Home » Eclipse Projects » Dali » Help setting up Dali in eclipse 3.5 on fedora 10, for use with RAP OSGI platform
Help setting up Dali in eclipse 3.5 on fedora 10, for use with RAP OSGI platform [message #435266] |
Thu, 05 February 2009 02:06  |
Hi Dali Collective,
I am currently trying to setup Dali to work with a RAP application.
i) I have decided to use eclipselink as my JPA platform/implementation
ii) I am prototyping this with a MySQL 5.0x backend, and the mysql JDBC jar
iii) I installed the Dali 2.1 tools from the update site, and "installed
software" is currently showing;
"Java Persistence API Tools - EclipseLink Support (Optional)
2.1.0.v200812180210-318Y9oA55S8_795555"
though I can't see Dali installed anywhere - I am not sure how to confirm
this is installed correctly?
However I now have a "JPA" option in eclipse preferences, and I can set
JPA properties on my projects.
iv) I have installed the OSGi bundle from the eclipselink - version 1.0.2;
http://www.eclipse.org/eclipselink/downloads/
into the eclipse/dropins folder and restarted eclipse
v) in eclipse I can now set eclipselink as the JPA platform for my project
I have also set "discover annotated classes automatically" to true
vi) I have now switched to the JPA perspective and created a new
connection to my database,
it tests OK. I can create tables from the "Data source explorer" view.
vii) I can go to my project properties and set eclipselink as the JPA
platform, and set my previously created MySQL connection there.
However I cannot click "connect" it is grayed out - is that a problem?
viii) I can now go to the "JPA content" to edit the connection properties
in persistance.xml to use the previously created MySQL connection
ix) I have created a test class called "Cat" like so;
"public class Cat {
private long id;
private String name;
private String likes;
private Gender gender;"
and added getters and setters, except for setId.
What libs or jars do I need to add to my project to allow it to recognise
the Annotations?
Should I be adding the javax.persistence and eclipselink jar files from
the main eclipselink download, I don't understand exactly where I should
be getting those libs to add to my classpath.
Also I see no "Add Java Persistence..." wizard when right clicking my
project.
I would be grateful for any help
Tom
Re: Help setting up Dali in eclipse 3.5 on fedora 10, for use with RAP OSGI platform [message #435458 is a reply to message #435266] |
Thu, 05 February 2009 11:58  |
Tom,
I'm not sure if you have seen the Getting Started page on the Dali
website, but here is a link -
http://www.eclipse.org/webtools/dali/gettingstarted.php.
Did you have a previous version of Dali installed before installing 2.1?
If not, then the Dali plugins appear to be in your installation.
Make sure you also have WTP 3.0.3 Java EE Developer Tools installed. This
was probably installed while installing Dali 2.1, but just to be safe, try
to install/update the Java EE Developer tools to version 3.0.3.
> the Annotations?
Library management is something we are working on for Dali 2.2, but for
now, all you need to do is define a User Library with the necessary
javax.persistence and EclipseLink classes. This can be done using the
JARs included in the main Eclipse download, or you could add all the
necessary bundles to the library.
The main download JAR's to include are:
.../jlib/eclipselink.jar
.../jlib/jpa/javax.persistence_1.0.0.jar.
For bundles, you would need the following:
javax.persistence_1.99.0.jar
org.eclipse.persistence.jpa_1.0.2.jar
org.eclipse.persistence.antlr_1.0.2.jar
org.eclipse.persistence.asm_1.0.2.jar
org.eclipse.persistence.core_1.0.2.jar
Hope this helps,
Neil
Tom H wrote:
> Hi Dali Collective,
> "public class Cat {
> private long id;
> the Annotations?
> project.
> Tom
Re: Help setting up Dali in eclipse 3.5 on fedora 10, for use with RAP OSGI platform [message #614905 is a reply to message #435266] |
Tom,
> the Annotations?
Hope this helps,
Neil
Tom H wrote:
> Hi Dali Collective,
> "public class Cat {
> private long id;
> the Annotations?
> project.
> Tom
Current Time: Sat Jul 19 09:56:37 EDT 2025
Powered by FUDForum. Page generated in 0.08066 seconds
