Home » Eclipse Projects » Rich Client Platform (RCP) » Problem with editor area
Problem with editor area [message #436736] Fri, 16 September 2005 04:46 Go to next message
Originally posted by: alr.agelid.com
i've build an Eclipse RCP that use editor as main components. Such editor
aren't linked to resources or at least resources that may be opened on
startup.
After, opening several editors and layout them, many folders have been
created. That's cool. BUT on start up all these folders are still there.
How can i reset/remove all those folders programmatically.
I've tried to reset the perspective but no influence on editor area.
I've tried to close all editors on close, but i'm probably do it too late
since it's done on the postWindowClose on my WorkbenchAdvisor.
Please help,
Arnauld
Re: Problem with editor area [message #436741 is a reply to message #436736] Fri, 16 September 2005 09:47 Go to previous messageGo to next message
alr wrote:
> editor aren't linked to resources or at least resources that may be
> opened on startup.
> late since it's done on the postWindowClose on my WorkbenchAdvisor.
Make sure that your IEditorInput#getPersistable() returns null. The
workbench doesn't usually try to re-instantiage the editor if it's input
wasn't persisted.
Later,
PW
Re: Problem with editor area [message #436743 is a reply to message #436741] Fri, 16 September 2005 11:11 Go to previous messageGo to next message
Thanks for your reply,
but getPersistable already returns 'null'. that why i've no editor back on
startup.
My problem is all the empty folder (actually editor'area layout's folders)
opened where my editors were.
Re: Problem with editor area [message #436744 is a reply to message #436743] Fri, 16 September 2005 11:28 Go to previous messageGo to next message
Assuming you are using a newer Runtime, would it be an option to create
a shutdownhook for the vm and remember the physical pathes to the
created folders? When the vm shutsdown it will delete the folder for
you. This assumes of course that the vm shutsdown with your rcp app.
Stefan
alr wrote:
> Thanks for your reply, but getPersistable already returns 'null'. that
> why i've no editor back on startup.
> folders) opened where my editors were.
Re: Problem with editor area [message #436745 is a reply to message #436744] Fri, 16 September 2005 11:33 Go to previous messageGo to next message
I think there is a misunderstood, what i'm calling Folder in not the file
system folder, it's an Eclipse's perspecive folder. That a named part of
the layout, where views (or editor part for my concern) can be stacked.
Folder part can be placed relative to others.
Re: Problem with editor area [message #437269 is a reply to message #436745] Mon, 26 September 2005 14:34 Go to previous message
This is a bug. I have filed bug 110684: [RCP] [EditorMgmt] Workbench
sometimes restores multiple empty editor folders
Boris
"alr" <alr@agelid.com> wrote in message
news:cdcb1bf0e41f13c268e3e7cba34a13ee$1@www.eclipse.org...
Previous Topic:plugin is not run
Next Topic:welcome page/intro part always appears
Current Time: Sat Jul 19 23:46:29 EDT 2025
Powered by FUDForum. Page generated in 0.04062 seconds
