it in the
Eclipse environment.
But how to get it working on the command line?
The author, Ed Burnette, gave the script for windows. But for linux
platform, Ed just ignored it. Ed only suggested it should be very
similiar. But if you try to copy and run it, it does not work. You are
then in blue.
I tried randomly. I added some options. Then luckily it works. I then
can continue the Tutorial Part 2 amd Part 3.
That is the trial:
// Command line
sh-2.05b$ java -cp ../startup.jar org.eclipse.core.launcher.Main
-application org.eclipse.ui.tutorials.rcp.part1.RcpApplication -os linux
-ws gtk -arch x86 -nl en_US -clean -consoleLog
// where am I ?
sh-2.05b$ pwd
/home/tzhou/RCP/plugins
// List what have you copied
sh-2.05b$ ls
org.eclipse.core.expressions_3.0.0
org.eclipse.osgi_3.0.0
org.eclipse.ui.workbench_3.0.0
org.eclipse.core.runtime_3.0.0
org.eclipse.ui_3.0.0
org.eclipse.help_3.0.0
org.eclipse.swt_3.0.0
org.eclipse.update.configurator_3.0.0
org.eclipse.jface_3.0.0
org.eclipse.ui.tutorials.rcp.part1_1.0.0
workspace
// List upper directory
sh-2.05b$ ls -a ..
.. .. configuration plugins startup.jar
From the above, you get the idea the directory structure and which
plugin should be there. Becareful the java classpath.
Hopefully it help you out and save you time and have a good day.
Ted Zhou
Re: RCP Tutorial - NoClassDefFound [message #439346 is a reply to message #439307] |
Sun, 11 July 2004 11:45   |
Thanks it started to work for me as soon as I added both -os linux and
-ws gtk !
>> SuSE 9.1 + Gtk).
>> in my case.
>> Any solutions?
>> Thanks,
>> Stefan
>>> Burnette...
>>> Eclipse
>>> Preston
>>> ----BEGIN ERROR----
>>> !STACK 0
>>> at
>>> at
>> xtImpl.java:937)
>>> at
>> ava:421)
>>> at
>> .java:293)
>>> at
>> assLoader.java:110)
>>> at
>> oader.java:371)
>>> at
>> der.java:336)
>>> at
>> leLoader.java:914)
>>> at
>> .java:399)
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>> java:330)
>>> at
>>> at
>>> at
>>> at
>> .java:25)
>>> at
>> .java:795)
>>> at
>>> at
>>> at
>> xtImpl.java:958)
>>> at
>>> ... 29 more
>>> Root exception:
>>> at
>> .java:795)
>>> at
>>> at
>>> at
>> xtImpl.java:958)
>>> at
>>> at
>> xtImpl.java:937)
>>> at
>> ava:421)
>>> at
>> .java:293)
>>> at
>> assLoader.java:110)
>>> at
>> oader.java:371)
>>> at
>> der.java:336)
>>> at
>> leLoader.java:914)
>>> at
>> .java:399)
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>> java:330)
>>> at
>>> at
>>> at
>>> at
>> .java:25)
>>> !STACK 1
>>> at
>>> at
>>> at
>>> at
>>> at
>> java:330)
>>> at
>>> at
>>> at
>>> at
>> .java:25)
>>> ----END ERROR----
> then in blue.
> That is the trial:
> // Command line
> // where am I ?
> sh-2.05b$ pwd
> sh-2.05b$ ls
> org.eclipse.swt_3.0.0 org.eclipse.update.configurator_3.0.0
> org.eclipse.jface_3.0.0 org.eclipse.ui.tutorials.rcp.part1_1.0.0
> workspace
> sh-2.05b$ ls -a ..
> Ted Zhou
Re: RCP Tutorial - NoClassDefFound [message #439516 is a reply to message #439307] |
Mon, 12 July 2004 22:24  |
Ok, I just added some notes about the suggested options for Linux and MacOS
to the first tutorial. Thanks for the info.
Ed
"Ted" <ted@x.y.z.com> wrote in message news:cclcnk$djq$1@eclipse.org...
> then in blue.
Current Time: Sun Jul 20 08:19:22 EDT 2025
Powered by FUDForum. Page generated in 0.05320 seconds
