Home » Eclipse Projects » Standard Widget Toolkit (SWT) » TreeViewer
TreeViewer [message #436407] Tue, 18 May 2004 14:42 Go to next message
Originally posted by: christian_mangeot.ibi.com
Couls someone point me to a working TreeViewer example that works stand
alone (outside the plug-in context). The example given in the article
section is plug-in based, and the example given in the IBM site gives a
stack trace.
Thanks.
Re: TreeViewer [message #436408 is a reply to message #436407] Tue, 18 May 2004 14:46 Go to previous messageGo to next message
> stack trace.
TreeViewer is no SWT but a JFace based class, you cannot use it in a SWT
only application. The rich client platform ( RCP ) might be a sollution
for you, the other one is to write your own wrapper around
org.eclipse.swt.widgets.Tree class.
Henning Rogge.
Re: TreeViewer [message #436805 is a reply to message #436408] Mon, 24 May 2004 17:08 Go to previous messageGo to next message
Henning,
This isn't quite right. TreeViewer is a JFace based class, but you
can certainly use JFace based classes in a standalone application.
I am using Jface and SWT myself in a standalone application.
See
http://www-106.ibm.com/developerworks/java/library/os-ecgui1 /
for a tutorial in three parts that uses SWT and JFACE in a standalone
application.
Jos Warmer
On Tue, 18 May 2004 20:46:37 +0200, Henning Rogge <HRogge@gmx.net>
>> stack trace.
>Henning Rogge.
Re: TreeViewer [message #436808 is a reply to message #436805] Mon, 24 May 2004 17:40 Go to previous messageGo to next message
Jos Warmer wrote:
> Henning,
> See
> application.
> Jos Warmer
Ahh okay. I though there were links between the JFace classes and some
of the basic runtime routines... seems they were killed in the same
process that made RCP possible.
Henning Rogge.
Re: TreeViewer [message #437426 is a reply to message #436408] Fri, 04 June 2004 08:11 Go to previous message
Originally posted by: olivier.larivain.criltechnology.com
I don't think so, I use a TreeViewer in my SWT stand alone application
without any problem..
I'll try and post a snippet of my code if you still need it
"Henning Rogge" <HRogge@gmx.net> a
Previous Topic:ANN: article "Java 2D imaging for the Standard Widget Toolkit"
Next Topic:TableTreeItem - changing fonts
Current Time: Sun Jul 20 03:23:54 EDT 2025
Powered by FUDForum. Page generated in 0.04822 seconds
