Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Virtual Table Slow
Virtual Table Slow [message #437303] Wed, 02 June 2004 17:05 Go to next message
HI,
I am using a virtual table, I thought in the same way as the snippet:
http://dev.eclipse.org/viewcvs/index.cgi/%7Echeckout%7E/plat form-swt-home/snippits/snippet144.html
But when I open the editor that contains the table, everything slows down quite
a bit. The table displays after the snippet below reports the the first 2000
rows populated, but it continues to call handleEvent, and is sucking up CPU.
Should it be doing this even though these rows are not visible?
Also, the performance degrades with time; the first items are taking 3 seconds
per thousand rows. By the time it is halfway done it is taking 15 seconds per
1000 rows. I have checked and the perfomance degredation is coming form outside
the handleEvent method (if I return immediately, it still takes longer and
longer to call handleEvent 1000 times).
A Bizarre effect: If I add a fourth row and call item.setText(3, "Item "+index);
_I can scroll down to the 133700th row and see "Item 133700" immediately_, but
my logger shows I have not processed those rows yet: in fact it still plods
along printing "Getting item 50000", "Getting item 51000" every second or so -
some threading issue I assume? But if Item 133700 is set, why are these events
continuing to be generated?
Here is a snippet from what I am doing:
final Table table = new Table(parent, SWT.V_SCROLL | SWT.VIRTUAL | SWT.H_SCROLL);
final RouteModel model = ((RouteModel)getEditorInput());
table.addListener (SWT.SetData, new Listener () {
public void handleEvent (Event event) {
TableItem item = (TableItem) event.item;
int index = table.indexOf (item);
PrefixNextHop hop = model.getPrefixNextHops()[index];
item.setText (0, hop.getPrefix().toString());
item.setText(1, hop.getNextHopA());
item.setText(2, hop.getNextHopB());
if (index % 1000 ==0 ) {
LOGGER.warn("Getting item "+index);
String [] columns = {"Prefix" , "Next Hop A", "Next Hop B"};
table.setHeaderVisible(true);
for (int i = 0; i < columns.length; i++) {
TableColumn col = new TableColumn(table, SWT.LEFT);
col.setText(columns[i]);
col.setResizable(true);
col.setWidth(100);
// triggers the filling in of the table - is this the problem?
table.setItemCount(model.getPrefixNextHops().length);
Re: Virtual Table Slow [message #437377 is a reply to message #437303] Thu, 03 June 2004 09:09 Go to previous messageGo to next message
Are you running on GTK? GTK has a bug that they ask your for table items
when they shouldn't. It is fixed in newer versions of GTK. Please enter a
problem report hacking the SWT snippet to show the problem. How many items
are you putting in the table?
"Chris Longfield" <clongfield@internap.com> wrote in message
news:c9lf00$41h$1@eclipse.org...
> HI,
quite
2000
CPU.
seconds
per
outside
"+index);
but
plods
so -
events
SWT.H_SCROLL);
> col.setWidth(100);
Re: Virtual Table Slow [message #437392 is a reply to message #437377] Thu, 03 June 2004 12:38 Go to previous messageGo to next message
1) A problem report against SWT?
2) 134000 items
3) Which GTK version is new enough?
4) It sounds like this is not an issue with other OS'es/windowing systems, correct?
Chris
>>HI,
> quite
> 2000
> CPU.
> seconds
> per
> outside
> "+index);
> but
> plods
> so -
> events
> SWT.H_SCROLL);
>>col.setWidth(100);
Re: Virtual Table Slow [message #437398 is a reply to message #437392] Thu, 03 June 2004 13:43 Go to previous messageGo to next message
1) Yes, even though it's a "feature/bug" in GTK if you include the code, we
can benchmark it and try to make it faster.
2) 134000 isn't much. How fast is your machine?
3) GTK 2.3.2 or greater
4) Only an issue on GTK.
news:40BF53ED.20006@internap.com...
items
enter a
items
> 2) 134000 items
correct?
> Chris
> >>HI,
down
> > quite
> > 2000
> > CPU.
> > seconds
seconds
> > per
> > outside
and
> > "+index);
immediately_,
> > but
> > plods
or
> > so -
> > events
> > SWT.H_SCROLL);
> >>col.setWidth(100);
Re: Virtual Table Slow [message #437400 is a reply to message #437398] Thu, 03 June 2004 13:56 Go to previous message
800 MHz/640MB
> items
> enter a
> items
>>2) 134000 items
> correct?
>>Thanks,
>>Chris
>>>>HI,
> down
>>>quite
>>>2000
>>>CPU.
>>>seconds
> seconds
>>>per
>>>outside
> and
>>>"+index);
> immediately_,
>>>but
>>>plods
> or
>>>so -
>>>events
>>>SWT.H_SCROLL);
>>>>col.setWidth(100);
Previous Topic:gcj
Next Topic:Tree.showSelection doesn't work
Current Time: Sun Jul 20 15:33:17 EDT 2025
Powered by FUDForum. Page generated in 0.04382 seconds
