Home » Eclipse Projects » Standard Widget Toolkit (SWT) » How to have window always on top of another
How to have window always on top of another [message #438937] Mon, 05 July 2004 10:34 Go to next message
Originally posted by: yuraukar.hotmail.com
I am trying to achieve something like
a floating property window. This should
always be on top of its parent shell,
but of course not on top of other windows.
What is the recommended style of doing this
with SWT?
I tried to create a shell with given parent,
but this seems to have no effect.
Yuraukar
Re: How to have window always on top of another [message #438939 is a reply to message #438937] Mon, 05 July 2004 11:08 Go to previous messageGo to next message
Try SWT.APPLICATION_MODAL
While digging in that doc, look at other modal models
as well.
> with SWT?
> Yuraukar
Re: How to have window always on top of another [message #439175 is a reply to message #438939] Tue, 06 July 2004 11:13 Go to previous messageGo to next message
No, this doesn't do the trick.
SWT.APPLICATION_MODAL displays the shell, but
no other window can be activated (that's what
modal means in general). SWT.SYSTEM_MODAL
doesn't let the user select a different window
of any other app. I therefore want a modeless
window/dialog.
SWT.ON_TOP almost does the trick, but the
window is on top of all windows - windows other
than the parent should hide the floating propery
window.
I don't see any effect on SWT.PRIMARY_MODAL (at
least not on Windows).
Any other ideas?
Yuraukar.
> as well.
>>with SWT?
>>Yuraukar
Re: How to have window always on top of another [message #439179 is a reply to message #439175] Tue, 06 July 2004 12:21 Go to previous message
Use new Shell(Shell, int). That will create a dialog shell that stays on
top of the parent shell.
"Yuraukar" <yuraukar@hotmail.com> wrote in message
news:ccefgq$ebd$1@eclipse.org...
> window/dialog.
> window.
> Any other ideas?
> Thanks
> Yuraukar.
> > as well.
> >>with SWT?
> >>Yuraukar
Previous Topic:TableViewer jumping to next column using TAB-Key
Next Topic:Add controls after shell open...
Current Time: Sat Jul 19 06:32:16 EDT 2025
Powered by FUDForum. Page generated in 0.24200 seconds
