Home » Eclipse Projects » Rich Client Platform (RCP) » Opening a specific editor
Opening a specific editor [message #436162] Wed, 31 August 2005 17:43 Go to next message
Originally posted by: jan.roehrich.iao.fraunhofer.de
at the moment I try to learn Eclipse/RCP/GEF. I wrote a very simple editor
which inherits from EditorPart.
I know how to programmatically open a view but I found no way how to open
a specific editor without supplying a certain file suffix and open this
kind of file. I want to open my editor with a model located in memory.
Are there any documents which explain how to manage editors. I only found
http://devresource.hp.com/drc/technical_white_papers/ecliped itor/index.jsp
but this articel doesn't solve my problem.
Thanks in advance
Regards Jan
Re: Opening a specific editor [message #436163 is a reply to message #436162] Wed, 31 August 2005 21:26 Go to previous messageGo to next message
Originally posted by: mail4zlq.gmail.com
At first,you must create "IEditorInput" use your "model located in
memeory",then use can just invoke "IDE.openEditor" to open your editor.
good lucky!
Jan Roehrich 写道:
> Hello,
> Thanks in advance
> Regards Jan
Re: Opening a specific editor [message #436169 is a reply to message #436162] Thu, 01 September 2005 08:41 Go to previous messageGo to next message
Jan Roehrich wrote:
> Hello,
If you haven't used the IDE in your RCP app, check out
IWorkbenchPage#openEditor(...) which takes an IEditorInput and your
editor ID.
Later,
PW
Re: Opening a specific editor [message #436275 is a reply to message #436169] Mon, 05 September 2005 07:24 Go to previous messageGo to next message
> editor ID.
Thanks for this answer. I read a lot and now it's much more clearer. But
now the point is where to open the editor. I want this editor to open
when my RCP application starts. Therefor I tried to use
WorkbenchAdvisor#postWindowOpen but it seems that this method is never
called in my app.
Jan
Re: Opening a specific editor [message #436336 is a reply to message #436275] Tue, 06 September 2005 09:05 Go to previous message
> called in my app.
That I'm not to familiar with. Maybe your WorkbenchAdvisor isn't set up
quite right, or your RCP app isn't doing a full Workbench initialization?
Another option might be to schedule a UIJob ... it'll run after the UI
thread has done most startup work.
Later,
PW
Previous Topic:org.eclipse.ui.forms not included in Plug-In dependencies
Next Topic:Access control on actions and views
Current Time: Sat Jul 19 23:38:03 EDT 2025
Powered by FUDForum. Page generated in 0.28065 seconds
