Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Linux - TabFolder Traversal using keyboard
Linux - TabFolder Traversal using keyboard [message #437611] Tue, 08 June 2004 17:15 Go to next message
I can't do tabfolder traversal using keyboard arrow keys in linux. Running
Eclipse 3.0RC1 GTK. But CTabFolder works fine.
Any ideas ?
SS
Re: Linux - TabFolder Traversal using keyboard [message #437651 is a reply to message #437611] Wed, 09 June 2004 09:36 Go to previous messageGo to next message
Use CTRL+PageDown and CTRL+PageUp to traverse between adjacent tabs, and
Home/End to go to the first/last tab.
"ss" <storaskar@xx.xxx.xxx> wrote in message
news:ca5a8n$deg$1@eclipse.org...
> Any ideas ?
> SS
Re: Linux - TabFolder Traversal using keyboard [message #437725 is a reply to message #437651] Wed, 09 June 2004 12:31 Go to previous messageGo to next message
CTRL+PageUP and CTRL+PageDown works fine if you just have one set of tabs.
I actually have CTabFolder on the outer layer and have TabFolder inside
that.
Even if focus is on TabFolder, CTRL+PageUP and CTRL+PageDown seems to work
on outer layer of CTabFolder. But Home/End does work on TabFolder itself.
Shouldn't it be consistent ? Is this a bug ?
Any ideas ??
SS
> > Any ideas ?
> > SS
Re: Linux - TabFolder Traversal using keyboard [message #437789 is a reply to message #437725] Thu, 10 June 2004 10:23 Go to previous messageGo to next message
That behaviour sounds strange. Please log a bug report with Platform - SWT
and include a stand-alone code snippet that shows the problem. Thanks.
Grant
"SS" <storaskar@xx.xxx.xxx> wrote in message
news:ca7e1c$o4d$1@eclipse.org...
> that.
> Any ideas ??
> SS
Running
> > > Any ideas ?
> > > SS
Re: Linux - TabFolder Traversal using keyboard [message #437795 is a reply to message #437789] Thu, 10 June 2004 13:01 Go to previous message
Bug #
https://bugs.eclipse.org/bugs/show_bug.cgi?id=66433
> Grant
> > that.
> > Any ideas ??
> > SS
> Running
> > > > Any ideas ?
> > > > SS
Previous Topic:Remove a singe Item from a TableTree
Next Topic:JVMCI161: FATAL ERROR in native method: Out of memory when....
Current Time: Sat Jul 19 22:34:49 EDT 2025
Powered by FUDForum. Page generated in 0.03656 seconds
