Home » Eclipse Projects » Standard Widget Toolkit (SWT) » SWT Thread problem under Linux (GTK)
SWT Thread problem under Linux (GTK) [message #437646] Wed, 09 June 2004 09:22 Go to next message
I'm dealing with an SWT Exception under Linux (gtk):
I need to create a new display object in a different thread to show a
download progress bar. Every 500ms the progress bar needs to be
refreshed....
public class DownloadProgressThread extends Thread {
public void run() {
Display display = new Display();
Shell s = new Shell(display);
display.timerExec(500,new Runnable() {
public void run() {
startRefresh();
public void startRefresh() {
public void run() {
startRefresh();
During the process the main UI-Thread (related to the thread of the
principal Display) throws an "Invalid Thread Access" SWTException and dies.
org.eclipse.swt.SWTException: Invalid thread access
at org.eclipse.swt.SWT.error(SWT.java:2689)
at org.eclipse.swt.SWT.error(SWT.java:2614)
at org.eclipse.swt.SWT.error(SWT.java:2585)
at org.eclipse.swt.widgets.Widget.error(Widget.java:374)
at org.eclipse.swt.widgets.Widget.checkWidget(Widget.java:311)
at org.eclipse.swt.widgets.Control.getShell(Control.java:1597)
at org.eclipse.swt.widgets.Control.getPath(Control.java:1566)
at org.eclipse.swt.widgets.Shell.setActiveControl(Shell.java:86 6)
at org.eclipse.swt.widgets.Control.sendFocusEvent(Control.java: 2196)
at org.eclipse.swt.widgets.Control.gtk_event_after(Control.java :1717)
at org.eclipse.swt.widgets.Widget.windowProc(Widget.java:1189)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:3040 )
at org.eclipse.swt.internal.gtk.OS.gtk_main_do_event(Native Method)
at org.eclipse.swt.widgets.Display.eventProc(Display.java:839)
at org.eclipse.swt.internal.gtk.OS.gtk_main_iteration(Native Method)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2252)
at
it.symlabs.sato.client.fileshare.SWTMainPanel.showGUI(SWTMai nPanel.java:288)
at it.symlabs.sato.client.fileshare.SWTMainPanel.main(SWTMainPa nel.java:266)
Why does it access to the display of the main composite, if I create a
new one?
I've tested the application under Windows and works fine.
Maybe it's a bug of the Display implementation under Linux-GTK. It seems
like events destinated to the second thread/Display are dispatched to
the first thread/Display, which tries to access the controls of the
other thread/Display and throws the exception.
Anyone has encountred the same problem? Any ideas?
Thanks in advance.
Maurizio Pillitu
Re: SWT Thread problem under Linux (GTK) [message #437726 is a reply to message #437646] Wed, 09 June 2004 13:01 Go to previous messageGo to next message
Are multiple displays supported under GTK? I'm not sure about that..
Also, why do you need to open up a second display just to show a progress
dialog?
This progress dialog will not be owned by the main window of your app.
Can't you just periodically call
display.asynchExec(update-the-progress-of-your-bar) from the worker thread,
where 'display' is the display object of your main thread?
Ivan
"Maurizio Pillitu" <m.pillitu@symlabs.it> wrote in message
news:ca6r4h$uc7$1@eclipse.org...
> refreshed....
> public void run() {
> public void run() {
> startRefresh();
> public void run() {
> startRefresh();
dies.
> at
> at
> new one?
> Thanks in advance.
> Maurizio Pillitu
Re: SWT Thread problem under Linux (GTK) [message #437729 is a reply to message #437726] Wed, 09 June 2004 15:51 Go to previous messageGo to next message
It's a good question; really I don't know... I must read the GTK
documentation.
> dialog?
No, because I need to block the main thread; I've to realize a long
running operation that cannot be transferred to another thread because
draws on the main window.
Maurizio Pillitu
> Regards,
> Ivan
>>Hi,
>>refreshed....
>>public void run() {
>> public void run() {
>> startRefresh();
>> public void run() {
>> startRefresh();
> dies.
>>at
>>at
>>new one?
>>Thanks in advance.
>> Maurizio Pillitu
Re: SWT Thread problem under Linux (GTK) [message #437731 is a reply to message #437729] Wed, 09 June 2004 15:10 Go to previous messageGo to next message
progress
> > dialog?
thread,
I don't quite understand that. What do you mean by 'I need to block the main
thread'?
Do you mean that ***at the same time while the worker thread is running your
operation*** the main thread also does something CPU intensive, like drawing
all the time, not in onPaint()?
I don't believe this is the case. Could you elaborate a bit?
Re: SWT Thread problem under Linux (GTK) [message #437778 is a reply to message #437731] Thu, 10 June 2004 06:20 Go to previous messageGo to next message
> thread'?
Hi Ivan, thanks for your interest on our problem.
The problem is that we have a single Thread, called "main", that handles
the SWT interface with the common :
shell.open();
while (!shell.isDisposed()) {
if (!display.readAndDispatch())
display.sleep();
At a certain point the user press on a button, and we start drawing on a
canvas. This is fine as long as the operation is relatively short. Due
to the impossibility to access to the canvas from another thread, and by
the fact that data are generated by an external library to which we
don't have source access, we cannot move this operation on a different
thread. Even worse, since the UI interface has been designed and
approved by the various steps of committers we cannot change it.
So we thought to launch another thread, create a new display, open a new
shell, and display a progress bar and some other informations calling
timerExec to periodically redraw :
public class ProgressThread extends Thread {
public void run() {
try {
Shell shell = new Shell(display);
ProgressWidnow progressWindow = new ProgressWindow(shell, SWT.NULL);
shell.setLayout(new org.eclipse.swt.layout.FillLayout());
Rectangle shellBounds = shell.computeTrim(0,0,246,151);
shell.setSize(shellBounds.width, shellBounds.height);
shell.open();
shell.forceActive();
display.sleep();
} catch (Exception e) {
e.printStackTrace();
This way we should have a second thread ruuning SWT. Teorically, events
for the main window should be received and dispatched by the main
thread, that owns that Display, while events for the progress window
should be received and dispatched by the second thread, that owns the
second Display. This is true in windows, and it works perfectly, but
seems that it's not true under linux GTK.
In Linux events for the progress window arrive to the main thread, and
from there it tries to access the controls owned by the second thread
throwing IllegalThreadAccess exceptions.
Any idea?
Ciao,
Simone Gianni
Re: SWT Thread problem under Linux (GTK) [message #437781 is a reply to message #437778] Thu, 10 June 2004 07:35 Go to previous messageGo to next message
Hi Simone,
Thanks for the thoroughful explanation.
Just wanted to mention that you are actually _allowed_ to draw on a canvas,
owned by the event lop ("main") thread from another thread.
You can create a 'new GC(canvas-object)' in the main thread, pass this to
the background thread and then call methods on the GC from the background
thread. I learned this just recently, when my own SWT port started to fail
with recent Eclipse3 milestone.. Note: only draws are allowed, i.e. methods
on GC/Image.
Seems so, but I'm in no way expert in SWT/GTK.
It hink this question deserves attention from Steve Northover or some of the
other SWT developers.
Maybe you could ping these guys on the platform-swt-dev mailing list (which
is otherwise for SWT development topics only), to get their attention on
your problem.
It is really strange that you are actually able to process these events in
the main thread at all..
You said it was busy drawing, right? So it is not running its event loop...
Anyways, if only you could figure out how to call into the 3rd party lib
from the background thread, this may solve the problem, bc as I said - draws
from a background thread are allowed..
Ivan
Re: SWT Thread problem under Linux (GTK) [message #438442 is a reply to message #437646] Thu, 24 June 2004 08:29 Go to previous messageGo to next message
Nothing to do with your primary problem, but,
won't you have an "stack overflow" problem since startRefresh
calls itself several times?
iran
> public void run() {
> public void run() {
> startRefresh();
> public void run() {
> startRefresh();
Re: SWT Thread problem under Linux (GTK) [message #438567 is a reply to message #438442] Sun, 27 June 2004 19:43 Go to previous messageGo to next message
No, it's not calling itself, it tells the Display thread to call the
function again after 500 milliseconds, and so on, and so on, so the
stack is never overflowed.
Ciao,
Simone Gianni
> iran
>>public void run() {
>> public void run() {
>> startRefresh();
>> public void run() {
>> startRefresh();
Re: SWT Thread problem under Linux (GTK) [message #438670 is a reply to message #437646] Tue, 29 June 2004 12:51 Go to previous messageGo to next message
I am having a similar problem.
However, mine is with changing text in a text field from a thread.
A bit of investigation found this message on the Widget class in the
javadoc:
"It is also an error to call widget methods from any thread that is
different from the thread that created the widget."
I guess I need to put a loop and listener in the parent thread after
starting the child thread just to change a bit of text.
Kind of sucks but, I shall persist.
> refreshed....
> public void run() {
> public void run() {
> startRefresh();
> public void run() {
> startRefresh();
> dies.
> at
> at
> new one?
> Thanks in advance.
> Maurizio Pillitu
Re: SWT Thread problem under Linux (GTK) [message #438674 is a reply to message #438670] Tue, 29 June 2004 14:05 Go to previous message
I'm posting this in case others might find it useful.
Further digging finds the
Display.asyncExec(Runnable) method.
Javadocs are a wonderful thing.
This solved my problem.
> javadoc:
>> Hi,
>> refreshed....
>> public void run() {
>> public void run() {
>> startRefresh();
>> public void run() {
>> startRefresh();
>> dies.
>> at
>> at
>> new one?
>> Thanks in advance.
>> Maurizio Pillitu
Previous Topic:RCP question: how to fill the Perspective Bar with all the perspectives
Next Topic:swt 3.0 full support for mac osx?
Current Time: Sat Jul 19 21:59:34 EDT 2025
Powered by FUDForum. Page generated in 0.07532 seconds
