Home » Language IDEs » C / C++ IDE (CDT) » Projects with C/C++ and Java
Projects with C/C++ and Java [message #43483] Mon, 30 September 2002 10:49 Go to next message
Originally posted by: crvich.us.ibm.com
Anyone know how developers are approaching projects that contain both C/C++
code as well as Java? e.g., people who do primarily Java dev, but also
have some native code. Are they using two separate projects and compiling
each language separately?
Ernest M. Crvich
IBM ODE Team
http://w3.ode.raleigh.ibm.com/
Have footbag, will shred
Re: Projects with C/C++ and Java [message #43581 is a reply to message #43483] Tue, 01 October 2002 12:31 Go to previous messageGo to next message
Hi Ernest,
For the most part I believe that people are using separate projects or using
an approach such as we use in the CDT.
See
org.eclipse.cdt.core.linux for an example of how we use a folder within a
Java Project (library) as the source folder for the C code that is used to
create the ".so" files for this platform.
-Judy
Re: Projects with C/C++ and Java [message #43610 is a reply to message #43581] Tue, 01 October 2002 13:29 Go to previous messageGo to next message
Hi Judy,
Could you please explain what you mean by "using an approach such as we use in
the CDT".
Thank you
Anil
"Judy N. Green" wrote:
> Hi Ernest,
> See
> -Judy
> ¨¨¨°ºo§oº°¨¨¨¨°ºo§oº°¨¨¨¨°ºo§oº°¨ ¨¨¨°ºo§oº°¨¨¨¨°ºo§oº°¨¨¨
> Judy N. Green Software Engineer
> QNX Software Systems Ltd. www.qnx.com
> "Ernest Crvich" <crvich@us.ibm.com> wrote in message
> news:an9oae$roh$1@rogue.oti.com...
> C/C++
> | Ernest M. Crvich
> | IBM ODE Team
Re: Projects with C/C++ and Java [message #43983 is a reply to message #43610] Mon, 07 October 2002 11:07 Go to previous messageGo to next message
"Anil Ambati" <aambati@us.ibm.com> wrote in message
news:3D99DB96.E1D83A1F@us.ibm.com...
| Hi Judy,
use in
| the CDT".
Rather than try to explain a directory structure etc. ... and probably fail
miserably and confuse everyone in the bargain (given that it is Monday
morning and I haven't quite got a full coffee into me) ...
I would recommend that you check out the "org.eclipse.cdt.core.linux"
project (or browse it via the web interface) and see what I mean.
It is a very small project and set up for both Java and C++.
-Judy
| Thank you
| Anil
| > Hi Ernest,
using
| > See
a
to
| > -Judy
Re: Projects with C/C++ and Java [message #45352 is a reply to message #43983] Tue, 15 October 2002 17:06 Go to previous messageGo to next message
Originally posted by: dschaefer.rational.com
For the little work I've done with native code, I've created two projects. I
wrote the makefile for the native code so that the shared library would be
output in the Java project so that LoadLibrary would pick it up at debug
time.
I would think that working on such projects would be a common scenario and I
would certainly like to see good support for working with projects that have
both Java and C/C++ for JNI.
- Doug
"Judy N. Green" <jgreen@qnx.com> wrote in message
news:ans68b$n1i$1@rogue.oti.com...
> | Hi Judy,
> use in
> | the CDT".
fail
> -Judy
> | Thank you
> | Anil
> | > Hi Ernest,
> using
> | > See
within
> a
used
> to
> | > -Judy
Re: Projects with C/C++ and Java [message #67116 is a reply to message #43483] Mon, 21 April 2003 22:58 Go to previous message
I have two Eclipse installs - one with CDT and 2.02 and the Java one with
the
latest 2.1 code
Peter
C/C++
> Ernest M. Crvich
> IBM ODE Team
Previous Topic:Debugger doesn't work
Next Topic:Debugger crash when expanding variable
Current Time: Sat Jul 19 06:40:50 EDT 2025
Powered by FUDForum. Page generated in 0.04648 seconds
