Problem to integrate a 3rd-part plugin [message #437134] |
Thu, 22 September 2005 05:33  |
Originally posted by: reg.sheng.clanfang.com
I have integrated a 3rd-part plugin into my Eclipse-RCP-APP, it's like a
type of XML editor. But the plugin only accepts files which are attached
into the workspace with a proyect. The code of the editor is like the
following:
public void init(IEditorSite site, IEditorInput input) throws
PartInitException {
FileEditorInput fileInput = (FileEditorInput)input; // XXX
If I try to open a external file(away form the workspace, type of
"java.io.File"), it will throw an exception while doing the casting.
There are 2 ideas, which I have now in my mind. They are:
1. Attach the external file into the workspace while trying to open it.
2. Convert a external "java.io.File" into
"org.eclipse.ui.part.FileEditorInput".
I prefer the 2nd way, I think it's cleaner but I don't know if it's
viable, because I've seen that the FileEditorInput contains a a interfaz
IFile which contains at the same time, informations of the workspace.
Maybe the 1st way will be easier.
Would you give me any recomendation of which to choose and how to carry it
out? Or any more suggestion will be welcome also.
Thanks in advance.
ShEng
Re: Problem to integrate a 3rd-part plugin [message #437140 is a reply to message #437134] |
Thu, 22 September 2005 10:50   |
Sheng Fang wrote:
> Hello,
> following:
> PartInitException {
> Thanks in advance.
> ShEng
You can change File to IFile - search eclipse tips & tricks on
www.eclipsezone.com
Re: Problem to integrate a 3rd-part plugin [message #437217 is a reply to message #437140] |
Fri, 23 September 2005 06:14   |
Thank you snpe, this may guide me a little.
snpe wrote:
> Sheng Fang wrote:
>> Hello,
>> following:
>> PartInitException {
>> Thanks in advance.
>> ShEng
> www.eclipsezone.com
Re: Problem to integrate a 3rd-part plugin [message #437257 is a reply to message #437140] |
Mon, 26 September 2005 04:10   |
snpe wrote:
> Sheng Fang wrote:
>> Hello,
>> following:
>> PartInitException {
>> Thanks in advance.
>> ShEng
> www.eclipsezone.com
I'a afraid that the ideas on www.eclipsezone.com do not work to change
File to IFile.
Anyone has more suggestion about this?
Thanx
ShEng
FUDForum. Page generated in 0.27812 seconds
