Home » Eclipse Projects » Rich Client Platform (RCP) » Splash works after export, but not from within IDE
Splash works after export, but not from within IDE [message #437542] |
Thu, 29 September 2005 16:35  |
My RCP product (plug-in based, not feature based) defines
osgi.splashPath in my config.ini, and I have a splash.bmp in the root
directory of my plug-in. When I export the product and run it
standalone, the splash screen works as expected. When I run from the
Eclipse IDE, however, the splash screen does not show.
I've tried copying the splash.bmp to various directories - the eclipse
directory, the runtime directory, the directory that the config.ini is
loaded from, etc, without any luck.
I turned on tracing for org.eclipse.core.runtime, and it shows "Splash
Does anyone have any idea why this might be happening, or pointers on
where to look next?
Josh
Re: Splash works after export, but not from within IDE [message #437741 is a reply to message #437542] |
Mon, 03 October 2005 16:09   |
Here's something to check before you run your product within the IDE...
In the Run configuration on the Main tab, ensure that 'Run a product' is
selected under the 'Program to Run' group, and make sure your product is
selected.
Mike S.
J wrote:
> location: null".
> where to look next?
> Josh
Re: Splash works after export, but not from within IDE [message #437746 is a reply to message #437741] |
Mon, 03 October 2005 17:39   |
Hi Mike,
Thanks - But, I am running the product - in fact, other branding aspects
such as the About dialog work perfectly.
Josh
> selected.
> Regards,
> Mike S.
> J wrote:
>> Hi,
>> location: null".
>> where to look next?
>> Thanks,
>> Josh
Re: Splash works after export, but not from within IDE [message #437923 is a reply to message #437542] |
Thu, 06 October 2005 22:54   |
Look at the command line that PDE generates (can be seen in the debug view
by right-clicking on the process). Could it be that PDE generates a
config.ini file, and that your config.ini is not being used?
Boris
"J" <snark@slunk.net> schrieb im Newsbeitrag
news:dhhj6k$u4h$1@news.eclipse.org...
> My RCP product (plug-in based, not feature based) defines osgi.splashPath
> in my config.ini, and I have a splash.bmp in the root directory of my
> plug-in. When I export the product and run it standalone, the splash
> screen works as expected. When I run from the Eclipse IDE, however, the
> location: null".
> where to look next?
> Josh
Re: Splash works after export, but not from within IDE [message #437933 is a reply to message #437923] |
Fri, 07 October 2005 13:40  |
Good idea, but actually it turned out to be the opposite - I was using
my own config.ini, with my own osgi.splashPath in it. As soon as I got
rid of that and let the PDE workbench generate the config.ini (which
upon investigation doesn't have osgi.splashPath in it at all), it worked
fine.
Josh
> Boris
>> Hi,
>> location: null".
>> where to look next?
>> Thanks,
>> Josh
Current Time: Sun Jul 20 03:31:48 EDT 2025
Powered by FUDForum. Page generated in 0.23972 seconds
