Home » Eclipse Projects » Rich Client Platform (RCP) » Help doesn't work after export
Help doesn't work after export [message #435063] Tue, 09 August 2005 12:44 Go to next message
Hello !
I use help in my RCP application and everything works perfectly when I
launch the application as a product in eclipse. I am able to export it,
too, but there are some problems with help.
First, I can't specify anywhere the runtime required plugins for help
(tomcat, help.webapp, ...). If I try to add them in plugin.xml I have an
error at runtime.
So I specified the libs in the runtime configuration and tried to export
them manually. It doesn't work either. I tried to put them in the
plugin/ folder, or even the lib/ folder of the jar of my application.
In fact the applications works well except that the help button in the
menu doesn't do anything : the help browser doesn't start.
Anyone has an idea ? Thanks
Vincent
Re: Help doesn't work after export [message #435066 is a reply to message #435063] Tue, 09 August 2005 15:01 Go to previous messageGo to next message
Are you using a Manifest? If so, you may have to manually enter the
required help jars in there.
Vincent Etter wrote:
> Hello !
> error at runtime.
> Vincent
Re: Help doesn't work after export [message #437121 is a reply to message #435063] Wed, 21 September 2005 13:40 Go to previous messageGo to next message
I had the same problem with getting help working in a deployed rcp app
on eclipse 3.1, and solved it as follows:
1. Created a config.ini in the configuration directory that included all
bundles used by the base rcp platform, by the help system, and by my
application. Each bundle specified here should have a corresponding
plugin (either source or binary) in the plugins directory of your rcp app.
2. Launched the application with jvm command line switches "-debug -clean"
The first time I did this the rcp app would not start at all (whereas
previously it had started but help didn't do anything). So I examined
the nnnnnnnnnnnnn.log file in the configuration directory and saw that
the help system actually needs one more plugin than stated in the
literature: org.eclipse.ui.forms. Adding this plugin to the rcp app and
to the config.ini file fixed the problem - it started again and help now
worked.
Here is the final bundle list I ended up with:
osgi.bundles = org.eclipse.core.runtime@2:start, \
org.eclipse.osgi, \
org.eclipse.core.commands, \
org.eclipse.core.expressions, \
org.eclipse.help, \
org.eclipse.jface, \
org.eclipse.swt, \
org.eclipse.swt.win32, \
org.eclipse.ui.workbench, \
org.eclipse.ui, \
org.eclipse.ui.forms, \
org.apache.ant, \
org.apache.lucene, \
org.eclipse.help.appserver, \
org.eclipse.help.base, \
org.eclipse.help.ui, \
org.eclipse.help.webapp, \
org.eclipse.tomcat, \
your.plugin.here
HTH
Keith
> Hello !
> error at runtime.
> Vincent
Re: Help doesn't work after export [message #437334 is a reply to message #437121] Tue, 27 September 2005 10:43 Go to previous message
Thanks a lot !
It worked fine ! But it seems a little complicated for something that
should be automatically done when exporting...
In fact, after some tests, it seems that it works without editing
config.ini. I only have to add manually in the plugin/ dir the plugins
you listed.
> worked.
> org.eclipse.osgi, \
> org.eclipse.help, \
> org.eclipse.swt, \
> org.eclipse.ui, \
> org.apache.ant, \
> your.plugin.here
> HTH
> Keith
Previous Topic:plugin_customization.ini: how to specify url for update-policy?
Next Topic:How can I add source location to a jar file that is a plugin dependency
Current Time: Sun Jul 20 01:52:37 EDT 2025
Powered by FUDForum. Page generated in 0.04059 seconds
