Home » Eclipse Projects » Web Tools incubator » [JAX-WS] Unable to generate code from JAX-WS annotations
[JAX-WS] Unable to generate code from JAX-WS annotations [message #435128] |
Thu, 19 March 2009 19:56  |
I have an existing eclipse project with a Spring nature that I want to use
with WTP JAX-WS in order to generate code for the JAX-WS annotations. I was
originally using JAX-WS from the STP project but wanted to switch to WTP. I
run my web services with Spring's
org.springframework.remoting.jaxws.SimpleJaxWsServiceExporte r, not in a web
container. My expectation is that if I edit a Java file with JAX-WS
annotations the corresponding Java should be generated when it is rebuilt. I
think I need to understand when and how they are built to solve this
problem.
Here is now I configured JAX-WS (I have not run into any specific
documentation for this other than the Fuse videos):
1) set CXF runtime tab to dir with apache-cxf-2.1.4
2) in Spring Config tab select "Use Spring Application Context" (I am not
sure what the purpose of the panel is???)
3) in <project> -> Properties -> Java Compiler -> Annotations I enabled
annotation processing by checking the box (no other changes)
I was notified with a dialog that the project needed to be rebuilt (and I
would expect it to detect the annotations in my source at this time). I see
and empty <project>/.apt_generated directory created but no .class files for
the JAX-WS annotated Java.
Any help appreciated.Thanks!
Derek
Re: [JAX-WS] Unable to generate code from JAX-WS annotations [message #435136 is a reply to message #435134] |
Fri, 20 March 2009 16:11   |
Hi Shane,
Ok, I seem to be getting code generation to happen. But now I see a problem
in the java2ws console output. I poked around and did not see an obvious way
to control this for java2ws. My IDE compiler compliance level is set to 1.6
globally and for the specific project. I am running on Linux x64 with
openjdk.
java2ws -cp /home/dpalma/eclipsedata/test/Test3/build/classes -s
/home/dpalma/eclipsedata/test/Test3/.cxftmp/src -d
/home/dpalma/eclipsedata/test/Test3/.cxftmp/wsdl -classdir
/home/dpalma/eclipsedata/test/Test3/build/classes -o
pojo1.wsdl -createxsdimports -verbose -frontend jaxws -databinding
jaxb -wsdl -wrapperbean test.jaxws.POJO1
java2ws - Apache CXF 2.1.4
Derek
P.S. Thanks for your responsiveness. Let me buy you a drink at Eclipse Con
if you are there...
1. ERROR in
/home/dpalma/eclipsedata/test/Test3/.cxftmp/src/test/jaxws/G etString.java
(at line 15)
@XmlRootElement(name = "getString", namespace = "http://jaxws.test/")
Syntax error, annotations are only available if source level is 1.5
2. ERROR in
(at line 16)
@XmlAccessorType(XmlAccessType.FIELD)
3. ERROR in
(at line 17)
@XmlType(name = "getString", namespace = "http://jaxws.test/")
3 problems (3 errors)
pojo2.wsdl -createxsdimports -verbose -frontend jaxws -databinding
jaxb -wsdl -wrapperbean test.jaxws.POJO2
"Shane Clarke" <shane_clarke@hotmail.com> wrote in message
news:1bd6083099cadcee81f42df324c0653b$1@www.eclipse.org...
> Hi Derek,
> From your description it sounds like you've used Apache Axis as the Web
> Service Runtime in the wizard.
> When you open the wizard make sure you change the "Web Service Type" at
> the very top of the page to "Bottom up POJO Web Service". Or set this up
> in the preferences i mentioned in the last post.
> When you select your service implementation class using the browse button
> you should see the "Configuration" section just below that field and to
> the right of the slider change.
> The Web Service Runtime in that configuration should now read "Apache CXF
> 2.x"
>> 1) Under what specific circumstances will the classes be generated. Will
>> they only be generated when I run the wizard or each time I change and
>> cause a build of the POJO class?
> The classes are only generated when you run through the wizard.
>> I presume the wizard saves some information about the POJO that will be
>> treated as a web service implementation.
> An jaxws endpoint configuration is created in the spring configuration
> that's setup.
> Depending on the option in the preferences that'll either be a beans.xml
> file or a cxf-servlet.xml file.
> The location of that file will be in the /WebContent/WEB-INF/ directory.
>> 2) I also did not see any annotations get added to my POJO. Your note
>> indicates you expect the annotations to be added to my POJO source. I
>> presume you mean at least WebService and WebMethod.
> It will add @WebService, @WebMethod, @WebParam, @ResponseWrapper and
> @RequestWrapper depending on preferences and if they already exist in the
> code.
>> 3) Is there a log entry I can look for to see if everything worked fine
>> or not?
> Any errors that might occur are logged. Check the Window > Show View >
> General > Error Log.
> Also, the CXF Java2WS and WSDLJava tools logs output to the console view
> when run. So you should see that output if it runs correctly.
>> Note: I have not tried to deploy the web service yet so if the classes
>> are only generated at deployment this could be my problem. However, I
>> plan to use Spring in a mode where it uses the JAX-WS Endpoint API to
>> deploy services for internal testing. I can use a regular web app
>> container like Tomcat if this is required.
> No need to deploy to generate classes.
> Shane
Re: [JAX-WS] Unable to generate code from JAX-WS annotations [message #435138 is a reply to message #435136] |
Fri, 20 March 2009 16:33   |
I was able to get rid of the 1.5 compliance issue by doing a QuickFix from
the Problems pane. Where exactly is this configurated?
"Derek Palma" <derek.palma@gmail.com> wrote in message
news:gq0taf$smt$1@build.eclipse.org...
> Hi Shane,
> problem in the java2ws console output. I poked around and did not see an
> obvious way to control this for java2ws. My IDE compiler compliance level
> is set to 1.6 globally and for the specific project. I am running on Linux
> x64 with openjdk.
> Derek
> if you are there...
> 1. ERROR in
> (at line 15)
> 2. ERROR in
> (at line 16)
> 3. ERROR in
> (at line 17)
>> Hi Derek,
>> 2.x"
>> that's setup.
>> code.
>>> or not?
>> Thanks,
>> Shane
Re: [JAX-WS] Unable to generate code from JAX-WS annotations [message #570158 is a reply to message #435134] |
Hi Shane,
openjdk.
Derek
if you are there...
1. ERROR in
(at line 15)
2. ERROR in
(at line 16)
3. ERROR in
(at line 17)
> Hi Derek,
> 2.x"
> that's setup.
> code.
>> or not?
> Shane
Re: [JAX-WS] Unable to generate code from JAX-WS annotations [message #570180 is a reply to message #435136] |
> Hi Shane,
> x64 with openjdk.
> Derek
> if you are there...
> 1. ERROR in
> (at line 15)
> 2. ERROR in
> (at line 16)
> 3. ERROR in
> (at line 17)
>> Hi Derek,
>> 2.x"
>> that's setup.
>> code.
>>> or not?
>> Thanks,
>> Shane
Re: [JAX-WS] Unable to generate code from JAX-WS annotations [message #570768 is a reply to message #435139] |
Fri, 26 February 2010 15:12  |
Sorry to revive such an old thread, but it's the only one I can find that mentions the option I'm missing.
I'm trying to create a JAX-WS web service using Apache CXF and I'm missing the "Bottom Up POJO Web Service" and "Top Down POJO Web Service" choices in my "Web Service Type" drop-down list.
I'm running Galileo (JEE) with JDK 1.6.x. Any suggestions?
Current Time: Sat Jul 19 12:46:53 EDT 2025
Powered by FUDForum. Page generated in 0.05311 seconds
