Home » Eclipse Projects » Standard Widget Toolkit (SWT) » threading problem with TableTreeViewer.refresh()
threading problem with TableTreeViewer.refresh() [message #439119] Tue, 06 July 2004 05:06 Go to next message
Originally posted by: lshan.imail.eecs.berkeley.edu
I wondering in what thread should i call TableTreeViewer.refresh().
Following the source code, the refresh() eventually calls the following
method in Widget class to do the thread checking. If the thread that calls
refresh() is the correct thread, it issues invalid access error.
protected void checkWidget () {
Display display = this.display;
if (display.thread != Thread.currentThread ()) error
(SWT.ERROR_THREAD_INVALID_ACCESS);
I am implementing a listener and want to call TableTreeViewer.refresh() when
something changes in my model. What's the correct way to make such a call?
Thanks a million.
Lexin Shan
Re: threading problem with TableTreeViewer.refresh() [message #439170 is a reply to message #439119] Tue, 06 July 2004 10:10 Go to previous message
Originally posted by: richkulp.NO.SPAM.us.ibm.com
This means you are calling from some thread other then the display
thread. If you are not on the display thread, you need to use
Display.asyncExec() or Display.syncExec() to get the refresh() to be
called on the display thread.
Thanks, Rich Kulp
Previous Topic:No more handles error
Next Topic:WebStart?
Current Time: Sat Jul 19 22:30:25 EDT 2025
Powered by FUDForum. Page generated in 0.03931 seconds
